#1 |
Join Date: Oct 2012 Motorcycle(s): 2010 Ninja 250R Posts: 30
Hello guys ,
![]() First, I want to know its wet performance (some review only stated the dry performance which is pretty good). Maybe some of guys ever tested in ninja250. Second, I want to know about the tire size, since the smallest size of s20 are only available in 110/70 Front and 120/60 Front. And 150/60 Rear. the rim is 2.75" Front , so 110/70F would fit best. 120/60F can fit in but it is not good (out of tolerance). the rear has to be 150/60 (yes It way out the 3.5" rear rim tolerance, but that is the smallest rear tire size of s20). so my question is, which one is better (not best ![]() ![]()
I've failed over, and over, and over, and over again in my life.. and That is why I succeed ![]() |
#2 |
Why are you limited to the S20? Given the choices you listed, 110/70 on the front, 150/60 on the rear is the best option. But not sure why those are the only options, with all of the better suited rubber now available for these bikes.
#3 | |
#4 |
You have access to the Internet, order whatever you want online & have them fitted at the local shop.
#5 | |
![]() Quote:
it would be very expensive to buy it from outside country ![]() ![]() so whiskey, better which one 110/70F 150/60R or 120/60F 150/60R
#6 | |
Standard size is 110/70/17 front Who makes the S20? |
#7 | |
![]() so it it still okay to have 110F - 150R width difference? ![]()
#8 | |
ModMy250.com
Whiskey- Bridgestone makes the S20. |
#9 | |
[cyclenews.com] - Bridgestone Battlax S20 or T30 Tire Promo | Ninjette Newsbot | Motorcycling News | 0 | September 12th, 2014 01:00 PM |
[motorcycle-usa.com] - Bridgestone Battlax S20 Tire Review | Ninjette Newsbot | Motorcycling News | 0 | September 13th, 2013 04:40 PM |
Xelement Men's Black Motorcycle Performance Boots Size 9 | CalvinAmI | Gear-related | 0 | June 20th, 2012 03:12 PM |
tire size | unowned | Ninjettes At Speed | 13 | June 13th, 2009 03:34 PM |
max tire size? | richierich781 | 2008 - 2012 Ninja 250R Tech Talk | 2 | May 13th, 2009 04:51 PM |
