Old June 24th, 2013, 02:25 PM   #1
PEN25
Motorcycle(s): 2001 ex250
idle issue
having issues with my 01. starts fine and idles fine until i ride. the rpm's dont seem, to want to come down from 5k as i have the clutch engaged or in neutral until i adjust the idle screw. then i have to turn it a 1/4 turn to restart. if i ride it again i have to turn it a turn or so down then have to turn it a turn back again. doesnt seem to have anything hung up on my cables.
the other thing i have an issue with is it is slow to drop rpm after coming off the throttle. takes about 10 seconds to come down to 1500rpm's. I did pull the carbs apart to clean the float bowls and a quick spray down when my petcock needed rebuilt. outside of that it runs great with no stumble
PEN25 is offline   Reply With Quote
Old June 24th, 2013, 02:49 PM   #2
That happens when the engine sucks extra air from some leak between the intake valve and the carburetor.
Old June 24th, 2013, 07:13 PM   #3
PEN25
interesting. ill have to rip my tank off and look again. i thought for sure i had the boots on correctly. could it be i got one of the vacuum lines on wrong?
Old June 25th, 2013, 05:44 AM   #4
Yes, it could be a crack on a vacuum hose.
Spray some carburetor cleaner over the area while the engine is idling.
Any change in rpms' should indicate where the leak is at.
Old June 26th, 2013, 05:52 PM   #5
notsofast
Motorcycle(s): 2005 Ninja 250
Could you elaborate a bit for me? I am having this problem as well, almost to the "T" in fact. At least she runs now!
Thanks!!
notsofast is offline   Reply With Quote
Old June 27th, 2013, 04:28 AM   #6
When the intake valves open, the piston is going down, creating vacuum to suck a mix of air and gasoline from the carburetor.
Any leak in between will cause excess of air being introduced into the cylinder.
Old June 27th, 2013, 04:53 PM   #7
notsofast
Ah, thank you. I wonder if this may have something to do with my petcock vacuum hose...
Old June 28th, 2013, 12:55 PM   #8
notsofast
Talking
So, I discovered that my petcock vacuum fitting is loose... Meaning the little piece of brass tubing comes out pretty freely...I cannot seem to get it out of the hose (gunked up pretty bad).
Could this fitting not...fitting...properly cause the above idling issues as well?
Any tips for getting it to fit air tight again?
Thanks!!!
Fit! lol
Old June 28th, 2013, 03:41 PM   #9
Lychee
sail away
Lychee's Avatar
Yes, air can leak in around the brass. Try the carb cleaner trick at idle to see if the rpms raise. That would be a give away.
Old June 30th, 2013, 02:04 PM   #10
PEN25
fixed it. tried the carb cleaner trick and nothing changed. no loose rubbers. wasnt sure about vacuum lines on the carbs since the pictures i took some how didnt take. anyway dropped the carbs off used a youtube video http://www.youtube.com/watch?v=zgt3LQKIwVg to figure out i had frogged the first vac line that bridges the two carbs together with the larger line that goes in the center high location. after running new lines and putting them in the right spot i have great response on the throttle. thx for suggesting vac leak.
Old June 30th, 2013, 02:14 PM   #11
Thumbs up
Originally Posted by PEN25 View Post
fixed it. ......... thx for suggesting vac leak.
You are welcome
Strange high idle issue. Terraninja 1986 - 2007 Ninja 250R Tech Talk 40 April 8th, 2015 06:30 PM
Strange Idle Issue Jason5885 2008 - 2012 Ninja 250R Tech Talk 2 April 1st, 2015 08:31 AM
bike idle and throttle issue randomwalk101 2008 - 2012 Ninja 250R Tech Talk 5 January 18th, 2015 04:53 PM
Idle issue 2008 250 TS250 2008 - 2012 Ninja 250R Tech Talk 8 February 7th, 2014 09:50 PM
Idle issue djjontran 1986 - 2007 Ninja 250R Tech Talk 27 August 18th, 2013 09:00 AM
