September 16th, 2013, 05:17 AM | #1 |
heat gun glue
So i decided to peel off the decals on my bike with a heat gun this weekend. It was going well up until some of the glue wouldnt peel off on both sides. Can anyone recommend a good cleaner or advice on how to take off the dry glue?
September 16th, 2013, 06:49 AM | #2 |
Sometimes the glue will come off with tape. Take a piece of 2" masking tape, and push it down on the glue firmly, then pull it up quickly. Also try a wiping motion. If that doesn't do it try duct tape. A poor quality duct tape may leave more glue than it picks up.
After that I'd try WD-40 to soften the glue. Don't use anything harsh like brake cleaner. If WD won't take it off you can try a commercial remover like OOPS or similar. Most likely it will be fine, but test it in a safe place before rubbing it all over the paint. |
September 16th, 2013, 10:26 AM | #3 |
sail away
Join Date: Jul 2012 Motorcycle(s): gixxer (sold), ninjette (upgrade!) Posts: 964
Have you tried plexus?
Unregistered found this post helpful. Track Day Preparation Checklist 1. Financial 2. Mental 3. Physical 4. Gear / Bike |
September 16th, 2013, 07:19 PM | #4 |
Thanks for thr advice guys but i used a combination of adhesive spray and goop off and with a good amount of rubbing all the glue pretty much came off. Only problem now is you could still see the kawasiki letters on the side and the areas where the stickers were. I heard sanding and then buffing would blend the colors well, but dors anyone else have any advice?
September 16th, 2013, 07:28 PM | #5 |
Join Date: May 2013 Motorcycle(s): '75 CB550:.'82 XV920:.'00 KLR650:.'00 EX250:.'08 Ninja 250 Posts: A lot.
MOTM - June '15
Don't sand it, just use polishing compound
'82 XV920: Soon to be tracker--'00 KLR685:adv --'04 DRZ400E--'12 Super Tenere --'13 Versys Ride more, worry less. |
September 16th, 2013, 07:32 PM | #6 |
Wait, you removed the Kawasaki letters on the tank? I thought they were under the clearcoat?
September 16th, 2013, 07:37 PM | #7 |
Join Date: Apr 2013 Motorcycle(s): 2004 Ninja 250 Posts: 465
The reason you can still see the lettering is because adhesive that was left behind, trapped dirt in the same formation as the letters were.
September 17th, 2013, 06:10 AM | #8 |
The area under the sticker was protected from normal wear-and-tear, so it's still like new.
Use the most gentle compound to get the job done - don't sand it. Try using regular car wax and some pressure first. If that doesn't do it try some "swirl remover" or "glaze". Rubbing Compounds and even Polishing Compounds that you find in most regular stores are WAY too coarse, and can do more damage than good. |
September 17th, 2013, 08:08 AM | #9 |
Thanks ill try waxing it this weekend. And, no not from the tank, i removed the stickers on the fairings.
Glue on Helmet? | Daks | Motorcycle Gear | 7 | November 17th, 2012 06:03 PM |
[webbikeworld.com] - Steinel Heat Gun Review | Ninjette Newsbot | Motorcycling News | 0 | June 1st, 2011 07:30 AM |
type of glue to use | wayanlam | 2008 - 2012 Ninja 250R Tech Talk | 5 | April 30th, 2011 09:33 AM |
Visor / Face Shield cleaning and repair..Any ever use a heat gun? | edwinmcq | General Motorcycling Discussion | 4 | November 9th, 2010 01:54 PM |
glue residue | bash | General Motorcycling Discussion | 17 | January 28th, 2010 02:26 PM |
