Old July 12th, 2013, 06:35 PM   #1
MikeM5
Motorcycle(s): 2012 Kawasaki Ninja 250r
Exclamation Oil Change Failure. Help me fix this?
So I changed the oil today and bad things happened. Anyway, without going into too much detail, my "cover, 1st filter" (the part the oil drain plug goes in: part number 14092-0927) is cracked open and cannot hold oil. I will order a new one but my question is if I should also replace the "gasket, 1st filter cover" part number 11061-0341. I'm just not sure if that is something that can be put back after being taken out. Also, if anybody has any knowledge or advice from having a similar problem, any info would be much appreciated. Also, anybody know the torque specification for the bolts that hold on the cover? Thanks a lot. I just need to act fast and get this done. Here's a link showing these parts I'm talking about:
http://www.kawasakipartshouse.com/oe...ump-oil-filter
MikeM5 is offline   Reply With Quote
Old July 12th, 2013, 06:51 PM   #2
00NissanNinja
I hate driving...
00NissanNinja's Avatar
Motorcycle(s): 13 Triumph Street Triple R, 09 Ninja 250r (Sold 4/20/12)
87 in lb, and I would replace the gasket but that's me. Make sure you put it on the right way(the gasket that is) its not 100% symmetrical if I remember. You can clean the oil screen while you're at it too.
09 ninja 2fiddy SE Driving slow things fast
00NissanNinja is offline   Reply With Quote
Old July 12th, 2013, 06:58 PM   #3
AZninja
Motorcycle(s): 2009 Ninja 250
I recently just cracked my oil filter cover as well. I just replaced 14092 and used the o ring I got with the new filter. Just hand tighten it to be sure you don't crack it again.
AZninja is offline   Reply With Quote
Is it normal for oil to increase a bit in the crankcase after an oil change? cadd 2008 - 2012 Ninja 250R Tech Talk 10 May 15th, 2014 08:38 PM
Synthetic oil at 300 mile oil change? anacron 2013 - 2017 Ninja 300 Tech Talk 14 July 29th, 2013 04:58 PM
Oil drain plug gasket for oil change. tsdexter 2008 - 2012 Ninja 250R Tech Talk 8 July 10th, 2012 01:00 PM
change oil filter, without draining oil? peter330 2008 - 2012 Ninja 250R Tech Talk 5 May 30th, 2010 01:08 PM
How to fix an oil leak. Kolya1981 Off-Topic 4 May 5th, 2009 04:42 PM
