April 26th, 2009, 06:28 AM | #1 |
Join Date: Apr 2009 Motorcycle(s): 09 Ninja 250........08 Harley Street Glide Posts: 9
Scorpio Alarm
So I picked up a Scorpio SR-I900 for a steal and thought I throw it on the 250r as the Street Glide already has an alarm. Scorpio's website doesn't list the wire adapter kit for an 09 (they do list for an 07-08). I sent off an email to support and got this response.
Scott, I haven't been able to get one of these bikes for 2009 yet. I don't know if the connectors have changed or not. The ex250 is not normally kept on the sales floor at our local dealers. Can you email us a few photos of the tail light, license plate light and rear turn signal connectors? These photos should show the wire color going into the connector and could help us determine whether we have a kit for your bike or not. If you are unable I will update our list at; www.scorpioalarms.com once I am able to see this bike or you could use the universal connector kit that comes inside every new Scorpio alarm. Regards, Harley Hogue Scorpio Alarms 480 951 1109 I replied I thought the 09 was the same wiring as the 08 but wasn't sure if it had changed in the redisgn from 07 ...........and go this in return Scott, I received some photos of the 2008 250 but they did not show what color wire goes where and I also don't think I received all the correct photos. The 2008 is listed on our website but I am in the process of having it removed until we can verify it as I don't think it is correct. I know within the last 2-3 years the connector has changed but since these bikes are not as common they are more difficult to check connectors on. So What I'm looking for is has anyone installed a Scorpio on the Gen2's, what connector did they use? Or does someone have a tail off a bike that they could snap some pictures of wiring connectors to the left,right turns, and connector to the brake. Basically needing wiring colors that go to each...........Or does someone have a wiring diagram that could be e-mailed/faxed to Scorpio showing the proper wiring coloring to the rear lights? I'd just much rather buy the correct plug in adapter than splicing inot a brand new wiring harness. Thanks Guys..........I'm learning alot about this bike here, Scott |
April 26th, 2009, 07:05 AM | #2 |
self wrencher
Just test the wiring with the voltmeter. It's super simple. How much did you pay for that scorpio?
April 26th, 2009, 07:29 AM | #3 |
I know it's not difficult, but for a few bucks I can buy the correct sonnectors and not have to splice wires
April 26th, 2009, 11:56 PM | #4 |
The Grand Royal
Join Date: Dec 2008 Motorcycle(s): 2009 Ninja 250R Posts: 258
Tag. I need an alarm.
May 4th, 2009, 09:23 PM | #5 |
Join Date: Jan 2009 Motorcycle(s): 2009 Kawasaki Ninja 250R Posts: 83
I want one too its very difficult leaving her behind when I go out. Any update on the plug and play connectors?
May 5th, 2009, 06:43 AM | #6 |
I'm still working on it. I've not yet had a chance to pull the tail off and take pics of the turn and brake connectors and wire colors. I did send them wiring diagrams on Friday and am actually hoping that is enough information for them.
Still awaiting a reply. |
May 13th, 2009, 06:36 AM | #7 |
Join Date: May 2009 Motorcycle(s): '09 Kawasaki N-250 + '09 Vulcan 900 Classic Lt Posts: A lot.
Nixed the Scorpio with all the splicing, etc. Grabbed the Gorilla Alarm.... install 5 minute hook up and 15 minute run of the wires. Located the "alarm box" in the storage beneath pillion seat. Price was right. Battery never drained and 7 sensitivity settings. Warn away has worked on many occassions. Decibel level of alarm decent enough.
June 24th, 2009, 11:28 PM | #8 |
09Ninja 250...HELP So any word on a 08 sr-i900 scorpio alarm HARNESS working on a 09?????? I dont wanna splice my wireing ): i think the two bikes (08/09) are the same but not 100% any clues will help?? thanks
June 25th, 2009, 05:39 AM | #9 |
IC2(SW)
Seems like you could of found all them pics posted around here
June 25th, 2009, 07:35 AM | #10 |
Welcome Winnie!
June 25th, 2009, 08:23 AM | #11 |
Join Date: Dec 2008 Motorcycle(s): 2008 250r (Fastest Color) Posts: 914
common they are more difficult to check connectors on. Can someone explain what the guy means by this? Isnt the 250 the number 1 selling kawasaki in the states? |
June 25th, 2009, 09:06 AM | #12 |
hmmm why is it so necessary to have all the lights blinkin, horn blarin and alarm sounding when its breached only to probably have a bigger drain on the battery and it seems connection issues vs. the get it now Gorilla alarm with paging system, little battery drain, reset, sensitivity settings and a hook up in 5 minutes bringing the whole thing to life!
June 25th, 2009, 09:31 AM | #13 |
To each their own addy, if we all liked and bought the same thing the little 250 probably wouldn't even be on the market. The thing I like about the 900 is (an I'm not sure what you call it) when the remote is a certain distance form the bike it automatically arms the system. No buttons to pushs, no remembering, simply walk away and it arms, approach and it un-arms. As for the lights flashing, I want all the attention possible being drawn to my ride in the event of a theft, and the scorpio has it's own internal siren, so it's not using the bike horn. With the connector, the alarm is simple plug and play unless you also get the iginition kill, and in that case it's a simple one wire splice.
As for the alarm, I ended up installing it on the Harley because Airtronix was taking so long in getting me answers on the connector. I did get them diagrams and pics of the connectors and they did send me a connector, but by then I was tired of waiting and already installed it on the Glide. I love the alarm and may buy another in the future if I come across another good deal. |
September 3rd, 2009, 12:28 AM | #14 |
Join Date: Aug 2009 Motorcycle(s): 09 Kawasaki Ninja 250R Posts: 3
Mining up old gold here, but if you can remember, were the connectors the right ones for the 09 model? I'm guessing they would be, but if you could confirm that'd be awesome. Thanks heaps mate.
September 3rd, 2009, 07:25 AM | #15 |
Regan, You'll have to check with Winnie as I passed the harness along. I ended up installing the alarm on the Harley while waiting on Scorpio to figure it out. So I do not know if it was correct or not.
December 30th, 2009, 10:14 PM | #16 |
Join Date: Dec 2009 Motorcycle(s): 2009 250r green(sold) 2009 zx6r green Posts: 96
i wonder where to get these cheap, and how cheap did you guys get it?
DIY and First Impressions: Scorpio i800 alarm | ninjabadger | 2008 - 2012 Ninja 250R Tech Talk | 7 | June 19th, 2013 10:15 AM |
Scorpio alarm i900 and integrated LED lights problem and fix | CThunder-blue | 2008 - 2012 Ninja 250R Farkles | 3 | April 7th, 2012 12:38 PM |
Scorpio SR-i1100 | blubyu | Motorcycle-related | 0 | May 10th, 2011 10:20 PM |
[superbikeplanet.com] - '80s GP Rider Alarm: Near Death Highside. '08 Rider Alarm: Un | Ninjette Newsbot | Motorcycling News | 0 | June 27th, 2008 01:41 PM |
