June 23rd, 2013, 04:59 PM | #1 |
Join Date: Jun 2013 Motorcycle(s): 2008 Ninja 250r Posts: 288
Question about tires
Hello everyone!
I am looking at buying a ninja 250 from craigslist, and I found a black ninja that I like, but the tire looks semi-worn in the picture. I texted the owner this weekend but he hasn't gotten back to me about it. I wanted your guys opinion on whether it looks absurdly worn or not, because I have no idea what I am looking at. And i don't need you guys telling me to go see the bike, because it is an hour drive and I am trying to decide on two bikes within my budget, and replacing the tires could make the difference. Thanks! |
June 23rd, 2013, 05:04 PM | #3 |
June 23rd, 2013, 05:04 PM | #4 |
Fix It Till Ya Break It
Join Date: Oct 2011 Motorcycle(s): 08 250RRrrrr Posts: 623
see the bike
because I can't tell from the big high quality picture |
June 23rd, 2013, 05:05 PM | #5 |
June 23rd, 2013, 05:07 PM | #6 |
MOTM - Jan '18, Sep '13
You really shouldn't settle for a bike before you've seen it. It could seem fine in pictures but not be so good after all. Yeah you might save yourself a few bucks now on gas or maybe even the tires, but it might cost you so much more because you settled on something that wasn't well maintained.
On the flip side, maybe it's just the tires and everything else is fine with the bike. Paying for tires is cheaper than paying for a full service. |
June 23rd, 2013, 05:07 PM | #7 |
Bass Master General
As did it, ****** image.
I also thought an hours drive isn't unreasonable for such a big purchase, in fact that's nothing, so grow a pair and stop telling me what not to say because i'll just go ahead and say it anyway. |
June 23rd, 2013, 05:08 PM | #8 |
June 23rd, 2013, 05:10 PM | #10 |
June 23rd, 2013, 05:12 PM | #11 |
don't say that
June 23rd, 2013, 05:16 PM | #12 |
Bass Master General
If you hadn't of been an arsehole as to reject someones help based on something you didn't want to hear because of no good reason I wouldn't have picked up on that, and I wouldn't have taken your original dismissive arsehole comment and turned it around.
You may not like to hear you have to see the bike, you may want to pretend you don't have to, but to tell me not to tell you something you don't want to hear? No, I will tell you what you need to hear, not what you want to hear, because that's ultimatly a much nicer thing to do, don't like it? You have the right not to like it, not the right to tell people not to say it. |
June 23rd, 2013, 06:09 PM | #13 |
Join Date: Jun 2012 Motorcycle(s): 2013 Ninja 300 Posts: 718
Hey. Children. Cool it.
The tires don't look ridiculously worn, but you DO need to really look at them to tell, or at least get a better picture. Good advice you don't want to hear is still good advice. |
June 23rd, 2013, 07:05 PM | #14 |
I'll ask another question then, when going to see the tires, what is a good rule of thumb for tread left/wear that I should assume is good/bad?
If that makes sense. |
June 23rd, 2013, 07:49 PM | #15 |
Tires have wear bars on them. If the tread is down to the level of the wear bars, its about time to replace them. Also should check the manufacture date of the tires. Tires are usually good for up to about 5 years. I believe its in the form of a 4 digit number; first two indicate which week of the year, and the last two are the year. Cracking hard rubber is a sign to replace the tires.
June 23rd, 2013, 08:41 PM | #16 |
Long story short....
Tires are a consumable item when it comes to riding. If your basing your idea to buy a bike based on tires then you need to rethink some things. I do understand not wanting to put tires on a bike you just bought but if the deal is right.... then buy the bike and replace the tires. EDIT: The tires are fine by what I can see from the pic.
June 24th, 2013, 10:23 AM | #17 |
crash 250, get supersport
Join Date: Apr 2010 Motorcycle(s): 2010 250R SE (Sold 6/9/14), 2009 ZX-6R (Sold 6/25/14), Subaru BRZ Posts: A lot.
What kind of riding do you plan on doing? Those tires look decent for everyday commuting, but I can't give a solid answer without having a high-resolution picture of the tread and where the wear bars are.
I spot a Two Brothers can = do not wantttttttt. ...unless you want to be brap brappin' all day. As @csmith12 said, tires are a consumable item and you'll be expected to eat through sets of tires for the entire duration of your motorcycling career. There are plenty of tires that fit the new-gen (either stock or different sizes), but it really depends on the application of those tires, rather than just getting uber sticky tires. Choose tires that fit your particular needs. Personally, I only run radials that are proven to provide adequate grip in all conditions, regardless of the mileage-expectancy of the tire. "Where the rubber meets the road" is literally the contact patch of your tires, remember that. Last futzed with by menikmati; June 24th, 2013 at 08:32 PM. |
June 25th, 2013, 01:19 AM | #18 |
Check the 4 digit code on the side walls. If it's 4-5 years or has been sitting for some time during the bike's life, it's likely to develop side wall cracking if it hasn't already.
June 25th, 2013, 03:36 AM | #19 |
Join Date: Apr 2012 Motorcycle(s): 09 Ninja 250R (Crashed/Unexistent) / 11 Ninja ZX6R Posts: 83
maybe the owner sold it and thats why it has not answer. you live in murrieta, is the bike in sd area or where?
June 25th, 2013, 03:15 PM | #20 |
I texted him again a few days ago.
I am going down to San Diego to look at two different bikes tomorrow morning. And Im going to Torrance Thursday morning to look at a third. I'll be making a decision after that. Thanks for the help guys! |
Question on new tires, and 3/4 boots | ichibunkid.206 | General Motorcycling Discussion | 16 | June 5th, 2013 10:22 AM |
noob question about buying tires | gt_turbo | 2008 - 2012 Ninja 250R Tech Talk | 37 | August 11th, 2011 09:02 AM |
Stupid question (involving tires) | Soujyu | 2008 - 2012 Ninja 250R Tech Talk | 12 | May 9th, 2010 11:15 PM |
Another Tires Question | paterick4o8 | 2008 - 2012 Ninja 250R Tech Talk | 19 | August 28th, 2009 05:12 AM |
Question about tires | Sailariel | 2008 - 2012 Ninja 250R Tech Talk | 7 | November 10th, 2008 05:15 PM |
