February 21st, 2014, 03:29 PM | #1 |
Ninjette Jockey
Join Date: Oct 2010 Motorcycle(s): Ninja 250R, Harley Davidson Heritage Softail, 2 Honda Monkeys, Polini & GRC mini GP Posts: A lot.
Looks like spring!
I rode from Stockton to Oakdale and back today (had to buy some CA glue, no hobby shops here). I passed orchards in bloom and stopped for a photo. Only a 75 mile ride. Really nice out!
For what shall it profit a man, if he shall gain the whole world, and lose his own soul?. |
February 21st, 2014, 03:33 PM | #2 |
Participant
Join Date: Oct 2012 Motorcycle(s): '94 K75 std Posts: Too much.
Sounds like a nice ride! But that's a long way to go for superglue...
February 21st, 2014, 03:34 PM | #3 |
Certified looney toon
MOTM Jul '13, Jul '14
Yeah, plants are confused and starting early.
Yay for getting out for awhile today. I hope to get some time in tomorrow or Sunday.
February 21st, 2014, 03:46 PM | #4 |
Ninjette Jockey
Any excuse for a putt!
February 21st, 2014, 05:42 PM | #5 |
Your face
Join Date: Jul 2013 Motorcycle(s): 2014 Honda CBR650f Posts: A lot.
Damn does that glue turn to gold once it dries or something?
"even a proper fitting helmet can 'get loose'" -csmith |
February 21st, 2014, 08:37 PM | #6 |
Certifiable nontundrum
MOTM - Sep '13, Sep '16
I'm never a fan of Walmart... But they sell about everything. I'd rather go to a hobby shop to though
February 21st, 2014, 09:38 PM | #7 |
Ninjette Jockey
In the R/C flying hobby we use large amounts of CA in various formulations; thin, thick, foam-safe, ect. I like 2 oz size bottles. These glues are not sold at Hobby Lobby, Michaels, Walmart, Home Depot or normal craft stores.
If you have a local hobby shop you are truly blessed.
February 22nd, 2014, 10:36 AM | #8 | |
MOTM - Sep '14
Would it work to fix cracked fairings? |
February 22nd, 2014, 04:15 PM | #9 |
Ninjette Jockey
Yes, I used that very trick on broken fairing tabs on a Yamaha 1200 Venture years ago. Best if done in 2 or 3 layers.
March 4th, 2014, 07:54 PM | #10 |
Join Date: Feb 2012 Motorcycle(s): 2012 Ninja 250R Posts: 362
What kind of materials will this work on? All plastics? Does the heat generated ever cause a problem?
March 4th, 2014, 11:58 PM | #11 |
Ninjette Jockey
The baking soda (or micro balloons, ect) acts as a filler. It has the side effect of causing the glue to set almost instantly. It gets hot enough to smoke, but only for an instant. (Beware the fumes). I have never had the heat melt the work. I have repaired styrene plastics this way, but I am not sure about ABS. Flexible plastics can sometimes be repaired using epoxy. Fiberglass cloth can be added for strength. The faster the cure time, the more flexible the epoxy; 5 minute epoxy being the most pliable after curing. Fillers can be added to epoxies, as well, for example sawdust. Fillers can also make the epoxy set up faster, so beware of mixing large batches. Interesting fact: JB Weld is epoxy that uses various metal particles as a filler.
Preparing for Spring | ForceofWill | General Motorcycling Discussion | 4 | February 18th, 2014 03:53 PM |
Waiting for spring ... | mikeohio | General Motorcycling Discussion | 26 | January 23rd, 2014 10:43 AM |
Spring | itslocfoo | 1986 - 2007 Ninja 250R Tech Talk | 8 | November 11th, 2013 08:38 PM |
Spring rates | Sipper' | Ninjettes At Speed | 2 | October 20th, 2013 06:13 PM |
Spring is coming! | g21-30 | General Motorcycling Discussion | 24 | March 2nd, 2010 08:36 PM |
