September 10th, 2013, 08:13 PM | #1 |
Join Date: Feb 2013 Motorcycle(s): 2006 Kawasaki Ninja 250R Posts: 18
Camshaft chain removal
So my '06 Ninja 250 has 30K miles and is making a rattling noise, more noticeable at idle than at acceleration or driving. I took it to two different shops, and both confirmed that the chain needs to be replaced... I plan to do it myself, though it's my first time (I do have a very good knowledge of how things work, taking them apart, and putting things back together). However, I would like to know if I need any special tools other than the regular handy ones you would find in any mechanics garage, and also what parts I need to remove... Obviously the camshafts must come off prior to removing the chain, am I correct? Suggestions and advice on this from people with first hand experience on this job is appreciated. Thank you.
September 10th, 2013, 08:26 PM | #2 |
First, you should measure the elongation of the chain by yourself.
At 30K miles, it should be OK still. Please, read this old thread: http://www.ninjette.org/forums/showt...443#post592443
September 12th, 2013, 09:34 PM | #3 |
Yup, every 10-link lengths I've been measuring are over 2.5in, which equals to 5in for 20-links, and service limit is 128.9mm (5in=128mm). So it's confirmed, the camshaft chain needs to be replaced...
September 13th, 2013, 06:04 AM | #4 | |
http://www.ninjette.org/forums/showthread.php?t=104334
September 19th, 2013, 05:11 PM | #5 |
I just want to know, am I going to have to split the crankcase for sure? Cause there seems to be no way for the chain to come out, due to that little safety guide that is right below the crankshaft gear.
September 19th, 2013, 05:27 PM | #6 |
I saw a method posted a while back where a dude on youtube changed his dirtbike cam chain without cracking the case.
he cut the chain, tacked the new on onto the end of the old one, pulled the old on through while rotating the engine by hand, then just cut the old chain off the new one once the new one was threaded through there. Then check the timing and voila! I'd probably crack the case instead though... |
September 19th, 2013, 06:17 PM | #7 |
Yeah I haven't seen the video but I know which you refer to.. I know some basics about welding, done a little bit of work, but I don't feel comfortably doing that to the bike. This will be my first time splitting it, is there anything special I need to know? Like gaskets, parts or springs that might come out? I already took off the whole top end minus rocker arms and valves, and removed the clutch.
September 24th, 2013, 12:23 PM | #8 |
Progress Update
Fortunately, I didn't have to split the crankcase. I was able to get a grinder with a small plate that fitted in the small space and grinded down that little guide that goes around the gear on the crankshaft. Now all that's left is getting that darn timing right haha.
September 24th, 2013, 07:19 PM | #9 |
Join Date: Apr 2013 Motorcycle(s): 2004 Ninja 250 Posts: 465
Is that little guide that you grinded down inside the engine?
September 24th, 2013, 10:17 PM | #10 |
Yes that's correct, I grinded the guide down inside the engine to give me clearance to take the chain off and put it back together.
P.S. I have installed everything back, it won't turn on... It cranks, but it seems as if the piston is hitting the valve... When setting the chain for the timing, was the cylinder #2 the one that was supposed to be TDC?? Or was it #1? My service manual says #2... And that the EX mark on the exhaust sprocket is supposed to be lined up with the gasket, while the IN mark on the inlet sprocket is supposed to be lined up with the gasket as well. Also, when counting the pins in between the marks with chain tensioner installed, it's supposed to be 33. I'm wondering if my service manual might have possible made a typo?? Please clear up any confusion about this if possible. Thanks. |
September 25th, 2013, 08:44 AM | #11 | |
http://www.ninjette.org/forums/showp...01&postcount=4 Cilinder #1 is the left one when sitting in the sadle. When mark 2T shows up through the visor, the lubes of the cams should not be pressing on any of the valves of cylinder 2. Note that there are two top positions of the piston (two turns of the crankshaft) for each turn of the cam shaft.
September 28th, 2013, 06:57 AM | #12 |
Join Date: Aug 2012 Motorcycle(s): Ninja 250 2001 Posts: A lot.
Can you post pics or video?
Just to cover the basics you did turn fuel on and connect all your vacuum lines correct? If you installed your throttle cable too tight the bike won't start. Have you tried bump starting it I've found that to override some minor starting issues so that at least you know your timing is right...
Mods: Offset clutch pressure plate |
October 14th, 2013, 03:00 PM | #13 |
Update
Finally got the bike running. Sounds beautiful, no more rattling, runs great
October 14th, 2013, 03:07 PM | #14 |
October 14th, 2013, 03:55 PM | #15 |
thats an interesting idea cutting off the bottom chain guide. just make sure it never gets loose enough to skip a tooth down there.
October 14th, 2013, 05:39 PM | #16 |
Yes, the satisfaction of knowing it's running good
October 24th, 2013, 06:13 PM | #17 |
I just found this thread. Interesting. I have never heard of grinding the lower chain guard down, but as long as there is still enough of it left to keep the chain from hopping a tooth, then it should work OK.
Most of the time when people with a pregen complain about a ticking or rattling sound at idle that goes away under load, its nearly always the clutch basket. A timing chain does not feel torque with the engine and only feels speed. So the faster the engine, the more it flaps. Load makes no difference. The pregen clutch basket has a design flaw that makes it rattle at idle. By applying a light load with the front brake, you can make this type of rattle go away. Every pregen I have ever seen in person has had a clutch basket rattle. Unfortunately, there is no real solution. In theory, it might be possible to use a newgen clutch basket, but I've never confirmed that.
Camshaft Chain Tensioner | gxmcdg | 2008 - 2012 Ninja 250R Tech Talk | 16 | October 27th, 2014 07:55 PM |
Camshaft Chain Inspection | indr | 2008 - 2012 Ninja 250R Tech Talk | 18 | February 2nd, 2013 08:29 PM |
Airbox removal + Kleen air removal? | MikeBudd | 2008 - 2012 Ninja 250R Tech Talk | 6 | February 16th, 2012 04:57 PM |
Camshaft Chain tensioner mounting bolts | cerberusrex25 | 1986 - 2007 Ninja 250R Tech Talk | 7 | June 19th, 2011 10:03 AM |
