November 14th, 2015, 07:29 AM | #41 |
Join Date: Dec 2014 Motorcycle(s): Ninja 300, GSXR-750, Ducati M1100 Posts: 185
It's all pretty straightforward except for the actual arm/spring. When you go to put it on, let the arm and spring hang down while you get the bolt started to hold it in place, then push it up against the spring resistance and into position against the shifter star and finish tightening the bolt.
It's worth the hassle as I rarely miss a shift anymore, and it has stopped the transmission from slipping back a gear altogether. |
November 16th, 2015, 07:27 PM | #42 | |
November 22nd, 2015, 06:52 AM | #43 |
The installation of the factory pro detent arm and spring is mostly straight forward. You will need:
Maintenance manual Basic sockets & Hex bits Torque Wrench Breaker bar Clutch basket removal tool Clutch cover gasket Liquid Gasket Moly grease Thread Locking compound Oil I bought a Tusk brand clutch tool for like $18 from rocky mountain and ground the ends a bit thiner to better fit the Ninja's clutch basket. Drain your oil. Remove your clutch cover, taking care not to remove the clutch release rod or you will need to replace the needle bearing assembly that is in the cover. Remove your old gasket and clean mating surfaces. Remove your clutch, keeping all plates and spacers in order. Once the clutch is removed, you can tackle the detent arm and spring. The spring pressure on the detent arm is what makes this a little tricky. My recommendation is to spread apart the "shift mechanism arms" over the end of the shift drum before tackling the detent arm. This will give you more room to swap out the part. Do not unscrew the star on the end of the drum. As @GregS pointed out, once you have the new bearing in place with thread locker, do not tighten it down fully. Leave enough room to push the bearing up and in place on top of the shift star before torquing it down. Move the "shift mechanism arms" back in place and test the shifting. If everything feels good, reinstall your clutch, gasket, cover etc, as per the maintenance manual, and add your oil. Any additional feedback or tips are welcome. |
November 23rd, 2015, 10:50 AM | #44 |
Indeed - I forgot the part about spreading the shift arms and moving them out of the way, that really makes it easier to do. I made the mistake of removing the shifter star and it was a major PITA to get back on and positioned properly.
Last futzed with by GregS; November 26th, 2015 at 07:50 AM. |
April 27th, 2016, 07:36 PM | #45 |
I wanted folks to know I took the bike back on the track this past weekend and had zero shifting or false neutral issues. The kit is working well so far.
April 28th, 2016, 06:06 PM | #46 | |
April 25th, 2017, 06:10 AM | #47 | |
Join Date: Feb 2013 Motorcycle(s): '13 GSX-R600, '09 Ninja 250, 04 SV 650 (track) Posts: 157
After 2 days at the track testing this weekend, My bike was shaking violently getting on the gas coming out of the corners. We replaced fuel, coils, injectors, battery, took the pcv right out, and swapped the ecu. Got home, pulled the clutch out and saw that there is some major wear on the retaining washer that holds the "shift star" in place. When I did the install,I ended up unbolting the "shift star". I thought I had it back together properly but apparently not... |
April 27th, 2017, 05:47 AM | #48 |
this is a pic...i'm stumped
April 27th, 2017, 04:17 PM | #49 |
Must be your clutch vibrating against the shift star washer. If I remember correctly there is a cone shaped washer that goes under the clutch basket, did you put that on the right way? It's the only thing I can think of that would cause a lot of vibration.
Last futzed with by GregS; April 27th, 2017 at 04:18 PM. Reason: Picture |
July 25th, 2017, 08:32 AM | #50 |
Join Date: May 2017 Motorcycle(s): 2013 Ninja 300, 2009 GSXR 1000, 2005 American Ironhorse Legend, 1999 Honda Shadow A.C.E. Posts: 9
Just did mine last week
I got mine installed a week ago. Gregg even put a couple of my photos up on the site...LOL... It was, indeed, pretty straight forward. Having he tips about moving the arms and putting the whole thing in place before tightening up the bolt was awesome. Made the whole thing easier. For some reason, these photos are turned 90 degrees to the left. My apologies for that.
July 25th, 2017, 03:36 PM | #51 |
Good to hear that it went well for you. Anybody that is mechanically inclined can do this mod. The number one thing I would recommend is to NOT unbolt the shift star, as the darn thing gave me hell going back on right.
Let us know if the shifts improve, as you should see a pretty big difference. |
July 27th, 2017, 10:50 AM | #52 | |
January 24th, 2018, 07:44 AM | #53 |
Wow, I'm sorry all, I never did post a reply to the message a couple above this one. Greg, the spring and arm work flawlessly. After this trackday, I raced at Summit Point and VIR without one single issue. I coach also and have hundreds of laps around a couple of different tracks since the install, and not one single issue.
Thanks for a great product. Juan |
January 27th, 2018, 12:54 PM | #54 |
Join Date: Sep 2016 Motorcycle(s): '00 SV650,'02 EX250,'15 EX300 Posts: 99
Curious
In 6+ decades of bike fiddling I've known about under cutting but don't know how common it has been over the years. Any clue as to what bikes have had it or not? I've always felt Suzuki & Yamaha trannies seemed better but didn't know why they were. The occasional missed shift doesn't bother too much but unintentional downshifting is a worry for us Golden Age riders. I wonder how much $ is saved w straight milling the dogs vs a small angle. Is this a problem for Ninjettes as they may be ridden w more gusto than others? Others have asked about power shifting but I think they'd avoid such if shown the resulting dog wear & tear. Anyone heard of XS100s w/o 2nd gear?
GUZZI JOHN |
January 28th, 2018, 01:12 PM | #55 | |
January 29th, 2018, 05:46 PM | #56 |
Part update
I see there is a different part# listed for the detent now. Is this an improved piece or just a number change?
GUZZI JOHN |
October 9th, 2018, 04:54 AM | #57 |
BUMP
I am experiencing the same issue as the OP and others on my track-only 2015 300. It doesn't happen *all* the time but when it does it's fairly disconcerting. I'm thinking about this product for next season... thanks for any additional insights. |
November 29th, 2018, 11:12 AM | #58 |
I bought the updated parts, the spring looks substantially stronger than the OEM item and the bearing (that rides on the shift drum) looks a little bigger. The following is mostly for myself in case I ever have to do this again, lol.
Here's couple more installation tips. (1) stuff a rag or paper towel in the oil drainback cavity (under the clutch plates) in case you drop anything. There's a small washer behind the arm that's easy to drop. (2) as others have said, spread the shift linkage arms apart and there should be enough slop to move the top arm over onto the star piece on the end of the shift drum (I just moved both of them out of the way). (3) I put the parts together and got the allen head screw started a few turns with the straight piece of the spring sticking almost straight up and down. I then used a screwdriver to move it into final position (resting against the case) before tightening further. (4) Keep a close eye on two things: make sure the bearing on the end of the arm stays in proper alignment with the shift star i.e. parallel to it, not pushing against the end of the star and that the washer-bushing that the allen screw passes through stays in proper position. I had to hold the washer in place using a screwdriver as the new spring wants to push the arm down out of alignment. (5) When you think you're done pry against the arm with a screwdriver to make sure you feel spring tension and can see the arm pushing down onto the shift drum. It's winter and I won't know until next season but this setup cannot be worse. My bike was downshifting by itself in a couple of places on the track which (needless to say...) was pretty disconcerting. At first I blamed myself for sloppy shifting but then realized it probably wasn't me. Thanks for previous tips! |
November 30th, 2018, 07:47 AM | #59 |
The OEM updated parts? I looked at listings and see a number change for the lever arm but not the spring.
GUZZI JOHN |
November 30th, 2018, 08:30 AM | #60 |
November 30th, 2018, 09:16 AM | #61 |
So not updated OEM
GUZZI JOHN |
February 13th, 2019, 07:12 PM | #62 |
Hi we just tried to install this kit on my EX300 and was unable to get the bike with the FactoryPro detent arm and spring installed to shift past 2nd gear while the bike was stationary (and back wheel was being manually spun). I was able to shift through 2nd when I tested the stock detent arm and the FactoryPro spring, but not with the FactoryPro intentionally larger detent arm. After speaking on the phone with the FactoryPro support, he stated that the Kawasaki's don't shift above 1st if the bike's rear wheel is not spinning (he said the bike needs to be moving for it to spin fast enough to engage) due to the steel balls that sit on the transmission output shaft that are by design some kind of safety thing so that you can't shift into 2nd while bike stationary.
Did anyone of you who successfully installed the kit notice this "issue" when testing the shifting before putting everything back together? Worried that we were overthinking it, and should have just put it back together without it being able to shift into 2nd...and it would be perfect. It is just a lot of work to have to take it apart, put it back together, and pray that it is supposed to be like that. |
February 13th, 2019, 07:41 PM | #63 |
its called the Kawasaki "positive neutral finder" system, search that phrase on Google, a ton of info. Info may be in owners manuals, too, dunno.
swing arm covers? chain cover? shift lever? | ac9im11 | 2008 - 2012 Ninja 250R Tech Talk | 1 | April 30th, 2014 11:11 PM |
Shift arm linkage placement | Redsvt | 2008 - 2012 Ninja 250R Tech Talk | 1 | March 11th, 2012 08:43 AM |
Factory Pro Jet Kit | snowsoldier | 2008 - 2012 Ninja 250R Tech Talk | 5 | May 25th, 2011 08:11 PM |
factory pro jet kit | newgirlrider | 2008 - 2012 Ninja 250R Tech Talk | 2 | August 4th, 2009 11:04 PM |
