July 10th, 2014, 01:04 PM | #1 |
Join Date: Jul 2014 Motorcycle(s): 04 Ninja 250 Posts: 42
CARB Dropped and Busted Fuel Inlet - Suggestions?
Dummy dropped my carb last night and busted the plastic piece where the fuel line connects to the left side of the carb. It is black plastic and shows on the fiche as part of the body. Ron Ayers confirms it is not sold as a separate part and a body is $360. Any creative SAFE solutions to fix this, or is my carb deader than Elvis?
Is it worthwhile to go ebaying for a complete carb? Seems like throwing away a large assembly for one small piece. Thanks |
July 10th, 2014, 01:07 PM | #2 |
maybe you could ebay a full carb and take the piece and sell it again on ebay sans connecting piece for someone to use as parts?
July 10th, 2014, 01:18 PM | #3 |
It's a somewhat common problem, but there is a fix.
Read this, it may help you- Quick CV Carb Fix http://www.johnsmotorcycleparts.com/fuel_elbow.htm |
July 10th, 2014, 02:19 PM | #4 |
Thanks
First body I saw on fleabay is $40 and complete carbs start at $150. Inlet valve alone is $10 plus S&H. Deal!
May even order the Hardly part, just to mess with Hardly guys. |
July 10th, 2014, 02:19 PM | #5 |
Join Date: Jan 2012 Motorcycle(s): Race bikes:08 Ninja 250,11 R6,16 ZX6,SV650.3 HD-1947,2-2003,2010. 1946 Indian and a lot of dirt bikes.2 Posts: 999
The above fix is for harley carbs. It is a new elbow that is all brass, no more plastic. I have repaired several of these recently. If you are handy you can pull the old brass fitting out of your carb and see if the harley piece will fit. You can get them from the local HD dealer for about $12
July 10th, 2014, 02:37 PM | #6 |
Incomplete carbs and carbs with bad diaphrams are practically free trash due to there being a glut in the market (torn diaphrams are more expensive to replace than simply buying complete used carbs). Look for a good deal on one of those and transplant your good parts.
July 10th, 2014, 03:19 PM | #7 |
Harley part number 27371-76A for the replacement elbow. If you dont want to go through the trouble PM me I have a carb body.
July 15th, 2014, 09:32 AM | #8 |
The 2 Stroke Ninja!!
Join Date: Feb 2012 Motorcycle(s): 2010 250R, 1977 RD400, 72&73 RD350 75 RD200 Posts: 79
Even easier....
I have done a bunch of these and you do not need to make a puller. You simply need to break off any remaining plastic, grab the brass that's left with a vice grip, and while rotating it back and forth pull it out. It will take about 30 seconds to wiggle it out. If it is especially tight you can put a flat head screwdriver under vice grip and gently pry up on the fitting/vice grip while you rotate it back and forth.
Here's the catch: In order to grab the brass with enough force to rotate it and wiggle it out without the pliers slipping, you will most likely collapse(crush) it. This will lead to it breaking off inside the carb body creating a worse problem. This is why most articles tell you how to thread the brass and make a puller. Here's the fix: Slip a drill bit, bolt, or piece of metal rod inside the brass. I usually use a drill bit and use the end that clamps into the drill chuck, not the cutting end. Make it a close fit, but a little loose is OK. Now, when you clamp down the vice grip it will start to deform the brass slightly, but only until it contacts the drill bit. Then it will clamp tightly against it and you can make the vice grip as tight as you want without crushing it. I have done this probably 20 or 30 times over the years working on Harley carbs and it takes less time to get the old fitting out than it took for me to type this!! |
July 15th, 2014, 01:59 PM | #9 |
How do you press the new fitting in?
July 18th, 2014, 07:12 PM | #10 |
Sorry..I missed your last question. Using a "C" clamp or vice with soft jaws will work just fine if you are using the all metal replacement fitting.
If you are using the stock fitting (plastic over brass) you need to be more careful or you will crack the plastic again. On them I usually use a piece of SOFT wood (pine usually) against the fitting and tap it in with a small hammer. Go slow and take your time and it will be easy. On the plastic fitting you can use the "C" clamp with a piece of soft wood to cushion it as well but you need to go slow and it MUST be perfectly straight going in as well as the clamp being perfectly square to the fitting. No matter what you will need to use a bit of judgement and "feel" to make sure you are not hurting anything. Also...absolutely make sure it is going in straight and is clocked at the position you want it to end up in before you start pressing or tapping it in. |
Fuel coming out the carb, and bike wont start | scorch | 2008 - 2012 Ninja 250R Tech Talk | 35 | February 13th, 2014 11:33 AM |
Broke Carburettor Fuel Inlet | indr | 2008 - 2012 Ninja 250R Tech Talk | 4 | May 1st, 2013 01:30 PM |
fuel inlet tube on carb cracked or loose? Leaks gas! | sherwiner | 1986 - 2007 Ninja 250R Tech Talk | 5 | April 11th, 2012 02:57 PM |
Adjusting the carb to let more fuel in? | 2fiddy | 2008 - 2012 Ninja 250R Tech Talk | 3 | May 16th, 2011 11:20 AM |
Fuel Smell+Dropped it | snowboardenc | 2008 - 2012 Ninja 250R Tech Talk | 6 | May 19th, 2009 08:27 PM |
