Old August 30th, 2013, 05:50 PM   #1
[motorcyclistonline] - Chain Maintenance and Test Rides | Hot Links
The heat in a warm chain helps the lubricant penetrate the space between the chain’s rollers and bushings, and spread over the O-rings to keep them from drying out and breaking.Q: Good stuff on chain maintenance in the June issue (“Drive Time”), except that I was always taught to “lube hot, adjust cold.” If you adjust the chain when you lube it, and you should lube it while it’s still warm, the adjustment will be too tight when the chain cools. Is that still a valid strategy?
Frank Wissler
Spring Branch, TX
a
Photo Gallery: Chain Maintenance and Test Rides - Motorcyclist
Chain Maintenance and Test Rides | Hot Links | Digg It | Add to del.icio.us
Click here for full story...
Chain maintenance fail cuong-nutz Videos 37 May 12th, 2014 11:37 AM
[visordown.com] - Why chain maintenance is important Ninjette Newsbot Motorcycling News 0 April 23rd, 2014 04:22 AM
Chain Maintenance Question dcj13 General Motorcycling Discussion 10 January 27th, 2014 04:08 PM
[motorcyclistonline] - Drive Chain Maintenance | Drive Time Ninjette Newsbot Motorcycling News 0 May 9th, 2013 05:30 PM
Chain maintenance Highalltheway 2008 - 2012 Ninja 250R Tech Talk 5 August 30th, 2011 09:17 PM
Except where otherwise noted, all site contents are Copyright 2022 ninjette.org, All rights reserved.
