Old July 14th, 2014, 12:03 AM   #1
RandomPhantom
The Motorcycle Newb!
RandomPhantom's Avatar
Motorcycle(s): 2010 Ninja 250R (Red/SOLD), 2008 Ninja 250R (Black/SOLD), 2005 ZX6R (Black)
Light bulb and Gauge bulb options
My low beam bulb died on me and also the lights that illuminate my tach and speedometer is both out as well. What options do i have to replace these? Im looking for those bright white bulbs with a hint of blue in them. Also what parts number would i be looking for?
Thanks in advanced!
RandomPhantom is offline   Reply With Quote
Old July 14th, 2014, 12:14 AM   #2
Much of that should be in this thread:
https://www.ninjette.org/forums/showthread.php?t=11738
Old July 15th, 2014, 12:51 PM   #3
kennetht
kennetht's Avatar
I have the exact thread you will want to look at, as I just recently changed my dash to LEDs
https://www.ninjette.org/forums/showthread.php?t=169472
I bought my LEDs from here:
http://www.ebay.com/itm/111197894979
kennetht is offline   Reply With Quote
Old July 15th, 2014, 06:31 PM   #4
Skullz
Skullz's Avatar
Motorcycle(s): 2012 Ninja 250
The one thing you do not want to change to LED is the turn signal light as it will only work with one side or the other, keep that one as it is and the rest will look awesome.
Old July 15th, 2014, 06:33 PM   #5
kennetht
kennetht's Avatar
That is not true....
My turn signal light is LED and it works both sides.
Old July 16th, 2014, 11:04 AM   #6
InvisiBill
EX500 full of EX250 parts
InvisiBill's Avatar
With a diode kit (generally aimed at LED blinker use), it will convert the dash indicator to having specific + and - wires, so an LED will work.
In the stock setup, it's just tied to both sides' + wires, so it's +- when the left blinker is on and -+ when the right blinker is on. An LED bulb with polarity physically cannot work both ways.
Old July 19th, 2014, 11:55 PM   #7
RandomPhantom
So i found the 12v 55w H7 bulbs for my headlamp do these work? http://www.walmart.com/ip/BulbAmeric...-Bulb/37683386
Now the only problem i have been running into is finding the 12V 3.4W T10 bulbs for my tach and speedo backlights. Can anyone help link me to a sight where i can just buy a pack for cheap?
Old July 20th, 2014, 10:17 AM   #8
Originally Posted by RandomPhantom View Post
.........Now the only problem i have been running into is finding the 12V 3.4W T10 bulbs for my tach and speedo backlights. Can anyone help link me to a sight where i can just buy a pack for cheap?
If those are the same for the pre-gen (#194):
http://www.walmart.com/ip/Sylvania-1...-Bulb/16913641
http://www.autozone.com/autozone/par...entifier=59018
http://faq.ninja250.org/wiki/Replaci..._cluster_bulbs
Old July 21st, 2014, 08:34 AM   #9
kennetht
kennetht's Avatar
Old July 22nd, 2014, 01:45 PM   #10
RandomPhantom
Thank you both very very much
Old August 20th, 2014, 05:48 PM   #11
But *two* LEDs can.
Connect each anode to a cathode then stuff two in there.
Old August 21st, 2014, 10:06 AM   #12
InvisiBill
InvisiBill's Avatar
Originally Posted by CZroe View Post
But *two* LEDs can.
Yup, then one would work for the left blinker and the other would work for the right blinker. If you positioned them carefully, your single indicator could now actually indicate which side was on even.
If you wire up the green and gray wires at the indicator to the anodes (+) of two LEDs and add another wire to ground the cathodes (-), you would have the same LED-per-side setup, plus the effect of a diode kit. Instead of grounding through to the other side's blinker circuit (and therefore causing your new LED signals to light up on both sides), each side would ground through the added wire and be blocked from hitting the other side by that side's LED (since it's a diode).
I was trying to think up some sort of PnP male-female bulb adapter thingy that could be used to easily replace the stock bulb with LEDs and add the ground wire, but I haven't been able to figure out anything easier/cheaper than Tri's diode kit.
Does dead taillight bulb affect the license plate bulb? headshrink 2008 - 2012 Ninja 250R Tech Talk 5 April 3rd, 2013 06:05 AM
bulb options? azimmer11 2008 - 2012 Ninja 250R Tech Talk 1 August 10th, 2012 07:24 AM
Side light bulb dave hendy 2008 - 2012 Ninja 250R Tech Talk 9 February 7th, 2011 06:10 AM
WTB: Replacement bulb. Upgraded to HID? Sell me your old bulb! CZroe Items Wanted 7 October 25th, 2009 03:58 PM
speedometer gauge light bulb? jiggawuah 2008 - 2012 Ninja 250R Tech Talk 2 May 7th, 2009 02:17 AM
