Old March 9th, 2009, 02:46 PM   #1
hogfan83
hogfan83's Avatar
What order do these spools go in?
im not sure which order or direction to put these spools on as i have never seen them on a bike up close.....
2009 Kawasaki Ninja 250R Special Edition
hogfan83 is offline   Reply With Quote
Old March 9th, 2009, 02:56 PM   #2
HKr1
IC2(SW)
HKr1's Avatar
I would guess that the small piece goes between the swing arm and slider.
They look nice, what kinda are they?
Old March 9th, 2009, 03:02 PM   #3
hogfan83
hogfan83's Avatar
steel horse fabrications.
niether side fits well with the spacer, and i dont understand why the spacer is shaped the way it is
Old March 9th, 2009, 03:08 PM   #4
HKr1
IC2(SW)
HKr1's Avatar
I know just the spool wouldnt sit flush..... maybe smaller cone side towards swing arm??? Guessing you have tried every way, didnt have any instructions?
Old March 9th, 2009, 03:12 PM   #5
that would be my guess.
Old March 9th, 2009, 03:12 PM   #6
HKr1
IC2(SW)
HKr1's Avatar
Theres allot of guessing going on
Old March 9th, 2009, 03:14 PM   #7
hey, he's the one that asked for help!!
Old March 9th, 2009, 03:18 PM   #8
hogfan83
hogfan83's Avatar
thats what i guessed too but i wanted to make sure...heres a picture from below the swingarm with everything hand tightened
Old March 9th, 2009, 03:19 PM   #9
HKr1
IC2(SW)
HKr1's Avatar
^ Looks good
Old March 9th, 2009, 03:25 PM   #10
yep, I'm guessing that's correct.
Old March 9th, 2009, 04:15 PM   #11
hogfan83
hogfan83's Avatar
thanks for the guesses guys...
Old March 9th, 2009, 11:22 PM   #12
Sound Wave
Ramen Rider
Sound Wave's Avatar
i have a shogun swing arm spool and yeah, that is pretty much the way it goes. the fat side towards the spool and the skinny side towards the swing arm.
Old March 9th, 2009, 11:51 PM   #13
watcanido
watcanido's Avatar
Yah that's my setup as well. I made my rear spools a little loose so it can spin while I set it up on the rear stand. I find it helps in lifting, what did you guys do? tight or loose?
watcanido is offline   Reply With Quote
Old March 9th, 2009, 11:52 PM   #14
tight. I'd be concerned that they would vibrate loose.
Old March 10th, 2009, 09:47 AM   #15
00v_Lucky
00v_Lucky's Avatar
Motorcycle(s): '09 Candy Thunder Blue Ninja 250R
posting here because not worth a new thread.
i remember some one buying the t rex spools. would those fit with the northern tool stand? I previously bought the 6.50 spools on ebay, and those are too short to be caught on the stand hooks ( i do not want to make that same mistake again) Do you guys think this would be any longer?
http://cgi.ebay.com/ebaymotors/T-Rex...Q5fAccessories
00v_Lucky is offline   Reply With Quote
Old March 10th, 2009, 10:17 AM   #16
RaceBikeRentals
Pimpin
RaceBikeRentals's Avatar
Motorcycle(s): Bunch of em
I'm using TRex spools and the Northern Tools stand. The stand is adjustable width, so no problems.
-Richard
MotoList.com <<<List your stuff!
RaceBikeRentals is offline   Reply With Quote
Old March 10th, 2009, 10:28 AM   #17
00v_Lucky
00v_Lucky's Avatar
ty, i feel secure in this purchase now, thx. Also, how did you permanently hold the hooks onto the stand? if you used epoxy, how did you make sure that the hooks were properly straight and aligned?
Old March 10th, 2009, 10:33 AM   #18
RaceBikeRentals
Pimpin
2 part epoxy from HD. Make sure you get the one specified for metal. Just goop the stuff around the perimeter of the top cap and place it in the holes. Hold for a minute or so while it gels up and wipe off the excess. Good to go.
-Richard
Old March 18th, 2009, 11:21 PM   #19
paterick4o8
paterick4o8's Avatar
Motorcycle(s): '08 blue 250R [sold]. '09 lime ZX-6R [stolen :( ]. '06 blue 636.
I have the same ones (shogun) as hogfan83.
I put the skinny side toward the swing arm.
BTW, not sure if they were just on too tight or if the screw just of poor quality, but in my low side, this broke right off and the left over piece of screw is stuck inside the hole in my swing arm now
paterick4o8 is offline   Reply With Quote
Old March 19th, 2009, 09:12 AM   #20
hogfan83
hogfan83's Avatar
thats not good! i put locktite around mine so if that happens im pretty much screwed
Old March 19th, 2009, 10:19 AM   #21
use the appropriate sized screw extractor and remove it.
Old March 19th, 2009, 01:01 PM   #22
paterick4o8
Thanks Kelly, will do
Old May 20th, 2009, 01:08 PM   #23
Tubesock
Tubesock's Avatar
Motorcycle(s): 2009 Kawasaki Ninja 250r
I'm putting this here because I figured it kinda goes with the topic, What size spools does the 09 250r take? I have some 10mm but they seem way too big, I tried screwing them in and it was a no go.
"When I die I want mud on my jump boots, magazine empty, and barrel hot."
Tubesock is offline   Reply With Quote
Old May 20th, 2009, 01:41 PM   #24
The 250r does in fact take 10mm spools. That 10mm refers to the bolt itself, but there are many different sized spools that all have a 10mm bolt. Do your spools fit into the hole but they just don't look right or sit right against the swingarm?
Old May 20th, 2009, 01:49 PM   #25
Tubesock
Tubesock's Avatar
I can get the very tip in then if I try to screw it in more it won't go. I used an allen wrench to try and get it further in but it wouldn't move all the way in.
Old May 20th, 2009, 02:14 PM   #26
Make sure that the spools really are 10mm and not 12mm, and then check to see if the threads on either the spools themselves or the spool boss on the swingarm are buggered up. Definitely don't force anything, if it doesn't fit easily something is wrong.
Old May 20th, 2009, 02:16 PM   #27
Tubesock
Tubesock's Avatar
Yea thats what I thought I've checked the box and when I went to get them the guy let me make sure theyd fit mine by screwing them on another 09 ninja 250r.
Old May 20th, 2009, 02:22 PM   #28
those spool hole threads are normally filled with paint which makes screwing in the spools a bit more difficult. make sure it's clean and try using a regular hex head bolt in there first to clean out the paint from the threads.
as Alex said, don't force anything. some wd40 might help clean/lube the threads when screwing it in.
Old May 20th, 2009, 02:47 PM   #29
Tubesock
Tubesock's Avatar
Paint wouldnt make it so hard that when I try to tighten them the bike shakes would it?
Old May 20th, 2009, 03:15 PM   #30
what do you mean shakes?
Old May 20th, 2009, 03:30 PM   #31
FroggyGreenInSD
FroggyGreenInSD's Avatar
Motorcycle(s): 08 Green 250, 12 Ninja 650 (also green, it's the fastest color!)
One other thing to check is the thread pitch. My spools came with 10mm bolts, but the thread pitch was 1.5 which does not match the mount on the swing arm. As a result they wouldn't go in. When I got a bolt with 1.25 thread pitch it went in smooth as silk. If you want to test the thread pitch of your bolt, you can take the rubber plug off one of the mirror mounting holes on the clutch lever perch or front brake perch. They are M10x1.25 with no paint on the threads. If you cant put the bolt in there it is definitely the wrong size.
Last futzed with by FroggyGreenInSD; May 20th, 2009 at 03:33 PM. Reason: Add info on how to check thread pitch of your bolt
FroggyGreenInSD is offline   Reply With Quote
Old May 20th, 2009, 03:35 PM   #32
true, but we already know the spool bolts he has fits the holes that are threaded in the swingarm for the spools.
Is that correct, Tubesock?
Old May 20th, 2009, 04:52 PM   #33
Tubesock
Tubesock's Avatar
That is correct, and what I mean't by the bike shakes (shakes was probably a poor choice of words) I mean it wobbles and moves as I tried to screw it down and about that time I decided it shouldn't be this hard and I should ask for help (which I got from you guys). But anyway I went to a friend of mine who I wrestled with in high school who's father owns and operates his motorcycle repair shop, I went in and asked for help and he said it actually was all a product of the paint! He took a threader to it, cleaned the paint out and it went in just fine after that.
Old May 20th, 2009, 05:50 PM   #34
Old May 20th, 2009, 06:13 PM   #35
Bsmith
Bsmith's Avatar
Motorcycle(s): '08 Ninja 250 R.I.P.
Yeah I ended up having to buy a set of tap and dies for just that purpose You can never have too many tools.
Bsmith is offline   Reply With Quote
Old May 20th, 2009, 07:00 PM   #36
Tubesock
Tubesock's Avatar
Just like Clint Eastwood said "A man acquires all these tools over a lifetime."
Old May 20th, 2009, 07:03 PM   #37
Glad you got it in.
Old May 30th, 2009, 06:57 AM   #38
Frog
Kawasaki Green Swingarm Spools
Has anybody come across Kawasaki Green Swingarm Spools? I would like to use them with a Pit Bull stand.
Frog is offline   Reply With Quote
Old May 30th, 2009, 07:11 AM   #39
Banzai
Psychic war veteran
Banzai's Avatar
You know, it would have been so much easier if Kawi had just weleded the spool bosses flush with the OUTSIDE of the swingarm instead flush with the INSIDE. Would really have opened up the aftermarket without the need for some silly little cone thingy!
To the OP, glad you got it figured out.
Old June 1st, 2009, 08:26 PM   #40
tiburonsita
tiburonsita's Avatar
Motorcycle(s): 2009 black Ninja 250R
I was able to find the one I needed at Ace Warehouse by itself for $5 instead of the $50 kit at Home Depot. I was ready to just return the 2nd set of spools/slider and get a different stand that didn't require them. Glad I gave it a try. Was a lot easier to do than I had expected.
You have them on right Michael - I have the same set.
tiburonsita is offline   Reply With Quote
spools? 2k1013r General Motorcycling Discussion 3 March 10th, 2014 04:37 PM
My $3 Homemade Spools slowninja 2008 - 2012 Ninja 250R Tech Talk 17 November 25th, 2012 12:51 PM
Shogun Spools...? clintalmighty 2008 - 2012 Ninja 250R Tech Talk 11 July 12th, 2011 10:59 AM
Needles and Spools csmith12 1986 - 2007 Ninja 250R Tech Talk 3 June 13th, 2011 02:05 PM
t-rex spools tinng321 2008 - 2012 Ninja 250R Farkles 9 June 9th, 2009 08:13 PM
