October 28th, 2013, 11:19 PM | #1 |
Join Date: Oct 2013 Motorcycle(s): 2008 Ninja EX250J Posts: 6
Putting Engine Sprockets Back In
I have read about every guide I could possibly find, but I'm running into a minor problem.
I went through the procedures: - Crankshaft was at 2T, from when I removed the Chain Tensioner and Sprocket - Put the exhaust sprocket into place in chain - Put the intake sprocket into place in chain When I put the sprockets so that the timing marks align, and the chain has the correct amount of link pins, so that it is positioned correctly, on Cylinder 1 exhaust, the sprocket seems to touch the cylinder cap. There are pictures below with the Sprocket aligned correctly (or what I think is correct) and incorrectly. When it is correct, Cylinder 1 exhaust touches one of the caps, and when it is incorrect, if I assemble it, it won't turn all the way around if I crank the alternator. Anyone know what I'm doing wrong or what I'm missing? Thanks in advance. At 2T At 2T slightly misaligned Cylinder 1 exhaust sprocket at 2T sitting on cap Cylinder 1 exhaust sprocket sitting on cap Engine at 2T Exhaust Sprocket 2T slightly misaligned Exhaust sprocket aligned properly |
October 28th, 2013, 11:26 PM | #2 |
Welcome to our site, Kyle !!!
The problem seems to be the lack of tension of your cam chain. Search for DYI related to valves here: http://www.ninjette.org/forums/showthread.php?t=5586 I suggest you service the chain tensioner before continuing.
October 28th, 2013, 11:33 PM | #3 |
Thanks for the prompt response.
Wouldn't the chain tensioner go on after the sprockets, plates, and chain guide, but the problem exists before those things already go on? Also, by service the chain tensioner, do you mean get a new one I assume? |
October 29th, 2013, 05:01 AM | #4 | |
http://www.ninjette.org/forums/showthread.php?t=140450 http://www.ninjette.org/forums/showp...0&postcount=67 The chain between the sprockets need to be free of any slack and rotating the engine without the tensioner or in the opposite direction can lead to problems. No, the tensioner can be disassembled, lubricated and re-assembled. Go to the end portion of this page: http://www.theyeagergroup.com/2008_n..._clearance.htm
October 30th, 2013, 05:05 PM | #5 |
Board Member
The #1 cylinder will be putting pressure on the exhaust valves. This makes installing the exhaust cam tricky. The trick I use is to lighly wedge a small screwdriver between the chain and the head so the chain does not skip.
I will say that I am running much higher spring pressure than stock. So my situation may be different. |
Not putting this bike back together. | Alex | Videos | 37 | July 11th, 2015 03:58 AM |
Had to jump-start the 250 after killing the engine when putting down the side-stand. | Norway | 2008 - 2012 Ninja 250R Tech Talk | 4 | June 5th, 2014 02:32 PM |
Need help putting lower cowling back on | IF13 | 2008 - 2012 Ninja 250R Tech Talk | 9 | September 12th, 2013 12:00 PM |
A few questions, help putting bike back together | cdupont03 | 2008 - 2012 Ninja 250R Tech Talk | 13 | May 22nd, 2013 02:47 AM |
putting the black side fairings back on the rubber grommets | stryder | 2008 - 2012 Ninja 250R Tech Talk | 6 | April 18th, 2010 09:00 AM |
