Old August 16th, 2013, 11:20 PM   #1
ChickenRun
ChickenRun's Avatar
Motorcycle(s): 2010 250r SE (without stupid tribal decals)
15t Sprocket Noise
I'm planning on installing a 15t front sprocket, but I've seen some posts saying they get a "clicking" sound due to the teeth not having the chain gripping stuff the stock 14t has. Could ya'll help point me towards a 15t sprocket that wont make that noise, or what you did to eliminate the noise?
I read somewhere that some one used a 15t sprocket from a Z1000 and didn't have the noise, don't know if anyone can confirm that.
"It sounds like a lawnmower."
"Shut up no it doesn't."
ChickenRun is offline   Reply With Quote
Old August 16th, 2013, 11:24 PM   #2
fishdip
fishdip's Avatar
Motorcycle(s): 250/300
I have a larger front sprocket and don't have any sounds coming from it? Mine is just a basic one from cycle gear.
Old August 17th, 2013, 10:46 AM   #3
ans008
Motorcycle(s): 08 Ninja 250R
I've been told that a big factor is the lack of rubber damper like the stock sprocket has. That being sad, I have the JT 15t and it is much noisier than the stock one used to be. I later purchased the Motion Pro chain alignment tool (http://www.motionpro.com/motorcycle/partno/08-0048/) and discovered my chain was definitely out of line however only slightly. Alignment good now and it still makes some noise, though not nearly as much.
Edit:
Background info --
JT 15tf / 44tr
D.I.D. 520 x-ring chain
Replaced everything at same time
Shimmed cush drive as well
ans008 is offline   Reply With Quote
Old August 17th, 2013, 10:58 AM   #4
ChickenRun
ChickenRun's Avatar
You mean like you have a 16t front sprocket? I thought those wouldn't fit.
Old August 17th, 2013, 04:22 PM   #5
fishdip
fishdip's Avatar
take a little of the sprocket cover. Also I have had a 15 same cheap one from cycle gear and it was fine.
Old August 18th, 2013, 12:58 PM   #6
red5
red5's Avatar
Motorcycle(s): 09 ninja 15.256
I am running this one...
JT 15T
No louder than stock as far as I can tell.
"We're not always doing business, but we're always open."
"For me, it is far better to grasp the Universe as it really is than to persist in delusion, however satisfying and reassuring." Carl Sagan
red5 is offline   Reply With Quote
Quicky about 15t sprocket Graugaard 2008 - 2012 Ninja 250R Tech Talk 7 June 28th, 2012 03:10 AM
15t jt front sprocket and now noise? greatwhiteninja 2008 - 2012 Ninja 250R Tech Talk 25 August 30th, 2011 08:34 PM
15t Sprocket Brands lonewolf05 2008 - 2012 Ninja 250R Tech Talk 5 March 4th, 2011 09:39 PM
First ride-15t sprocket wild-bill 2008 - 2012 Ninja 250R Tech Talk 13 January 24th, 2011 08:28 AM
15t sprocket '09 250r eddiekay 2008 - 2012 Ninja 250R Tech Talk 10 February 21st, 2010 01:13 PM
