January 9th, 2014, 08:13 PM | #1 |
Join Date: Nov 2011 Motorcycle(s): Kawasaki ZX10 Posts: 5
Ninja 250R Ecu / start up problem?
Hi there,
I have a Ninja 250R 2009 Model (This bike is Fuel Injected so has no choke, UK model) Recently I tried to start my bike and it wouldn't, then I looked and saw that my dash wasn't working, the oil light still showing red and the fuel indicator lights are both flashing. I can also hear a fast weird ticking noise, upon closer inspection this noise was coming from the ECU. Now the bike doesn't start, the indicators don't work, the horn doesn't work, the lights don't work, basically all the electronics on the bike don't work. (with the ignition on or off) Now the weird thing is when I turn off the ignition and arm the alarm, all the indicators still manage to flash? Either way, I checked all the 10amp / 15amp fuses and none of them seem to be blown - I also disconnected the battery and reconnected it to see if that would help but no luck. I tried to push start the bike as well but it doesn't work, both the fuel and fuel injection lights just turn on solid - Here's a video of what happens when I turn on my bike: http://www.youtube.com/watch?v=LYyWCtVo-8E UPDATE: The battery was out of charge even though the lights light up, I managed to jump start my bike with a car and everything's working fine! Thanks to all of you who helped me out Last futzed with by hatashi; January 10th, 2014 at 02:42 AM. |
January 9th, 2014, 08:39 PM | #2 |
You may want to start with the basics. 1st check and make sure your battery has an good charge. Alarms put a constant drain on the battery. Although your lights are on, your amperage may be too low.
2nd disconnect any external electrical components (i.e. alarms, lights, outlets etc..) Disconnect then reconnect the battery terminals and see what the FI indicator light does. |
January 9th, 2014, 09:04 PM | #3 | |
I'll let you know if I have any luck with this |
January 9th, 2014, 09:18 PM | #4 | |
Maybe this feature is making those indicators flash: "Can be programmed to provide Turn Signal Reminder." http://bikealarmman.com/?p=acumen&i=cat21
January 9th, 2014, 09:50 PM | #5 | |
January 9th, 2014, 10:12 PM | #6 | |
http://faq.ninja250.org/wiki/How_to_...attery_is_dead I have no experience with fuel injected bikes, but as far as I have learned, those engines are harder or even impossible to start up by pushing when the battery is low. I would put that battery on a slow charge (1~2 Amps max) for a few hours and disconnect the alarm, at least temporarily, as DaBlue1 has suggested above.
January 9th, 2014, 10:50 PM | #7 | |
Either way thanks allot for your help, I hope this fixes the problem |
January 9th, 2014, 11:04 PM | #8 | |
Components connected in-series are connected along a single path, so the same current flows through all of the components. A charger for car's batteries could work, if it delivers no more than 2 Amps. Having a charger is convenient for situations like yours and those are not expensive ($20~$30). You could also rule out your battery if you can connect a full car or truck battery (engine non-running) to the terminals in your bike and see if everything returns to normal with the proper voltage. Sorry, as you see, your options are so limited as inconvenient. You are very welcome
January 10th, 2014, 02:36 AM | #9 | |
Thanks once again! |
January 10th, 2014, 05:21 AM | #10 |
You are welcome
I am very sorry, I also forgot that option, as well as telling you that the engine of the car should be off during the jumping, in order to prevent possible damage to your internal electronics. Glad you get her rolling again !!! Keep an eye on the battery for signs of chronic weakness; sometimes, after deep discharges, they become "cranky".
January 10th, 2014, 06:21 AM | #11 |
Manuel, If you have a CycleGear near your rock, stop in and get a battery tender jr..
Don't know if you'll need it nightly, but better safe than sorry. |
[visordown.com] - New Triumphs recalled for ECU problem | Ninjette Newsbot | Motorcycling News | 0 | November 24th, 2014 03:13 AM |
[motorcycle.com] - 2014-2015 Triumph Models Recalled for ECU Problem | Ninjette Newsbot | Motorcycling News | 0 | November 21st, 2014 11:20 AM |
