Old June 9th, 2013, 07:44 PM   #1
Lucagst
Lucagst's Avatar
koso rx2n wheel settings
Hello everyone' I have just installed a Koso rx2n gauge, I wanted to know the configuration settings for the wheel because I think that the speed is off.The speed sensor that i am using is the one that came with the original koso rx2n. i tried the speed sensor adapter that came with the plug and play harness and i get no speed reading so i installed the original koso sensor that came with the gauge. Tank you in advance for your help
Lucagst is offline   Reply With Quote
Old June 9th, 2013, 08:49 PM   #2
NevadaWolf
Certified looney toon
NevadaWolf's Avatar
MOTM Jul '13, Jul '14
Hey there.
@RaceTech Electric put out an install video that has the specs at the end of it.
Also, here's a previous post of his...
Originally Posted by RaceTech Electric View Post
Hey guys, this is Evan from RaceTech Electric (we're going to use the same account on here). I'm our Engineer and tech guy. I've finished the install and all of the filming on our test bike. I'm going to edit the video tomorrow hopefully, I should have it posted on YouTube by Monday at the latest.
Here's the settings I used:
For a 110/70R17 tire, use 722 P2 for the circumference settings. 1840 or so is the actual circumference, but that produces insanely high speeds. 722P2 is reasonable, but will need to be adjusted.
Water Temp Warning: 230F
Oil Temp Warning: 240F
Fuel Sender Resistance: 100 Ohms
Tach: 13,000 RPM Redline Warning
Ignition: 4C, 2P (4cycle/stroke, 2pistons)
Video coming soon!
<-- Linky
Old June 9th, 2013, 09:09 PM   #3
rojoracing53
Fast-Guy wannabe
rojoracing53's Avatar
MOTM - Jan '13
Make sure all your magnets are facing the same way because polarity matters.
to get my speed calibrated perfectly I take the bike up to 80mph via gps on my phone and hold it there and note what the koso says. if the koso is at 75 then you dived 80 by 75 and get 1.066666. take the number programed into the koso and multiply it by 1.066666, the number you get is your new wheel circumference. go out and check your koso against your gps one last time to confirm its good.
Old June 11th, 2013, 06:52 PM   #4
Lucagst
Lucagst's Avatar
sorry for the delay guys.The sensor that comes with the gauge does not use magnets it uses the bolts of the rotor.So the settings you guys suggested helped me a little,Now the only thing left to do is to take a ride with the GPS to see if it good.tank you i will reply again with more information
Rear Shock Settings FvnnyL3tt3r1ng 2008 - 2012 Ninja 250R Tech Talk 5 August 16th, 2013 04:04 PM
[sportrider - latest stories] - Wheel to Wheel AMA Pro Flat Track Action Returns to S Ninjette Newsbot Motorcycling News 0 September 24th, 2012 06:40 PM
YouTube Syndication Settings HELP!! Minikin_Jo Videos 2 September 13th, 2012 12:16 PM
Koso Gauge config settings snowsoldier 2008 - 2012 Ninja 250R Tech Talk 2 March 21st, 2012 08:24 PM
rear suspension settings? Colezombie 2008 - 2012 Ninja 250R Tech Talk 10 January 17th, 2011 08:47 AM
