July 24th, 2014, 09:50 AM | #1 |
Join Date: Jul 2014 Motorcycle(s): 1996 ninja 250 Posts: 49
Clutch problems
Just had my clutch cable snap last week so got the new cable installed with the 2-3mm of play suggested but as I pull the clutch to the bars and push the bike forward in 1st the gear is still engaging slightly and makes the bike hard to push forward. Haven't started it after the break because I'm getting the tank welded and need new hoses ect. Feels as though the clutch arm isn't being pulled up enough but when I tighten it the problem is arises
July 24th, 2014, 09:54 AM | #2 |
Join Date: Feb 2014 Motorcycle(s): Rebel 250s, Ninja 250s VN750s (currently nine total) Posts: 465
You may need to adjust the cable where it attaches to the engine.
July 24th, 2014, 10:01 AM | #3 |
July 24th, 2014, 11:30 AM | #4 |
The clutch cable is #54011 in this diagram: http://www.cheapcycleparts.com/oempa...478cdd6/clutch
You may need to adjust the lower end of the cable. I believe there is a procedure in the service manual, but don't have mine handy at the moment. |
July 24th, 2014, 11:48 AM | #5 |
Yeah I don't have a service manual and need to know what's going on and how to fix it
July 24th, 2014, 12:08 PM | #6 |
See this thread-https://www.ninjette.org/forums/showthread.php?t=173030
July 24th, 2014, 12:21 PM | #7 |
Thanks, Blue. That should help him fix the problem!
July 24th, 2014, 12:24 PM | #8 | |
July 24th, 2014, 12:25 PM | #9 |
I've looked at that the one thread on adjusting the cable to and did everything it told me to do
July 24th, 2014, 12:34 PM | #10 | |
July 24th, 2014, 02:10 PM | #11 |
I don't think so everything is the same as is was before I took off the old cable
July 24th, 2014, 03:08 PM | #12 |
Why is the bike barely able to move when it's in first and the clutch is pulled in. Is the cable to tight or to loose
July 24th, 2014, 04:40 PM | #13 |
Join Date: May 2013 Motorcycle(s): '92 GPX 250 (Gone and replaced with '08 V-Strom), 2005 Suzuki C50. Posts: 186
There will be resistance, especially when cold. Start the engine, put into gear and check where your friction point is. If you follow the procedure you should be right.
Originally Posted by jgcable; I ride a 2006 Custom HD Wideglide..... and I almost have to sign autographs when I park it. |
July 24th, 2014, 05:08 PM | #14 |
July 24th, 2014, 05:10 PM | #15 |
Also bike can't be started atm the tank is out being welded and I need a new vacuum hose the old one tore
July 25th, 2014, 07:16 AM | #16 |
Join Date: Apr 2014 Motorcycle(s): 1980 Yamaha XS850G Midnight Special, 32k Miles; 2000 EX250F, <5000 Orig Miles Posts: 98
just chill until you can start the bike. I thought something was seriously wrong with mine, doing the same thing as yours... until I was able to start the engine, let it warm up.. then the clutch discs separated more and it worked as I thought it should.
The cold clutch, even with the lever squeezed all the way, while in gear, will stick and bind and make it feel as though it isn't disengaging. |
July 25th, 2014, 10:55 AM | #17 |
Ok that makes total sense I'll see what happens when I do start it and let it warm up
Ninja having clutch and shifting problems | Jamestherider | 1986 - 2007 Ninja 250R Tech Talk | 2 | July 21st, 2014 11:19 AM |
Possible Clutch Problems? | Daks | 1986 - 2007 Ninja 250R Tech Talk | 8 | June 14th, 2013 06:34 AM |
clutch release problems | big duke | 1986 - 2007 Ninja 250R Tech Talk | 3 | November 17th, 2011 01:11 AM |
Clutch/Clutch lever problems | zca4 | 2008 - 2012 Ninja 250R Tech Talk | 1 | August 5th, 2011 03:40 PM |
clutch problems. im new HELP | mr.jake | 1986 - 2007 Ninja 250R Tech Talk | 14 | December 23rd, 2010 10:02 AM |
