Old June 7th, 2014, 01:50 PM   #1
shaggy
shaggy's Avatar
Motorcycle(s): 04 KTM 200EXC, 05 Yamaha XT225, 09 Ninja 250, 94 Ninja 250, 87 DR200
Intake valve clearance 04 Ninja 250
I have been able to adjust 7 out of the 8 valves on my 04 Ninja 250. The 8th is the 1st intake on the right side (timing chain side). No matter what I do I can not get any clearance between the lifter and the cam lobe.
The valve does not seem to be bent and moves freely when the engine is rotated.
Any ideas?
Thanks!
shaggy is offline   Reply With Quote
Old June 7th, 2014, 02:06 PM   #2
Old June 7th, 2014, 03:15 PM   #3
EMSRacer07
EMSRacer07's Avatar
Any ideas?
Thanks!
sometimes the valves run out of clearance, usually its the earlier models and high mileage engines. I think its suggested to check the rocker arm for wear. Someone can chime in. But when my 1990 engine did this I changed out the rocker arms bc they had alot of wear on them, 5 of my valves had no more adjustablity left
Old June 7th, 2014, 03:41 PM   #4
Ninjinsky
Ninjinsky's Avatar
Check carefully that the rocker is seated properly with one "ear" each side of the valve head.
I just made that mistake and it was very expensive £44 for a new rocker,
Old June 7th, 2014, 05:31 PM   #5
shaggy
shaggy's Avatar
Thanks......
I suspect this is the cause. I will change the rocker and see......
Thanks!
Old June 7th, 2014, 05:33 PM   #6
shaggy
shaggy's Avatar
Thanks........
I did check the rocker seating on the valve/spring collar. All was as it should be.
Good thought! Thanks.....
Old June 7th, 2014, 05:54 PM   #7
I did check the rocker seating on the valve/spring collar. All was as it should be.........
Please, be aware of this:
http://n4mwd.blogspot.com/2013/06/ov...ts-during.html
valve clearance sharky nrk 2008 - 2012 Ninja 250R Tech Talk 8 July 18th, 2014 06:19 AM
Should I do the valve clearance inspection myself? nickjpass The Ex-Ninjetters Lair 13 June 13th, 2014 12:50 AM
What is the Optimal Valve Clearance? krolinked 2008 - 2012 Ninja 250R Tech Talk 2 March 15th, 2013 02:25 AM
Valve Clearance Problem ElJokerr 1986 - 2007 Ninja 250R Tech Talk 9 February 22nd, 2013 12:40 PM
valve clearance??? what are they supposed... ecannon1 1986 - 2007 Ninja 250R Tech Talk 3 May 20th, 2010 10:41 AM
