Old October 22nd, 2013, 02:30 PM   #1
anacron
anacron's Avatar
Motorcycle(s): Triumph Street Triple R
Putting WD-40 on fork tubes
My bike's been squeaking/chirping when going over bumps. Its definitely not a grinding/screeching noise that's associated with worn brake pads, but more like a metal rubbing on metal.
I'm sort of suspecting the forks (or even the front axel) not having enough lubricant when compressing.. would there be any issues with spraying some WD-40 down the tubes and around the axel?
Here's my Youtube Channel.
Here's my Flickr Photostream.
anacron is offline   Reply With Quote
Old October 22nd, 2013, 03:02 PM   #2
tooblekain
tooblekain's Avatar
Motorcycle(s): 2007 Triumph Bonneville; 2008 Ninja 250r (trackbike)
I would check the following:
Check to make sure the following are straight: axle, fork tubes. If they are straight move on to the next step.
When was the last time you had your fork oil changed? If its been never or ages, that oil could be broken down and sheered so much that the springs inside the fork tube is causing the squeak. You should be using 15W oil
I would absolutely not spray WD-40 inside the fork tubes. The only liquid that goes inside the fork tube is fork oil.
Also maybe check your bushings on your forks. Or if possible, take a video of this squeek you speak of.
*CVMA #312*SoCal Trackdays*BigHeadz Racing*Motion Pro*Factory Effex*Leatt Brace* Racetech *Bell * Woodcraft CFM*Vortex*Hotbodies*Surface Sun Systems*Braking*LiveWire Energy*Freegun Underwear
tooblekain is offline   Reply With Quote
Old October 22nd, 2013, 03:06 PM   #3
every time my forks have squeeked on compression they have been bent and were rubbing on the inside. but that's only happened twice.
Old October 22nd, 2013, 03:13 PM   #4
Originally Posted by anacron View Post
......I'm sort of suspecting the forks (or even the front axel) not having enough lubricant when compressing.. would there be any issues with spraying some WD-40 down the tubes and around the axel?
The forks keep and recirculate the interior lubrication, there is no need to add any oil, unless your seals are showing leaks of oil.
There is nothing to lubricate in the axle; but it could be loose somehow: re-torquing it won't hurt anything.
Noise could come from the steering column (dry or loose bearing) and from the speedometer mechanism and cable (dry) as well.
Old October 22nd, 2013, 03:28 PM   #5
anacron
anacron's Avatar
A short clip of the noise I'm hearing. Seeing the video, it doesn't seem to be a fork/axel issue. The sound seems much closer to the camera (maybe from the dash...)
Old October 22nd, 2013, 03:41 PM   #6
backinthesaddleagain
backinthesaddleagain's Avatar
Motorcycle(s): 2013 ZX6R 636
The wheel turns on wheel bearings. The axle gets greased when you remove the wheel just to aid installation and the next removal. No wd40 needed and keep it off the forks. It might even harm the seals, but that's a whole argument like wd40 harming an oring chain.
Old October 22nd, 2013, 03:47 PM   #7
anacron
anacron's Avatar
No WD-40 then. Also, it doesn't seem like an issue with forks/axel the sounds seems to be closer to the dash. I guess I'll start with the clip-ons since those were the most recent modifications near the dash.
Old October 22nd, 2013, 04:02 PM   #8
very strange noise in that video. the 300 i believe has no speedo cable unlike the 250. i would say it sounds just like the speedo cable but since you dont have one... do you have ABS? perhaps the speed wheel is rubbing. its possible it could be something else rubbing. try compressing the suspension without moving and see if you can get it to squeak
Old October 22nd, 2013, 04:13 PM   #9
anacron
anacron's Avatar
Nope, non-abs 300. Can't replicate the sound when compressing the suspension. Brake and Clutch levers have some up-down play and I noticed the brake side squeaked a little when the lever rubs against the housing. However, I can't get the levers to make the noise on-demand. Looking at the video the levers seem unlikely given that I'm holding both to stop vibrations but the noise still happens.
Old October 22nd, 2013, 05:09 PM   #10
leed
leed's Avatar
Motorcycle(s): Time will tell
What about the rear shock?
Old October 22nd, 2013, 05:24 PM   #11
anacron
anacron's Avatar
Maybe but I hear the sound in front of me rather than behind...
Old October 22nd, 2013, 05:32 PM   #12
very strange noise in that video. the 300 i believe has no speedo cable unlike the 250........
I cannot hear any noise
No speedo cable?
What is the sensor for speed?
Old October 22nd, 2013, 06:02 PM   #13
leed
leed's Avatar
Understood, I was just throwing it out there. Mystery sounds are confounding, so you might be surprised is all.
Old October 22nd, 2013, 06:05 PM   #14
anacron
anacron's Avatar
No no, suggestions are much appreciated. I need to dial down preload anyway so we'll see.
Old October 23rd, 2013, 08:01 AM   #15
Loose radiator fan?
Front engine mount loose?
Old October 23rd, 2013, 08:16 AM   #16
I remember my 250 speedo drive gear had to be greased. didn't know the 300 doesn't have a drive.
Old October 23rd, 2013, 10:30 AM   #17
Lychee
sail away
Lychee's Avatar
I don't hear anything out of the ordinary... Is it intermittent? What time stamp does it happen at?
Old October 23rd, 2013, 10:47 AM   #18
anacron
anacron's Avatar
Loose radiator fan?
Had the dealership install shogun frame sliders so loose engine mount is a real possibility.
Old October 23rd, 2013, 10:55 AM   #19
Xtina
Xtina's Avatar
Motorcycle(s): 2013 Ninja 300, 2007 Gsxr 600, R6-sold :(
I don't hear anything unusual.
Xtina is offline   Reply With Quote
Old October 23rd, 2013, 11:16 AM   #20
i think we found a winner. the front engine mounts on the 300 are rubber mounts. if the rubber bushing is degrading/softening it means the engine vs frame positioning is moving a bit. which means that non-flexible shogun frame kit is sliding up and down, loosening your front engine bolts.
Old October 23rd, 2013, 12:09 PM   #21
anacron
anacron's Avatar
I feel a lot of vibration coming off of the sliders so this may very well be the issue and potentially a symptom of degrading rubber mounts. Hopefully, removing and reinstalling the upper fairing will solve the issue with them popping out, as well.
Anyone know where I can buy the rubber mounts, in the event they need replacing?
Old October 23rd, 2013, 12:19 PM   #22
the bushings should be available from any oem supplier like cheapcycleparts or bikebandit
i get the feeling though that its a fault in the design of the sliders not in the bike. where are they mounted to on the front? are they designed specifically for the 300 or are they 250 sliders?
Old October 23rd, 2013, 04:43 PM   #23
leed
leed's Avatar
What is the deal with Kawasaki having bad rubber suppliers/rubber choice?! My 06 SV's rubber bits [or at least what remains] are in good shape, where as my 09 250R's rubber pieces are.. well.. crumbling.
08+ forks or fork tubes garth285 Items Wanted 0 July 11th, 2014 10:42 AM
08+ fork tubes scorch Items Wanted 0 June 4th, 2014 06:16 AM
Can fork springs be changed without removing the fork tubes? AlanDog 1986 - 2007 Ninja 250R Tech Talk 26 April 23rd, 2014 05:19 AM
'94+ EX500 fork tubes and valve emulators in an EX250J? CZroe 2008 - 2012 Ninja 250R Tech Talk 1 February 7th, 2013 10:12 PM
[motorcyclistonline] - Race Tech Distributes TNK Fork Tubes Ninjette Newsbot Motorcycling News 0 April 18th, 2011 11:20 PM
