August 22nd, 2013, 03:58 PM | #1 |
WOT WOT WOT
Join Date: Jul 2013 Motorcycle(s): '12 Ninja 250R Posts: 421
In a day or two, I'll know if my bike's repairable
In the hands of myself.
I'll be receiving the kill switch (to replace the broken one) and the bar ends (to take the place of the ends that wouldn't come off my original bars because that red stuff sucks) soon. Once I throw them on, I'll tie all the freely hanging cables down and give it a good run. The last time I tried, the bike wouldn't start no matter how much I fidgeted with the old kill switch. The time prior to that, it did start. I'm just going to assume that the kill switch is really messed up and that by replacing it, I'll be able to start the bike. If someone here tells me that by uninstalling the kill switch, I should be able to start the bike, I will shed man tears because that means I've got a problem somewhere else in the bike that I don't know about. I'm a little nervous. |
August 22nd, 2013, 04:16 PM | #2 |
No electrical problem is insolvable.
Here is a hint: if it cannot be fixed with a hammer, is an electrical problem.
August 22nd, 2013, 04:23 PM | #3 | |
WOT WOT WOT
How often do crashes affect the gears itself? I'm no mechanic but I'd imagine them to be quite tightly housed in whatever they're sitting in, right? No way it could easily be lodged loose or whatever, right? |
August 22nd, 2013, 04:28 PM | #4 |
Your assumption is correct, gears should be OK.
August 22nd, 2013, 06:26 PM | #5 |
WOT WOT WOT
August 23rd, 2013, 07:06 AM | #6 | |
Join Date: Aug 2011 Motorcycle(s): Black '09 Kawasaki Ninja 250 Posts: 51
It usually happens if its laid down on the shifter side. The fall can transmit enough force through the shift lever I assume to cause them to misalign or break. This is a dog |
August 23rd, 2013, 07:17 AM | #7 | ||
August 23rd, 2013, 08:10 AM | #8 |
WOT WOT WOT
August 23rd, 2013, 09:47 AM | #9 |
Join Date: May 2013 Motorcycle(s): 2003 Kawasaki Ninja 250 Posts: 154
Have you tested the kill switch assembly with a multimeter? I would assume the shop manual describes what you should be able to measure across the terminals.
You could probably figure out how to bridge the pins in the wiring harness to mimic the kill switch functioning properly if you just need to be able to test the starter or something. I doubt it's a terribly complex circuit. |
August 23rd, 2013, 01:44 PM | #10 | |
WOT WOT WOT
August 26th, 2013, 10:28 AM | #11 |
WOT WOT WOT
Kill switch assembly came
I had a bit of trouble getting the left hand grip off so I forced it off and had to order new ones.
They came with bar ends. 'Course the screws didn't fit and there's no way in hell I'm using the screws that came off the old bar ends so that's another issue on its own. Anyways, I tied down all the free cables and basically road the bike. Several issues: -Burning plastic smell: Determined to be a portion of the inside padding of the side fairing that got scraped against the header. -Odd throttle: Determined to be an incorrectly installed throttle/ kill switch assembly, the cables are getting caught on something and it's not releasing the throttle as quickly as it should -Lots of vibrating: Either the bike's not aligned (more on this later) or the lack of bar ends (tested the bike without the ends) and new grips. -Alignment: Looking down the forks, they're not bent. But I've heard its common that the triple tree and whatever gets misaligned when people dump their bikes and right now, it's visibly off by probably a 1/2 cm to 1 cm. Any help on this? Also, mods, can this be moved to the '08 tech section. I realized it's more techy than casual talking? Thanks. |
August 26th, 2013, 11:41 AM | #12 | |
August 26th, 2013, 01:43 PM | #13 | |
WOT WOT WOT
Only concern is the lack of a center stand for the new gen. Also, what's that whole bounce it against a tree thing other forums are talking about? EDIT: also who ever moved my topic, thank you very much. I'v also decided to reinstall my stock pipe. It felt incredibly lean when I ran it today. I don't know if it's because the header is slightly dented or if that's just how it has always been and I've lost touch of that familiarity within the three weeks I haven't ridden the bike. |
August 26th, 2013, 04:52 PM | #14 | |
You can use a rear stand and then support the bottom of the engine using some pieces of wood and a lift. Yes, the bouncing against the tree is to twist the upper and lower triples back radially in the hope of re-establishing the alignment of the four eyes of the trees (so both tubes become parallel again. Releasing the pressure of the eye bolts (clamps) allows the tubes to rotate respect to the trees during alignment adjustment. The grosser bouncing against the tree field-method hopes for the tubes to rotate a little under the pressure of the clamps.
August 26th, 2013, 06:22 PM | #15 | |
WOT WOT WOT
Also the idea of lifting the bike, even slightly, using the engine makes me super nervous. |
August 27th, 2013, 05:43 AM | #16 |
Join Date: Aug 2013 Motorcycle(s): 2010 Kawsaki Ninja 250 Posts: 7
the easiest way ive found to replace a front end (forks, triple trees, stem) is to position a 6'-10' ladder (one that forms an "A" shape) over the tank (remove it to ensure you dont dent or scratch it), connect a tie down strap to either side of the frame an to the top of the ladder in a manner that allows you to use the ratcheting mechanism on the strap to lift your entire bike up off the ground. use a rearstand if you have one for extra stability. now you can loosen bolts on your triple trees, realign your forks, swap the entire front end, replace head bearings, or do what ever you need to do without fear of knocking your bike off of a pile of crap you haphazardly propped it up on.
August 27th, 2013, 05:45 AM | #17 | |
The other option is to remove the tank and hang the bike by the frame, if you have some strong structure above the bike. A front lift that hooks the tube of the steering column is another option. If the twisting is not severe, you could try doing it on both wheels, releasing only the upper or the lower clamps of the trees, so both threes don't slide down the forks under the weight of the bike. Something important: mark or measure the height of the forks respect to the trees because that affects steering handling if changed.
August 27th, 2013, 05:49 AM | #18 |
August 27th, 2013, 12:55 PM | #19 | ||
WOT WOT WOT
Quite an elaborate echo, if anything. Lol. But it's well appreciated. |
August 29th, 2013, 05:36 PM | #20 | |
Home made stand made from 1" black pipe
September 1st, 2013, 08:42 PM | #21 |
WOT WOT WOT
Hey, I'm back.
@Motofool I'm keeping that page in mind for when I decide to move but I have a garage and I was thinking of using the rafters. (I have a feeling someone mentioned it in on here) EDIT: But no, seriously, that's a really cool setup. Would make me look like a real gear monkey but for now, it seems like this thread: http://www.garagejournal.com/forum/a...p/t-58245.html is enough to persuade me my rafters can handle the load if the weight's distributed evenly. Heck, the rafter's already slightly exposed so I might punch several holes through the ceiling to get the straps around the rafter. Anyways, I've given the bike a few runs since this thread started. The slight offset is unnoticeable but I'd still like to get it taken care of. Also, I've decided to keep the gas tank and try to pop out the two major dents on it as best as I can. The other dents that aren't so popable are located on portions where the side fairings cover it. I'm thinking the only reason I'd have an issue is if the inside had some sort of rust preventing coating of some sort that may have been compromised because of these dents. |
September 1st, 2013, 09:37 PM | #22 |
September 2nd, 2013, 07:40 AM | #23 |
WOT WOT WOT
Oh dang I was hoping you'd say something like, "Yeah, the dents didn't compromise anything inside the tank" or "Noooo don't do it, its already prone to rusting now"
September 2nd, 2013, 07:55 AM | #24 |
The dents don't compromise anything inside the tank.
Just calm down and ride on, a dented tank never stopped any bike.
September 3rd, 2013, 02:04 PM | #25 | |
WOT WOT WOT
My fairing stay is still back ordered. I should've just bought OEM from the manufacturer. I got an aftermarket piece that the stealership ordered which was put in the system on the 13th. Supposedly I'm now going to get on Sept. 25th. What is that ****. I can't mount my headlights or instrument cluster. |
September 3rd, 2013, 04:47 PM | #26 |
Bummer !!!
September 4th, 2013, 07:39 PM | #27 |
WOT WOT WOT
oemninjaparts saved my butt, getting my bracket in two or three days
Also, lol @ HD riders waving to me while my front end's off then probably regretting it after looking back and seeing a sportbike tail. |
September 4th, 2013, 07:53 PM | #28 |
You have achieved two extraordinary things !!!
Bought first bike and 1 day later it won't start: do I have a junk bike? | brendandubs | 1986 - 2007 Ninja 250R Tech Talk | 43 | May 11th, 2014 07:59 AM |
WTB repairable pregen EX250F lower fairing in ATL area (or DIRT cheap shipped) | CZroe | Items Wanted | 0 | October 13th, 2012 03:55 PM |
