Old February 6th, 2014, 06:14 PM   #1
dcj13
Participant
dcj13's Avatar
Motorcycle(s): '94 K75 std
Bearing Life?
I'll put the question in the pre-gen section, but it's applicable across the generations, perhaps.
What is the expect life for Ninjette steering head bearings (SHB) and front and rear wheel bearing (WB)?
In the BMW world, front WBs last over 100K miles (provided one is not forging streams) and SHBs can last quite a while, particularly if one tightens up the races when it first starts to clunk. (I've got 83K miles on my K75 and the SHB have been adjusted twice in the last 20 years without cleaning/relubing). The modern BMWs (for last 30 years) have tapered SHBs, which, of course, are far superior to ball bearings in this application. And I know that my Ninjette with 26K miles could stand new SHBs (tapered would be installed, of course).
How many miles are you guys/gals getting out of your SHBs and WBs on your Ninjettes?
Old February 6th, 2014, 06:30 PM   #2
You'll find some posters here who believe the lifetime of the stock SHB should be measured in hours instead of years or miles.
Old February 6th, 2014, 06:39 PM   #3
dcj13
Participant
dcj13's Avatar
I admit I don't think ball bearings are appropriate for SHBs, including for bicycles. I'm curious as to why the big four Japanese bike manufacturers use them. Seems a lousy way to save $20 or so. Also, I've always been puzzled as to why tapered SHBs are marketed by a company called "All Balls" (or something to that effect).
My Ninjette has a slight detent at straight-ahead alignment and I know I'll have to deal with it one of these days. But not today.
Old February 6th, 2014, 06:41 PM   #4
tc.young
Motorcycle(s): '89 klr 650, '00 250r
depends on how much preventative maintenance has been done, my klr needed new head bearings at 12k because it was notchy and the ballbearings were dry and the PO did nothing.
my xr250l needed wheel bearings at 15k but it was ridden offroad a lot.
if you grease them then they can go for a lot longer. YMMV
tc.young is offline   Reply With Quote
Old February 6th, 2014, 06:47 PM   #5
dcj13
Participant
dcj13's Avatar
Sounds like good advice! But if I'm gonna go to the trouble of taking the steering head apart to grease it, I'm gonna spend the $50 or so to put in proper tapered bearings!
I've got an '05 KLR250 (with exactly 1800 miles! I just checked.) that I bought 6 weeks ago. Fortunately the SHBs still feel great on it. Only bad thing on that bike is the lack of electric starter.
Old February 6th, 2014, 08:56 PM   #6
Originally Posted by dcj13 View Post
.............What is the expect life for Ninjette steering head bearings (SHB) and front and rear wheel bearing (WB)?
With proper lubrication and isolation from water, all those bearings should last longer than the bike itself.
The main problem with the SHB is that the play is adjustable, while only one optimal clearance between the balls and the tracks can sustain a film of lubrication.
Old February 7th, 2014, 03:42 AM   #7
fast1075
Motorcycle(s): 2006 Ninja 250, 2004 Buell XB12s, Honda 110 Elite
I have been working on motorcycles for over 45 years. The problem is that the bearings used are not REALLY good for the side thrust loads. They are radial ball bearings. The rake of the fork and turning and braking loads put very high thrust loads on them. The pounding from the road surface beats them up. Humidity and water introduced corrode them.
SOME bikes, especially European ones have better engineered designs and are sealed better from environmental factors.
When they wear out install a set of good tapered bears which ARE designed to handle side thrust and enjoy better handling and life from them.
As for why they don't use "good" bearings, simple. Good bearings cost, say, $4.00 more. Build 10,000 bikes. Good bearings will add $40,000.00 to the build cost. 40K is a lot of money to lose on a low profit margin bike.
"They don't pay me enough to ride this thing!" Kenny Roberts after winning the Indy Mile on the TZ750 powered Grand National bike.
fast1075 is offline   Reply With Quote
Old February 7th, 2014, 07:22 AM   #8
quarterliter
Motorcycle(s): 2004 Ninja 250
Is there anyone besides all balls who makes the tapered roller bearings for the ninja 250?
Old February 7th, 2014, 05:48 PM   #9
dcj13
Participant
dcj13's Avatar
All balls probably isn't a manufacturer. They likely buy correct sized standard bearings from FAG, SKF, and other companies and sell them in kits to guys like you and me.
Old February 7th, 2014, 09:43 PM   #10
old3
800 miles and mine were wasted. 2013 300.
I love me some SHB talkin!
old3 is offline   Reply With Quote
Old February 8th, 2014, 09:37 AM   #11
dcj13
Participant
dcj13's Avatar
Good! Sounds like it may be a recurring thread (hopefully not as disdained as the dreaded oil thread, dreaded tire thread, etc.).
Is replacing pre-gen SHBs a difficult job for an advanced shadetree mechanic? I realize some homemade (or possibly purchased) tooling is in order.
Is it a one or two evening job?
Last futzed with by dcj13; February 8th, 2014 at 05:40 PM.
Old February 8th, 2014, 10:10 AM   #12
old3
I did the 2013 without removing the fairings in about 2 easy paced hours. I'm sure the older ones are similar. You need a BFH and a long drift or suitable device to pound out the old and gently introduce the new races.
Caveman simple to do. Just drive them back in straight and move the force 90 degrees every tap or get a race press and use that.
I'm a hammer guy.
http://www.youtube.com/watch?v=x17uzPUNMto
Old February 8th, 2014, 10:16 AM   #13
allanoue
allanoue's Avatar
MOTM - Sep '14
Is replacing pre-gen SHBs a difficult job for an advanced shadetree mechanic?I realize some homemade (or possibly purchased) tooling is in order.
this thread may help
http://www.ninjette.org/forums/showthread.php?t=119551
Old February 8th, 2014, 12:55 PM   #14
dcj13
Participant
dcj13's Avatar
Thank you Jim and Al!
It sounds like a "Heathkit 2 Evening" job (or less) and no more than USD $50.
I like that! I'll take a look at the exploded parts diagram to see what I'm in for. Appreciate very much your responses!
Old February 8th, 2014, 05:26 PM   #15
old3
Grab a tub of Bel Ray waterproof grease at the bike shop too. That stuff is great for this job, in your wheel seals, on the axles, linkage bearings. $5.
Steering stem bearing justdrew 2008 - 2012 Ninja 250R Tech Talk 3 February 5th, 2015 07:57 AM
Help: Journal bearing replacement cuong-nutz 2008 - 2012 Ninja 250R Tech Talk 2 February 27th, 2014 09:39 PM
Wheel bearing quality broken neck 2008 - 2012 Ninja 250R Tech Talk 15 January 18th, 2014 07:34 PM
Bearing or chain? The_big_dill 1986 - 2007 Ninja 250R Tech Talk 8 August 1st, 2013 08:41 PM
Wheel Bearing?! RiderOnTheStorm 2008 - 2012 Ninja 250R Tech Talk 3 May 20th, 2012 07:12 PM
