Old April 28th, 2009, 11:18 AM   #1
azia
Motorcycle(s): 08 Ninja 250
Steering seems loose??
Not sure if I'm being paranoid, but I feel like the steering is "loose" on the bike. I can turn left to right with very little pressure and while I'm riding it feels like the bike is doing a very slight fishtailing. When I stop I use some rear break but anything more than a coasting stop I fishtail.
I lowered my bike last month - front and back. Was out riding last night and one guy told me it might be because my forks aren't level. That when I tightened the bolts back on after putting in the lowering blocks, I might have tightened one down more than the other causing one fork to be slightly higher than the other. Could this be the issue?
I'm thinking the other possibility is that my tire pressure is low. Would this be a symptom? I'm going to go buy a gauge tonight anyways as I () haven't checked it all month.
azia is offline   Reply With Quote
Old April 28th, 2009, 12:00 PM   #2
I'd check tire pressure, if it's significantly off it could be showing the symptoms you describe. I'm not sure how the individual forks would be at different heights; they are connected at the bottom via the axle, and while it's not the thickest axle on our ninjettes, I'd think it's still sturdy enough to keep the forks in line.
Old April 28th, 2009, 12:30 PM   #3
azia
Hey Alex, thanks. I will check the tire pressure tonight. I suspect that might be the issue (or should I say...I am HOPING that might be the simple solution? heheh).
As for the forks, I didn't really understand him either. Lol!
Old April 28th, 2009, 12:46 PM   #4
komohana
komohana's Avatar
Motorcycle(s): 05 GSX-R 600 2003 EX250: Woodcraft Bars, Levers, Mirrors, Shim'd Mixture, Synthetic, '08 Rear Shock
just a thought...could suspension settings cause any of that?
Remember when sex was safe
and motorcycles were dangerous?
komohana is offline   Reply With Quote
Old April 28th, 2009, 12:52 PM   #5
Snake
Snake's Avatar
I would bet that it is tire pressure.
Old April 28th, 2009, 01:00 PM   #6
azia
fortunately, i didn't change the suspension and since this problem just started last month i can rule that out.
Old April 28th, 2009, 01:31 PM   #7
randomwalk101
self wrencher
randomwalk101's Avatar
get a steering damper...see the other thread
Old April 28th, 2009, 03:48 PM   #8
my guess would be tire pressure, too.
Old April 29th, 2009, 11:24 AM   #9
azia
Checked the tire pressure this morning and it was 27/31. I don't remember 100% but I think it's actually 31 in the front, 27 in the back which is 1 psi less AND completely opposite of what it should be.
Will check again tonight to see if I'm just going bonkers or if this could be the reason....
Old April 29th, 2009, 12:15 PM   #10
Nemy
Nemy's Avatar
Motorcycle(s): 2009 SE Ninja 250R
Well a reversed tire pressure would still mean you're going bonkers
Does it feel completely different than before you had the lowering kit/forks done?
Nemy is offline   Reply With Quote
Old April 29th, 2009, 01:11 PM   #11
azia
Lol! See, the problem is, I lowered it AND took it to a mechanic before riding this season so I'm not sure if I'm just paranoid or if it's really a difference from last year either due to lowering or maybe the mechanic tried to put more air in my tires.
I don't think that 1 psi makes enough difference for me to notice....
I'll report back later tonight.
Old April 29th, 2009, 04:51 PM   #12
I don't think the tire pressure was enough off to make that much of a difference in what you were feeling. If the front or rear was 15 psi, or maybe 45+ psi, then maybe something would start to feel particularly strange. But a couple psi here or there would be much harder to notice, and IMO would be unlikely to cause what you described.
Old April 29th, 2009, 04:58 PM   #13
it could... depending on what she's feeling.
also, did someone adjust your chain lately?
Old May 1st, 2009, 01:01 PM   #14
azia
Dammit, the tires are right (just 1 psi low though).
My chain seems to be fine, but I'll double check tonight. This is not a huge issue but again today I felt several times when I break (I tried using just front and then front and a little bit of rear) the front sticks but the back very slightly feels like it's swaying to the right. Sighhh...
Meeting some of my girls tonight one of whom is a mechanic. See what she says... I wonder if the answer will be "Yes Lindsay, it's just your paranoia"
Old May 1st, 2009, 01:04 PM   #15
Is it possible that you're locking up the rear wheel? Do you feel the rear of the bike sliding in either direction if you just use the front brake?
Old May 1st, 2009, 01:09 PM   #16
azia
^ To test it out, I tried using just front or front and only light pressure on rear and same thing still happens...
Will check with my friend tonight and get my bf to try riding it to see if he notices....that should eliminate if it's a real problem or just me.
Steering Stem Head Bolt Loose kremtok 2008 - 2012 Ninja 250R Tech Talk 10 June 7th, 2013 12:30 PM
Loose Feeling csmith12 General Motorcycling Discussion 16 May 7th, 2011 10:37 PM
loose tubing? onizthegnome 2008 - 2012 Ninja 250R Tech Talk 2 November 29th, 2010 03:37 PM
Throttle Loose blanco 1986 - 2007 Ninja 250R Tech Talk 8 October 17th, 2010 10:10 AM
Lowered back, Loose steering atl-ninja250 2008 - 2012 Ninja 250R Tech Talk 4 July 19th, 2010 07:48 AM
