Old August 27th, 2014, 07:50 PM   #1
james250ninja
james250ninjette.newbie
james250ninja's Avatar
Motorcycle(s): 1986 ninja 250
Smile carb clean and shimming 86 ninja 250
hi everyone
can I shim my 250 im goanna leave it stock and how many washer..??
also I cleaned my carbs real good change my vacuum diaphragm I used one from 2000 ninja 250 great condition EVERYTHING PUT BACK TOGEATHER PROPERLY
question MY BIKE RUNS GREAT BUT SLIGHT LEAN WHILE DRIVING IS IT POSSIBLE TO HAVE YOUR BIKE DRIVE SLIGHT LEAN AFTER GOOD CARB CLEAN
OH I DID USE ONE WASHER TO SHIM, JUST WANT TO MAKE SURE U CAN SHIM A STOCK BIKE
james250ninja is offline   Reply With Quote
Old August 28th, 2014, 06:57 AM   #2
Generally they all benefit from running a little richer than stock in the mid-range. 1 or 2 shims is about right.
Did you adjust the idle mixture screws? They are set lean from the factory also. If you feel it's lean at smaller throttle openings, that's what you need to adjust.
Start at 2 1/2 turns out on the screws. You can also adjust for the highest RPMs, then go just slightly richer (1/8 out or so).
Chances are the carbs need to be synced. If they are not synced no amount of adjusting will get you good results.
Old August 28th, 2014, 07:33 AM   #3
james250ninja
Smile
everything stock carbs were synch,
though someone drill out the idle mixture caps..
Shimming the Carb Needles... Is it for You? kkim 2008 - 2012 Ninja 250R Tech Talk 93 June 10th, 2018 05:25 PM
Valve adjustment, carb clean, carb sync? amad1972 1986 - 2007 Ninja 250R Tech Talk 2 July 29th, 2014 09:42 PM
Shimming the carb needles kfilla General Motorcycling Discussion 2 July 2nd, 2014 06:14 PM
Washers for carb shimming broilmebk Free stuff! 1 June 15th, 2014 02:56 PM
Need help on shimming carb needles RedNinja21 2008 - 2012 Ninja 250R Tech Talk 6 October 27th, 2011 10:16 AM
