Old May 6th, 2013, 03:39 PM   #1
ZeroG
ZeroG's Avatar
Motorcycle(s): '93 Ninja 600 (project)
Question Gas not getting past the petcock
I'm currently fixing up a 1993 zx600 that has been sitting for the past 5 years. I've cleaned the carbs and rusted tank and cleaned/rebuilt the petcock. It starts right up if I pour gas directly into the carbs, but for some reason, it won't draw gas out of the tank.
I've tried it with the tank partially filled with the petcock on reserve and fully filled with the petcock on normal, neither of which worked. Replacing the gaskets and vacuum diaphragm in the petcock hasn't made any apparent difference (except that it no longer leaks).
I'm completely stumped! Any help would be appreciated.
ZeroG is offline   Reply With Quote
Old May 6th, 2013, 04:08 PM   #2
SabreValkyrn
Motorcycle(s): 2017 Motus MSTR (Kara), 1990 Ninja 600R (ZX600C3) (Scrappy)
This is the bike from: Is this bike worth the chance?
Valves adjusted, carbs cleaned, and oil/coolant changed.
The bike sounds really smooth and wonderful when it starts.
Stock everything from what I can tell, even Dunlops.
By-passing the petcock results in an almost instant cold (or warm) start.
With the petcock, we are able to get it started if the choke and throttle are completely open.
SabreValkyrn is offline   Reply With Quote
Old May 6th, 2013, 04:17 PM   #3
CynicalC
CynicalC's Avatar
Motorcycle(s): '96 EX250
Reattach vacuum lines correctly? Check for obstructions in vacuum line? Try actually running it and check for vacuum with a gauge?
Ç¥ñ頻| ßÿ Ñâ7µ®é. Äñt¡~§º¢Ïä| ßý Çhøî©è.
Old May 6th, 2013, 04:20 PM   #4
Jesse8931
Jesse8931's Avatar
Motorcycle(s): 2007 ninja 250r
you can remove the spring in the petcock but fair warning it will flood your bike out if the motor is not running you have the fuel on.
Jesse8931 is offline   Reply With Quote
Old May 7th, 2013, 03:03 PM   #5
Have you cleaned the mesh filters that go inside the tank?
Old May 7th, 2013, 03:25 PM   #6
SabreValkyrn
Yes, we removed the normal/higher one because it was so crusted and filled with rust. There is an inline fuel filter, so we were advised to just take off the petcock mini-filter.
Old May 7th, 2013, 03:29 PM   #7
Open the gas tank cap and blow backwards in normal and reserve position.
You should hear plenty of air bubbling inside the tank.
Connect a long hose the outlet of the petcock and make a U shape, blowing from a point well above the level of the fuel.
Old May 7th, 2013, 05:39 PM   #8
gitoy
Motorcycle(s): 04 ninja 250, 05 zzr 600 (sold), 07 cbr600rr
is everybody in agreement that this whole petcock issue is hands on dirty?....bwahhaha...
gitoy is offline   Reply With Quote
Old May 8th, 2013, 11:23 AM   #9
sLick415
Put a tube on the vacuum port, suck on it and see if gas starts flowing.
sLick415 is offline   Reply With Quote
Old May 9th, 2013, 06:32 AM   #10
Originally Posted by ZeroG View Post
.........I'm completely stumped! Any help would be appreciated.
Any updates?
Old May 9th, 2013, 06:53 AM   #11
cuong-nutz
cuong-nutz's Avatar
http://www.sportbikes.net/forums/zzr...-gone-out.html
I suspect the fuel pump to be out. Make sure the solder joints are not broken/corroded.
HalfFast Racing Team
Old May 9th, 2013, 07:02 AM   #12
Jesse8931
Jesse8931's Avatar
its a 93 no fuel pump
Old May 9th, 2013, 07:16 AM   #13
cuong-nutz
cuong-nutz's Avatar
ah.... Must be thinking of something else
any updates @SabreValkyrn, @ZeroG
Old May 9th, 2013, 07:48 AM   #14
SabreValkyrn
Thank you all for your replies, the bike is 85 miles from me and 180 from ZeroG, at a friends house. Given Mother's day, we aren't able to work on it this weekend. I think Zero is going to work on it on Wednesday.
Old May 9th, 2013, 09:04 AM   #15
ZeroG
ZeroG's Avatar
Yep, that's the plan at the moment. When I get back up there, I'll run through all your suggestions and see what happens.
And Cuong_nutz, don't scare me like that
Last futzed with by ZeroG; May 9th, 2013 at 10:27 AM.
Old May 14th, 2013, 02:09 PM   #16
ZeroG
ZeroG's Avatar
Okay, everybody. I've just spent the past couple hours tinkering with this issue again.
When I got here, I noticed that there was a little gas leaking out of the petcock. Further inspection showed that it was leaking from the knob-side of the petcock. Also, when I turned the petcock to On or Reserve, gas would dribble from the outlet (with no vacuum).
I took the whole thing apart again, used gasket sealer on all the gaskets, and put it back together. It no longer leaks or dribbles, but there's still no flow! I tried sucking on the vacuum hose and hooking it up and starting the bike with no success.
I also noticed that when I started the bike, I had to use the choke (not unexpected), but if I gave it any throttle, it died immediately. I don't know if that's connected at all, but I thought I'd mention it.
This is driving me crazy!
As iron sharpens iron, so one man sharpens another. Proverbs 27:17
Old May 14th, 2013, 02:33 PM   #17
cuong-nutz
cuong-nutz's Avatar
Sounds like the assembly of the petcock is not correct. When vacuum is pulled from the petcock, gas should flow.
Old May 14th, 2013, 04:16 PM   #18
Jesse8931
Jesse8931's Avatar
again removed the spring and try again
Old May 14th, 2013, 09:23 PM   #19
ZeroG
ZeroG's Avatar
There still isn't any flow even without the spring in the petcock. I also took it out of the tank (again) and tried putting water through it while sucking on the vacuum line - still nothing.
So the tank and carbs are not the issue, it's definitely something up with the petcock. I can't think what else to do but just try and find a new universal replacement or something.
Any last bright ideas? By the way, thanks for all the help so far!
Old May 14th, 2013, 09:42 PM   #20
ZeroG
ZeroG's Avatar
I pulled out the diaphragm as well and capped off the vacuum nipple. That basically makes it into an expensive shutoff valve, which works... kind of. It flows fine now in the On and Reserve positions, but obviously it's not controlled by vacuum, and I'd have to shut it off every time I stop.
Old May 15th, 2013, 03:19 AM   #21
ai4px
ai4px's Avatar
Motorcycle(s): 650r 2009 Vulcan 800 2005
Nice to know you can suck start a ninjette. What a happy little motorcycle.
It's all about the curves. If you ride, you understand. If you have a stick skinny g/f and ride, you're 1/2 way there.
ai4px is offline   Reply With Quote
Old May 15th, 2013, 12:22 PM   #22
ZeroG
ZeroG's Avatar
Yet another update:
The vacuum-less petcock is now installed on the tank. The fuel flows fine when the hose and filter are not attached to the carbs (just dumping it into a gas can). When I connect everything, however, the fuel doesn't flow at all.
The only reason I can think of for this is if there was a blockage in the carbs, but not only did I clean them, the fuel gets down fine when we run it straight in from a gas can.
So from all the tests I've run, everything works fine by itself, but together there's still an issue..........
Old May 15th, 2013, 02:54 PM   #23
cuong-nutz
cuong-nutz's Avatar
Maybe the vent on the carbs are clogged?
Possible gas leak from carbs or petcock issue agentbad 1986 - 2007 Ninja 250R Tech Talk 7 December 13th, 2013 07:45 AM
Took off fuel tank and petcock is dripping gas... Navigon 2008 - 2012 Ninja 250R Tech Talk 31 February 4th, 2013 07:16 PM
WTB : 08+ gas tank petcock. abhijitz Items Wanted 0 August 22nd, 2012 06:23 PM
Gas Tank Petcock Problem? jboyd12 2008 - 2012 Ninja 250R Tech Talk 17 April 2nd, 2012 09:15 AM
Argh! Gas leak from petcock. Strange 1986 - 2007 Ninja 250R Tech Talk 8 March 17th, 2009 03:07 PM
