April 12th, 2014, 06:30 PM | #1 |
Threadkiller
Join Date: Apr 2014 Motorcycle(s): Yellow '04 stocker, '89 FJ1200, '87 Ducati Paso, '71 Yamaha XS1b, '99 KLR650, '81 FXE 80, '97 KTM 200EXC , etc Posts: 430
600 Single Roadracer
April 12th, 2014, 08:47 PM | #2 |
Join Date: Mar 2010 Motorcycle(s): 09' Blue Ninja 250R and 07' Honda 919 Posts: 605
interesting front end
April 12th, 2014, 08:52 PM | #3 |
Join Date: Feb 2012 Motorcycle(s): 2012 Ninja 250R Posts: 362
Wow. It's amazing what you can do with your uncle's old snowmobile....
April 12th, 2014, 09:22 PM | #4 |
Intrepid Adventurer
Join Date: Jan 2012 Motorcycle(s): 2004 GSXR 750 , 71 cb350streettracker, 07 Polaris Predator 500 Posts: A lot.
Dual overhead cam timming belt drive
Single cyl four stroke. Clutch on the left hand side of the transmission Oil pan at the bottom looks funky My un educated guess would be . Prototype engine derived from an auto engine. Mated to a motorcycle transmission. Anyone know about that crazy setup?
LIFE IS NOT FOR REGRETS OR EXCUSES. Breath deep, seek peace. Embrace the Madness. Life is good, let it be |
April 12th, 2014, 09:34 PM | #5 |
It appears to have belt driven cams. A cylinder and head from a Ducati maybe?
April 12th, 2014, 09:50 PM | #6 |
Intrepid Adventurer
Not a Ducati. The belt drive monster engines are air cooled
The panigale 1199 is liquid with chain drive overhead cam Multistrada also air cooled - I cannot find any motorcycle engines that are dual over head can belt drive that configuration The oil pan throws me off too And the protruding crank shaft with the weird coupler on there is confusing I even tried looking up prototype gti and diesel motorcycle singles. I am researching on my iPhone I wish the pics were higher def
April 12th, 2014, 10:02 PM | #7 |
it looks like an atv engine was stuffed into a custom frame that looks to be based on the mid 90s bmw designs. looks like it's missing its front cowl that has a ram-air scoop.
April 12th, 2014, 10:16 PM | #9 |
Intrepid Adventurer
What kind of atv ? Rzr
I cannot think of any belt drive cam atvs?? And what's w the oil pan? Ugh. I haven't slept enough in the last couple days . Simone figure this out so I don't have to obsess I've looked at many of these for reference if the builder removed the gear drive or chain drive cam assembly an replaced it with belt Tl1000 vtr1000 panigale1199 monster sv1000 kfx700 Raptor660 trx700 rc51 rzr 800 and 570 Rc8 Yamaha four stroke sleds and skidoo are chain drive cam Basically I've even tried some obscure car engines I checked a bunch of cruisers that are vtwin all have finned/air cooled jugs I am missing something! I've been googling all kinds of engines because I cannot think of hardly any powers port belt drie cam motors
April 12th, 2014, 10:29 PM | #10 |
Intrepid Adventurer
Right hand output and chain
Left side clutch w one off cover Dual overhead cam belt drive I guess whoever took the darn photo should've asked the builder some questions @alex.s - the front lower engine mount makes me think you could be on to something about an atv engine
April 12th, 2014, 10:44 PM | #11 |
The battery box hanging off of the front of the motor sure looks like a crappy afterthought. LOL!
April 12th, 2014, 10:53 PM | #12 |
Intrepid Adventurer
@Kevin1956 @alex.s
I doubted your guess too soon Testastretta head! Definitively a Ducati built top end http://www.sigmaperformance.com/testastretta.html You guys get to source the crank case and transmission ! It threw me because it seems they machined away a lot d the head to make it fit in the frame about the front corner The casting and bolt holes line up though
April 13th, 2014, 10:13 AM | #13 |
Whatever it is, why the square tubing linked forks? I had a 46 Indian once. It had a linked fork design like in the photo. When braking hard the bike would lift. The suspension basically didn't work at all when braking hard. I don't see how this could work on what is obviously a track bike. Some of the bike looks innovative, some of it looks like farm equipment!
April 13th, 2014, 10:15 AM | #14 | |
when setup correctly, it doesn't lift or compress under braking.
April 13th, 2014, 10:17 AM | #15 |
The cases remind me of an English bike with the cast motor mount. It looks like the motor/trans is unit construction. A mid sixties set of cases from a big English thumper of some sort?
April 13th, 2014, 10:23 AM | #16 |
it looks like the crank shaft with the three paws is for an external starter? i think the battery was an afterthought.
April 13th, 2014, 10:31 AM | #17 |
nology coils?
http://www.nology.com/power.html
April 13th, 2014, 11:06 AM | #18 |
This is starting to remind me of a bike a friend once owned. He restores antique motorcycles. He had a bike that was built with a Flying Merkel frame and home made forks. The engine was a set of Harley 45" (flathead) engine cases with the rear cyclinder blocked off. Adapted to the cases was an OHV head and cyclinder assembly from a Lawrence Aircraft engine, which had a smaller bore than the HD cylinder. Direct drive, no trans, no brakes, total loss oiling system. The gas tank was made from a Nash headlight. The bike had a history that came with it. It set a top speed record for a 350cc bike around 1950 at Edwards Dry Lakes in California. I think it was less than 100 mph! LOL!
April 13th, 2014, 02:21 PM | #19 |
edit: nevermind the sprocket is on the wrong side
could it be a highly modified BSA b33 bottom-end? with billet side panels and a new cast bottom plate?
April 13th, 2014, 02:35 PM | #20 |
Was hoping to cheat and find where these pics were posted elsewhere on the net, but as far as I can tell you took these yourself and they are only here. The mystery continues...
(google chrome tip; hold shift-s over a picture and then hit the right-click mouse button, and it auto searches the internet by image )
April 13th, 2014, 05:29 PM | #21 |
it's a KTM 640 LC4 engine with ducati cylinder and testastretta head, custom side panel
April 13th, 2014, 07:30 PM | #23 |
Threadkiller
Wow, I never expected much of a response to this thread.
The owner/builder is the guy in the red shirt in the first photo, and he was quite busy, so I didn't want to be a PITA and take up his time asking questions. What I do know is Ducati 916 cylinder head, piston and rod. One-off crank and engine cases Home built FI and ignition systems (15 years ago!) Look at the size of that headpipe! He built the frame to be adjustable in all aspects. Mofo's brain was way above my paygrade. Oh yeah, pics were taken by me, at Summit Point Raceway in W.Va. at least 15 years ago. |
April 13th, 2014, 07:38 PM | #24 |
Threadkiller
April 13th, 2014, 07:45 PM | #25 |
April 13th, 2014, 09:58 PM | #26 |
Intrepid Adventurer
@alex.s - how did you identify the crank case as LC4 ?
I don't see the oil pan or front engine mount screaming LC4? That bike is soooo custom. I don't know where a project like that starts or ends!? @Desmoluci - was he running the bike in some modified class? 15 years ago ? That's cool you held onto the pic and posted it ! Thanks
April 13th, 2014, 10:20 PM | #27 | |
April 13th, 2014, 11:39 PM | #28 |
Intrepid Adventurer
Sounds good to me! I've been looking all over the net at every Single and v twin I can think of and some I couldn't and I was stumped?
After you posted lc4 I tried searching the different years and I couldn't find one with a pan But the whole right side chain left side clutch made me think ktm I've been Measured weighed and left wanting. I best get out the way and let you brains do the figuring!
April 14th, 2014, 07:42 PM | #29 | |
'supermono' custom built around the lc4 http://i.imgur.com/DyWj9RD.jpg
FS: Twist of the Wrist - Interactive Vol. 1: The Motorcycle Roadracer's Handbook (CD- | Amazon Postbot | Amazon - Popular Motorcycling Items | 0 | April 23rd, 2013 10:45 PM |
[roadracingworld.com] - Geoff May Launching American Roadracer Clothing Line And Spon | Ninjette Newsbot | Motorcycling News | 0 | July 25th, 2012 11:10 PM |
[motorcyclistonline] - National- and world-champion roadracer to join Motorcycle Hall | Ninjette Newsbot | Motorcycling News | 0 | May 24th, 2011 07:10 PM |
[superbikeplanet.com] - Roadracer X Ceases Both Print & Internet Publishing | Ninjette Newsbot | General Motorcycling Discussion | 3 | January 1st, 2011 12:12 PM |
RoadRacer X: The Joy of Less | zenrush | General Motorcycling Discussion | 1 | May 7th, 2010 12:16 AM |
