Old July 26th, 2013, 11:35 AM   #1
tsmith3605
Motorcycle(s): 2009 ninja 250r 2002 sv650
Valve Clearance check
I am getting ready to check the valves on my sons 2009 ninja 250r, it has 7500 miles on it now. My question is, when I have the crank at the 2T position, can I check all the intake and exhaust valves on both cylinders at that point, or must I turn the crank to position the cam lobes for the other cylinder? I know on my Suzuki sv650 I had to turn the crank to a different position for each cylinder but then that was a V-Twin. Thanks for the clarification.
tsmith3605 is offline   Reply With Quote
Old July 26th, 2013, 11:39 AM   #2
you need to measure with the cam lobes facing away from the buckets. the ninja 250 is a paralell 180d opposed crank. so i think you gotta rotate it at least a little between the two sides
just remember to put it back to tdc when you go to remove the cams
Old July 26th, 2013, 12:50 PM   #3
tsmith3605
So by facing away from the buckets, you mean they will be facing to the inside of the cylinder?
Old July 26th, 2013, 01:10 PM   #4
cam lobe facing up. away from the engine/pistons. the buckets are below the cam, on top of the valve stems.
valve clearance sharky nrk 2008 - 2012 Ninja 250R Tech Talk 8 July 18th, 2014 06:19 AM
What is the Optimal Valve Clearance? krolinked 2008 - 2012 Ninja 250R Tech Talk 2 March 15th, 2013 02:25 AM
Valve clearance check confusion... LoneRonin 2008 - 2012 Ninja 250R Tech Talk 3 June 3rd, 2011 10:04 PM
Oil Leaking after Valve Clearance Check nick2049 1986 - 2007 Ninja 250R Tech Talk 3 June 13th, 2010 09:10 AM
Valve clearance check/adjustment Apex 1986 - 2007 Ninja 250R Tech Talk 6 July 16th, 2009 06:49 PM
