July 8th, 2013, 08:12 PM | #1 |
King Hamfist
Join Date: Oct 2012 Motorcycle(s): 2007 Crf 150R, 2011 Hypermotard 796 Posts: 940
Post valve adjust voodoo
I'm going to lay some info out that will most likely prevent any ninjette member from buying my bike if I ever sell it but whatever.
I finally checked and adjusted the valves on my 09 250. It had just over 15000 miles and they have NEVER been serviced throughout the bike's life. Not surprisingly the exhaust valves were super tight. I believe I could barely get a .003 feeler gauge through two of them. My bike is completely stock motor wise and my gas mileage was dropping to consistent 52-51 mpg. Now that you know the history check this out. So bike starts up, I miraculously didnt screw anything up, and I go to rev it no less than 10 seconds after it starts and it didnt die under throttle. I haven't started the bike in 3 weeks and the motor was cold. Before when I would first start the bike, I needed the choke, or the bike would start and then drop to 1000rpms and die a few seconds later, also unless you had the choke wide open if you revved the bike when it would start to stall it would just instantly die. None of this happened yesterday. The other surprise is that @rojoracing53 took the bike out without letting it warm up for 3 to 4 minutes and had no fueling issues or hiccups and lower rpms and parking lot speeds and maneuvers. Normally I have to feed in a tiny bit of gas to get the bike to rev then I can open the throttle wide. This is only a serious annoyance in the morning, or when the bike is first started for the day. Like the bike will choke out 1/8th of the way through an intersection if you open up the throttle quite a bit when leaving from a stop. The bike still has that slight laggy response when you go 3/4 to full throttle right off of idle but it doesn't straight fall on its face anymore. In all honesty the bike is running better than it ever has before. Rojo even commented that its running fine. All we did was adjust the shims and do a carb sync. I'm not running different jetting nor did I shim the needles. It has been pretty damn hot here in California so maybe the heat helps with the cold starts. But the bike feels noticeably better. Perhaps from the factory the valves weren't adjusted correctly and should be set on the loose side of the spectrum. Or maybe the carbs were out of sync from tr get go. I'll do more testing but I want to thank @rojoracing53 for hooking my bike up. |
July 8th, 2013, 09:35 PM | #2 |
Fast-Guy wannabe
MOTM - Jan '13
Oh stop it.......no really keep going
July 9th, 2013, 09:49 AM | #3 |
Motorcycle Hypermiler
Join Date: Jan 2012 Motorcycle(s): 1999 & 2005 Kawasaki Ninja 250R's Posts: A lot.
Bueno!!
The first thing I did when I got my 2005 Ninja home was to adjust the valves. The PO told me that his fuel economy had been dropping into the 50mgs and the bike didn't idle smoothly. I always keep my valve lash at the maximum. After the adjustment and carb synch the bike idle smoothly and pulled better at lower rpms. The first test produced 80 mpg with all stock configuration ( except for the taller windscreen). |
July 9th, 2013, 10:10 AM | #4 |
King Hamfist
Good so it wasnt just me. I'm curious if I got the bad batch of the fleet. The bike is running great and I'm still convinced that its pulling better through the lower rev range than it ever has before.
July 9th, 2013, 10:14 AM | #5 |
MOTM - Jan '18, Sep '13
Sounds like I really need a valve adjustment then. I'm getting **** mpg on the 250R; it's been around 44mpg. Good thing I'm getting that done next weekend.
July 9th, 2013, 10:58 AM | #6 |
King Hamfist
O cool. Let me know if you notice a big difference. And my own thread jack but how does the new gen compare to your 300. I want a 300...I think
July 9th, 2013, 11:02 AM | #7 |
July 9th, 2013, 11:05 AM | #8 | |
Fast-Guy wannabe
MOTM - Jan '13
I was thinking of offering the same deal to other that I did for Cameron at price that covers my time. Coolant & and oil change with filter and valve inspection for $250. This means you would do all the work while I teach you how and make sure you don't **** anything up. Not sure how many people would go for it but Cameron seemed to have fun learning about his bike with no fear of screwing anything up. |
July 9th, 2013, 11:31 AM | #9 | |
July 9th, 2013, 11:35 AM | #10 | |
Join Date: Mar 2010 Motorcycle(s): 09' Blue Ninja 250R and 07' Honda 919 Posts: 605
You could ride to PA and show me....lol |
July 9th, 2013, 03:26 PM | #11 |
King Hamfist
$180 nice. Looks like rojo deal is getting undercut like a mofo lol. But feel free to hit us up if you ever need help and stuff like that.
July 10th, 2013, 08:54 AM | #12 |
King Hamfist
New gen is shim under bucket adjustment. So it makes for good practice for real bikes.
July 15th, 2013, 01:20 AM | #13 | |
Join Date: Jul 2012 Motorcycle(s): 2007 R6, 2015 KTM 250XC - Past: 2011 KTM 150XC, 2009 Ninja 250r, 2012 Ninja 650, 2007 CRF250R Posts: 194
Try it, you might like it. |
July 26th, 2013, 08:35 AM | #14 | |
Name: Not Applicable
Join Date: May 2013 Motorcycle(s): 2007 Blue Ninja 250 Posts: 171
300 air switching valve and purge valve (CAL) removal | joyspring | 2013 - 2017 Ninja 300 Tech Talk | 21 | February 13th, 2017 01:36 PM |
Valve adjust and carb sync... | jgcable | 1986 - 2007 Ninja 250R Tech Talk | 20 | July 14th, 2014 09:20 PM |
Valve Impossible to Adjust | n4mwd | 1986 - 2007 Ninja 250R Tech Talk | 10 | October 11th, 2011 02:35 PM |
Valve Adjust - whoa! Idle Speed? | bungie4 | 1986 - 2007 Ninja 250R Tech Talk | 23 | August 2nd, 2011 06:02 PM |
Missing Rocker arm and valve adjust screw/nut | Ragnar1x | 1986 - 2007 Ninja 250R Tech Talk | 45 | May 22nd, 2011 09:28 AM |
