August 23rd, 2013, 05:19 PM | #1 |
Join Date: Jan 2013 Motorcycle(s): 2007 Ninja 250 Posts: 22
Broke key in gas tank
The kicker is I knew the old key was getting weak and had a replacement made at a locksmith, but the new key only worked in the gas tank and not the ignition and once I discovered this I never took the time to go back and address it.
1) The old key is turned half-way in. This seems to prevent me from being able to yank it out with tweezers/duct tape. Assuming I cannot grab hold of the broken part of the key (it's flush/flat with the surrounding area preventing me from grabbing it), do I need to have the key turned back to default before attempting to remove it? To clarify: After you put the key in the tank you rotate it 90 degrees to make it open. My old key is broken off in there, turned at a 45 degree angle. 2) What's the best way to remove a broken key? 3) Can a locksmith craft a new key from 2 broken pieces? Thanks in advance. My bike is stuck at the gas station where the key broke in it so timely answers are definitely appreciated. |
August 23rd, 2013, 06:33 PM | #2 |
Find a way to haul the bike back home; you cannot make it work tonight.
..........Don't try a screwdriver in the ignition switch, it just doesn't work.
August 23rd, 2013, 08:47 PM | #3 |
Ok an update:
My brother was able to successfully remove the broken key. While sitting at the gas station he looked at my replica key and determined it was incrementally taller than the original so he took a metal file to it to slim away a millimeter of metal, thinking the replica wasn't engaging the tumblers successfully because of the height difference. It didn't work. Same problem, replica key goes in but doesn't turn. So at this point I have the key out and no key that works and I'm afraid to go to the locksmith without getting the bike towed :/ I'm afraid the locksmith well look at the replica and say "it looks just fine" and without the actual bike be unable to do anything. Ugh. |
August 23rd, 2013, 09:14 PM | #4 | |
Join Date: Aug 2013 Motorcycle(s): 2008 Ninja 250 Posts: 52
I'm sure they'll be happy to do the same for you, well at least make another from a blank. I'm not sure if I'd use your beat up original, or a key code, but my policy is to leave originals collecting dust. |
August 23rd, 2013, 09:27 PM | #5 |
I'm dreading having to get it towed to the locksmith. Something tells me they're going to need to test a bunch of times on it.
August 23rd, 2013, 09:33 PM | #6 |
Join Date: Oct 2012 Motorcycle(s): 2002 Ninja 250 Posts: 213
a good locksmith can make a working key without having one to copy.
August 23rd, 2013, 09:42 PM | #7 |
August 23rd, 2013, 10:40 PM | #8 | |
Hopefully someone who knows more will pitch in =p. I'd look for that code though. |
August 24th, 2013, 07:12 AM | #9 | |
And idk if you need that information but from my understanding they measure the pins inside and can make a key from the measurements. Which I would imagine would me more expensive and time consuming that just having a copy made.....which you already did. Call the original locksmith. |
August 24th, 2013, 11:07 AM | #10 | |
http://faq.ninja250.org/wiki/What_do..._about_keys%3F Best !!!
August 25th, 2013, 09:10 AM | #11 |
Some important info:
When a locksmith makes a duplicate of a key the machine cuts the new key to the exact same profile as the original key. If the original is worn out then the dupe will be worn out also. That's why it's so important to keep an original unworn/unused key and use it to make duplicates. The pregen gas tank lock only has five wafers compared to the six in the seat and helmet locks and the ignition switch. For a key to work properly the key insertion depth has to be precisely controlled. Because the tank lock only uses the five key lands closest to the tip of the key the tank lock insertion depth is based on a stop in the bottom of the lock. The other lock cylinders use the shoulder on the key up by the head to set insertion depth. This means that the key not only has to be the proper length with the proper lands, but the distance from the shoulder to the tip has to be exact. If it's not, then you wind up with a key that will either work everything but the tank, or a key that only works in the tank lock. Here is more info on this: http://faq.ninja250.org/wiki/EX250F_key_blanks All of the locks on the pregen except for the ignition are ridiculously easy to rekey, FWIW, and they're also extremely easy to pick. If you can get the locksmith the helmet or seat lock they can make you a new key pretty easily. They can also do it from the tank lock but there's some trial and error as they will cut the first five lands to work the tank, then cut the last land one step at a time until it works in the other locks as well. Once you get into your tank you need to remove the filler cap and dismantle it for cleaning. The tank lock should be easy to turn. |
WTB: Ignition, key, gas tank, etc | MrSavvy | Items Wanted | 2 | June 2nd, 2014 12:51 PM |
Can't insert key all the way down into gas cap | chsonnu | 2008 - 2012 Ninja 250R Tech Talk | 5 | August 9th, 2013 05:34 PM |
Broke down in the rain. Out of gas?! | CZroe | 2008 - 2012 Ninja 250R Tech Talk | 6 | March 1st, 2010 05:24 PM |
