Old April 6th, 2009, 02:39 PM   #1
kbryant
Area P
kbryant's Avatar
Area P - Quiet Module - D.E.I.
We've had requests from those who have purchased the Standard Muffler and are looking to quiet it down without the additional expense of having to purchase the Long Quiet Muffler.
Attached are pictures of our "D.E.I." (Dual Element Insert) which debuts on this forum. We designed a first generation of this sound attenuator many years ago for a company called Jardine (it was called QMI or Quiet Module Insert). The D.E.I is a brand new product and far superior. It consists of a 304 series stainless steel "Nozzle", and a 6061 billet cnc aluminum "Module" insert with high temp O-Ring.
Essentially, it installs/inserts into your turn down exit tip and is secured by a single screw. You simply drill a hole in the tip and install the DEI. It comes with detailed instructions and is very easy to install.
It can be used as simply the "Nozzle" by itself. Or for further attenuation of sound, both the Nozzle and Billet module together. It will reduce decibel levels by 6 - 8 dbA. You can remove it completely also, as the small 5.5mm hole that you drill in the tip will not affect anything and puts the power/sound right back where you started. Although it will reduce the sound level, it will also reduce the power level that you gained.
It will not be nearly as quiet and/or perform as well as the Long Quiet Core Muffler. But for those people looking to reduce the sound level of their Standard muffler, this is a less costly solution.
Intro price is $39.95. Shipping cost is $6.00. It comes in a small box and is shipped by Priority Mail. We do not have specific test data on it for the 250R (we've tested this unit on a wide array of other models from Offroad to large displacment sportbikes). If someone would like to drop their bike off at our facility, we will install one at no charge to document specific test results.
Last futzed with by kbryant; April 6th, 2009 at 02:43 PM. Reason: sentence
Old April 6th, 2009, 02:46 PM   #2
would this work on the quiet core mufflers as well?
Old April 6th, 2009, 04:03 PM   #3
kbryant
Area P
kbryant's Avatar
Talking
Sure would Kelly. It should have the same basic affect. I just don't know what the "performance" results would be on the Long Quiet Muffler. How about I send you one for "R&D" purposes (no charge) and you tell me what you think?
Old April 6th, 2009, 04:07 PM   #4
Damn, Kerry... that would be awesome!
Though I have no access to a mechanical dyno to prove my findings, I'll start tuning up the ole butt dyno right away!!
mahalo, sir!
woohoooo!!
Old April 6th, 2009, 04:23 PM   #5
CaliGirl
Curiosity is a Killer
CaliGirl's Avatar
Motorcycle(s): 08 Ninja 250
I would love to leave you my bike for testing.....I think I need to get an actual AP exhaust first
CaliGirl is offline   Reply With Quote
Old April 6th, 2009, 04:24 PM   #6
stroked59
Motorcycle(s): 08 Ninja 2505
one up for kelly
stroked59 is offline   Reply With Quote
Old April 6th, 2009, 05:04 PM   #7
So, Kerry... for clarification, besides sending me one for evaluation (thank you, thank you, thank you ), are you still looking for someone in your area to bring their bike with a standard AP system in for testing and documentation?
If so, someone should jump on this!!
Old April 6th, 2009, 05:06 PM   #8
kbryant
Area P
kbryant's Avatar
mahalo, sir!
woohoooo!!
I'll mail you one tomorrow. The Dyno is simply one tool we use. It's always important (sometimes even more important) to use "the ole butt dyno" whenever possible. If you can't feel it, sense it, listen to it, it really doesn't matter what the Dyno says. Should be the same jetting with the Nozzle only. Will run richer with the billet insert installed.
Old April 6th, 2009, 05:09 PM   #9
kbryant
Area P
kbryant's Avatar
Yes. Leave it with us for a day or two. That way we can test and gather data on the Dyno and Sound Meter as well.
Old April 6th, 2009, 05:09 PM   #10
Jiu Jitsu Player
Live 2 Ride Forced 2 Work
Jiu Jitsu Player's Avatar
Motorcycle(s): 2008 RED 250r
If I was back in so-cal I would be all over this!!! (probably help if I had an area-p, but still!)
SAVAGE MODE: [ON] OFF
www.7milesdown.com
Jiu Jitsu Player is offline   Reply With Quote
Old April 6th, 2009, 05:09 PM   #11
kbryant
Area P
kbryant's Avatar
Well we can sure help you with that if you like
Old April 6th, 2009, 05:14 PM   #12
Last question... I promise... well, not really.
this was implied, but not stated in your first post... this module will work in the mufflers for both generations of 250s, is that correct?
Old April 6th, 2009, 05:15 PM   #13
Snake
Snake's Avatar
Kerry,
Can the silencer be used with the flat end muffler as well?
I don't have an Area P on my bike yet but hope to get one as soon as it comes out for the 07 & older bikes.
Old April 6th, 2009, 05:45 PM   #14
kbryant
Area P
kbryant's Avatar
Yes, implied and stated. Fits all.
Old April 6th, 2009, 05:45 PM   #15
kbryant
Area P
kbryant's Avatar
Originally Posted by rcuriel View Post
Kerry,
Nope. Only works with the Turn Down Exit Tips.
Old April 6th, 2009, 09:22 PM   #16
TrueFaith
TrueFaith's Avatar
Motorcycle(s): 2011 Honda CBR250R
You say it "should be the same jetting" with the nozzle only, but will run rich with both pieces installed. Do you have data on the difference in decible reduction using just the nozzle compared to using both the nozzle and billet? I have no intention of messing with my Area-P non-quiet core, since I love the exhaust sound as it is and don't consider it too loud compared to some of the bikes that blast by my house every day. Just curious.
TrueFaith is offline   Reply With Quote
Old April 7th, 2009, 08:34 AM   #17
kbryant
Area P
kbryant's Avatar
On other bikes we've tested, it is normally 2 dbA with the Nozzle only and another 5 - 6 dbA reduction with both the Nozzle and Billet Module installed. Total reduction is normally 6 - 8 dbA. In this case, the Billet Module causes the rich condition as it restricts exhaust flow to attenuate sound.
Old April 7th, 2009, 10:15 AM   #18
camaroz1985
camaroz1985's Avatar
Motorcycle(s): 2008 WR250R, 2006 Ural Raven (Sold), 2009 Versys Green (Sold), 2008 Ninja 250R Green (Sold)
Dang I was perfectly satisfied with keeping the stock exhaust because it was quiet. Now this and the quiet core are looking very very tempting. Why did you have to post this?
camaroz1985 is offline   Reply With Quote
Old April 7th, 2009, 04:01 PM   #19
TrueFaith
TrueFaith's Avatar
Thanks for the info, Kerry. After owning the Standard Area-P I wouldn't give up that beautiful exhaust sound for anything. I don't know why everyone thinks it's so loud. I can throttle down while cruising through town and nobody even raises an eyebrow, but open her up on the back roads around here and it's like having a "monster in your pocket". Lots of really loud Harleys out my way and most of the time people are too busy bitching about them to even notice me. Mad reps to you for manufacturing the best-sounding pipe on the planet.
Old April 9th, 2009, 01:03 AM   #20
VeX
That's me!
VeX's Avatar
Motorcycle(s): 2008 Ninja 250r (Tis blue), 2008 CBR600RR
Oh! Oh! When are you planning this test? I live in San Diego, but could drop my bike off and hitch a ride back down to San Diego (I have a friend that goes down from Pasadena to San Diego every other week). I would be down for it as I am one of those that is annoyed by the incredibly LOUDNESS of the standard core muffler (Trying to casually ride through city streets at 5am is... Noisy).
VeX is offline   Reply With Quote
Old April 9th, 2009, 01:06 AM   #21
Vex... great idea!!
PM Kerry right away to get dibs on this if he's still looking.
gl, man!
Old April 9th, 2009, 03:12 AM   #22
Blue Ninja 250R
Blue Ninja 250R's Avatar
Motorcycle(s): Kawasaki Ninja 250R 2008
Wonder will Kerry send me a full AP together with DEI for test too......
Say that you will Kerry, PLEASE.........
Blue Ninja 250R is offline   Reply With Quote
Old April 9th, 2009, 08:37 AM   #23
kbryant
Area P
kbryant's Avatar
Basically whenever someone wants to drop their bike off at our facility for a few days.
Old April 9th, 2009, 02:28 PM   #24
Go, Vex, Go!!
Old April 9th, 2009, 07:39 PM   #25
Blue Ninja 250R
Go, Vex, Go!!
Yes! Vex. Make sure you're there before me......
Old April 9th, 2009, 07:39 PM   #26
miks
I'm lovin' it.
miks's Avatar
Motorcycle(s): '09 Black 250R
$50 on Vex!
Son: When I grow up I want to ride a motorbike.
Father: You can't do both son.
miks is offline   Reply With Quote
Old April 10th, 2009, 09:32 AM   #27
1hardryder4life
Motorcycle(s): Nothing
very interesting design. Ima order one of these.
1hardryder4life is offline   Reply With Quote
Old April 10th, 2009, 05:25 PM   #28
08_250R
Motorcycle(s): 08 Green 250R
Kerry,
What are the odds on a new quiet end plate? something like this, sorry for the poor photoshop, but you get the point.
08_250R is offline   Reply With Quote
Old April 10th, 2009, 06:34 PM   #29
kbryant
Area P
kbryant's Avatar
Originally Posted by 08_250R View Post
Kerry,
Very creative. I do get the point.
Without getting too much into the engineering & design aspects and to make a long response short - you have the Billet portion of the module mounted backwards. The flow dynamic is designed for the taper to be in the inlet side. The D.E.I. is designed specifically for the turn down tip and merge from the core to the exit tip. The primary goal was to make a complex engineering component, into a simple, affordable, modular unit with multiple levels of adjustment.
Old April 10th, 2009, 07:57 PM   #30
Kerry,
Is it be possible for one to "tune" that billet piece by drilling the holes out to a bit larger diameters if you didn't mind a little more sound and wanted a little less restriction?
Old April 10th, 2009, 08:53 PM   #31
08_250R
I understand what you are saying and I figured as much because the drilled holes look like a velocity stack. As I said, you get the point, I understand it may be a pain, but a new end plate would be nice.
Thanks
Old April 10th, 2009, 09:48 PM   #32
kbryant
Area P
kbryant's Avatar
Kerry,
Yes absolutely! We have 8 other versions of these for different displacement applications, core diameters, turn down tip diameters, etc.. Primarily the difference is indeed with the outer holes and inner main primary hole. We have others with different degrees of taper. We even have some where leaving the CNC burr(s) around the outer holes (gatlins if you will), helps with the reversion affect. By all means, experiment away! Since you are being somewhat "sponsered" on this project, we can always send you another one if you go too far and/or want to go back to the way it was.
Old April 10th, 2009, 10:13 PM   #33
Kerry,
Thanks for the encouragement to experiment. Once I get it installed, I'll be able to tell how I want to play with it, if at all.
The thought came from modifying my dirt bike stock muffler. Removing the stock baffle yielded an exhaust that was too loud for my taste and reinserting the baffle proved too much of a restriction and "choked" the bike. The solution was to drill some additional holes in the baffle to reduce the back pressure and end up with a bit freer flowing stock exhaust, but not too loud for my tastes. I admit the jetting needed to be tweaked a bit more than what the normal solutions called for, but the result has yielded a bike with increased power over stock w/o the annoying, neighbor disturbing sound level an uncapped exhaust brings.
I hope I can come to the same sort of solution using the end cap you've provided. I really like the quiet core muffler, but at times wish it was a tad quieter. (I'm sure it's age related ) The end cap will hopefully allow me to tune the sound vs power level to perfection for me.
mahalo for "sponsoring" me the parts to experiment.
On an unrelated note, I know I'm only one of your many, many customers, but if I can ever be of help to you on a professional or non professional level, please do not hesitate to ask.
Old April 13th, 2009, 08:48 AM   #34
1hardryder4life
Ordered my kit last friday, part arrived the next day on saturday. thats what im talking about! should have it installed tomorrow to give it a test and report back.
Old April 15th, 2009, 10:13 AM   #35
1hardryder4life
Curious to know if you got yours and tried it out yet, Kelly?
Old April 15th, 2009, 10:41 AM   #36
Yes, I did get mine (thank you, Kerry), but have been busy with work (imagine that) and have not been able to install and test. Looking forward to your impressions.
Old July 15th, 2012, 10:51 AM   #37
t-rav_12
Motorcycle(s): '06 Ninja 2-Fitty (DD Commuter); '05 Ninja 2-Fitty (Track CCS#112); '94 YZF 7-FittyR (Missile/Backroad Bomber)
...well, Kkim?... After 3 yrs of testing?
(talk @ reviving a thread)
t-rav_12 is offline   Reply With Quote
Old July 15th, 2012, 11:08 AM   #38
cuong-nutz
cuong-nutz's Avatar
KKim is no longer around but I recall someone else installing the DEI and saw reduction of a few DBs.
HalfFast Racing Team
Area P 18" quiet core Install HELP! SafetyPaws 2008 - 2012 Ninja 250R Tech Talk 46 August 7th, 2013 09:09 AM
Can a Area P quiet 18' can attach to Jardine headers Cary26 2008 - 2012 Ninja 250R Tech Talk 3 February 21st, 2013 12:28 AM
Area P Quiet Core vs. Standard Betlog 2008 - 2012 Ninja 250R Tech Talk 19 January 28th, 2010 10:05 PM
DIY- Area P Quiet Module Install kkim 2008 - 2012 Ninja 250R Tech Talk 32 May 8th, 2009 11:02 AM
[2fiddy.com] - Area-P Quiet Core Exhaust Ninjette Newsbot Motorcycling News 0 June 30th, 2008 09:25 AM
