Old May 9th, 2013, 06:55 PM   #1
The_big_dill
The_big_dill's Avatar
Motorcycle(s): 1987 Ninja 250 custom gold
Post Some issues
Hi all,
Have got the bike together and tuned the idle mixture screws and its running great, revs up and back down better than ever! Except... It has been idling like crap.
It is unsteady and constantly floating around 1000-1500 rpm.
I sense a vacuum leak. The only thing that was a PITA to get back on the bike since the carb cleaning, was the boots from the air box.
Since its the first rebuild since i owned the bike, i have noticed a bunch of things that are unplugged:
1. Coolant reservoir upper hose (Does this stay unplugged?):
2. This little filter looking thing, goes nowhere... The end of that yellow cylinder is the hose end.
3. The input to the hose looks like this on the top of the tank. Where do i route this hose? It keeps getting in the way of the seat keeps it slightly elevated, really annoying.
4. And finally, this hose that i circled in red, looks like there was a little clamp on the end there to hold that to a nipple:
The_big_dill is offline   Reply With Quote
Old May 9th, 2013, 08:10 PM   #2
First one goes all the way down as a drainage.
The rest, I cannot see what point the pics are referring to, since they are so close up.
Old May 10th, 2013, 02:52 AM   #3
The_big_dill
Thanks,
The 2nd and 3rd go from the top of the tank to a filter type of thing to the right side of the battery and then nowhere... (the manual says it should go to a canister)
Last one is bottom front of the airbox, next to the connection from airbox to the crankcase.
Old May 10th, 2013, 06:09 AM   #4
Originally Posted by The_big_dill View Post
..........Last one is bottom front of the airbox, next to the connection from airbox to the crankcase.
The 2nd and 3rd should be just a vent for the tank (added for track or racing since the original tank vented through the cap) plus some carbon activated canister to avoid fuel vapors flow into the atmosphere.
Maybe the yellow thing is a non-return valve for preventing fuel spills when the bike falls on its side.
Just guessing here, not sure.
Sorry, no idea about the last one.
Where the other ends connects to?
You are welcome
PM sent.
Old May 10th, 2013, 07:46 AM   #5
quicklooker
Motorcycle(s): Ninja 250R '07
4th one looks like the airbox drain hose. It usually has a little plug on the end of it so it doesnt just freely leak despite the fact it hangs down with some other hoses.
You're supposed to unplug it every so often to let some liquid come out of it (usually oil or air filter oil) but I am not sure if it'd hurt to just leave it unplugged and hanging...
quicklooker is offline   Reply With Quote
Old May 10th, 2013, 06:40 PM   #6
The_big_dill
Looked up the hose coming out of the tank in the manual and it is suppose to go to a canister and recirculate the fuel. Unfortunately, the bike did not come with a canister and am left with an open hose...
However this does not explain the unsteady idle. The bike starts quick and runs well, besides the idle.
I have already tuned the idle mixture screws and the bike revs up and settles well.
Old May 11th, 2013, 08:14 AM   #7
soggybottom
Aimless
Motorcycle(s): 01 ninja 250
If your carbs are clean like you say, then I would guess carbs out of sync. When was this checked last? Out of sync carbs result in a screwy idle.
I just dropped in to see what condition my condition was in
soggybottom is offline   Reply With Quote
Old May 11th, 2013, 09:09 AM   #8
The_big_dill
Thats a good point, i did adjust the butterfly valve openings by eye, but i do need to do this checking vacuum to get a better reading.
Old May 11th, 2013, 11:24 AM   #9
infinitewhiskey
meh
Motorcycle(s): 2002 EX250F Cafe/Streetfighter Project
I see no ones suggested this yet, but have you tried this? I had kind of the same problem after my rejetting and tweaking that adjuster made everything alright. Also, have you checked valve clearances?
SoCal 626/951
instagram | youtube | modifications
infinitewhiskey is offline   Reply With Quote
Old May 11th, 2013, 01:10 PM   #10
soggybottom
Aimless
I have tested carbs I've set by eye, and they have usually been pretty off. Maybe I just have crumby eyes, but I always feel better properly syncing them.
Old May 12th, 2013, 11:51 AM   #11
The_big_dill
Thanks for your experience, i will need to make a contraption that will test this for me.
Old May 12th, 2013, 12:33 PM   #12
http://faq.ninja250.org/wiki/How_do_...carburetors%3F
Old May 21st, 2013, 04:59 AM   #13
baxtc1
baxtc1's Avatar
Motorcycle(s): '92 GPX 250 (Gone and replaced with '08 V-Strom), 2005 Suzuki C50.
The air box drain being unplugged would be as good as a vacuum leak, you will also be getting unfiltered air into your engine.
baxtc1 is offline   Reply With Quote
Several issues The_big_dill 1986 - 2007 Ninja 250R Tech Talk 21 June 12th, 2013 10:16 AM
Still Having Issues! Achilles 2008 - 2012 Ninja 250R Tech Talk 11 March 3rd, 2013 10:26 AM
2 issues I am having as a beginner... Miraha Riding Skills 39 April 30th, 2011 01:51 PM
Having some troubleshooting issues... Cloud Strife 2008 - 2012 Ninja 250R Tech Talk 70 April 19th, 2011 02:58 PM
I was having issues... Apex General Motorcycling Discussion 24 February 6th, 2010 05:21 PM
