September 10th, 2013, 11:51 AM | #1 |
Join Date: Jun 2013 Motorcycle(s): 08 Plasma Blue 250 Posts: 56
NGK CR8EIX spark plugs. Do they come pre-gapped?
I read that they come pre-gapped and you can just stick them in.
Is that true? Just wanted to check with you guys first. |
September 10th, 2013, 11:55 AM | #2 |
Join Date: Jan 2013 Motorcycle(s): 08 Ninja 250 Posts: 108
I always check the gap. The last set of spark plugs I changed on a motor, they came from 2 different boxes (6 cyl engine and box has 4 plugs) and the different boxes had a different gap.
September 10th, 2013, 12:23 PM | #3 |
The last 4 I bought came pre-gapped within the required Kawi specs. I checked them to make sure. The tips are thin and i didn't want to take the chance trying to gap them.
September 10th, 2013, 04:45 PM | #4 |
Join Date: Jul 2011 Motorcycle(s): 2012 Ninja 250, 2006 Ninja ZX6R-636 Posts: 661
Have only purchased 2 CR8EIX so far and on checking the gap I found them to be spot on.
September 10th, 2013, 05:53 PM | #5 |
Fix It Till Ya Break It
Join Date: Oct 2011 Motorcycle(s): 08 250RRrrrr Posts: 623
The ones I bought here in Canada were pre-gapped in MM. You will need to covert the ones you buy in the states to inches.
September 10th, 2013, 09:58 PM | #6 |
Join Date: Jul 2012 Motorcycle(s): 2010 Ninja 250 2009 Ninja 250 Posts: 730
Also make sure you have 1 left and 1 right spark plug.
The Canadian ones are reversed threaded....
2010 Red Ninja 250 2009 Black Ninja 250 -If you ride like lightning,you're gonna crash like thunder- |
September 13th, 2013, 10:23 AM | #7 |
Join Date: Jun 2013 Motorcycle(s): 2010 Kawasaki Ninja 250R (Passion Red, Ca Model) Posts: 107
I just pulled mine out to inspect them, they still look good 5,XXX miles later..
Getting CR8EIX Spark plugs to fit? | Runeknight95 | 2008 - 2012 Ninja 250R Tech Talk | 8 | July 26th, 2013 10:53 PM |
cr8eix spark plugs | WhiteRice | 2008 - 2012 Ninja 250R Tech Talk | 9 | November 17th, 2011 06:06 AM |
[roadracingworld.com] - More Senior Staff Changes At NGK Spark Plugs (USA), Inc. | Ninjette Newsbot | Motorcycling News | 0 | September 8th, 2009 09:20 AM |
[roadracingworld.com] - New President For NGK Spark Plugs Canada Ltd. | Ninjette Newsbot | Motorcycling News | 0 | August 28th, 2009 07:40 AM |
[roadracingworld.com] - New President For NGK Spark Plugs (U.S.A.), Inc. | Ninjette Newsbot | Motorcycling News | 0 | August 18th, 2009 10:00 AM |
