Old October 5th, 2014, 06:25 PM   #1
doyler
Motorcycle(s): R6
Changing brake pads - can't get enough space to reinstall
After putting new front brake pads on I can't seem to get enough space between them to put the caliper back on the rotor. I've tried using a c-clamp to push the pistons down but by the time I've put the pads and allen bolts back on they've come back up too much to fit.
Any tips or tricks to get the pistons to stay down?
doyler is offline   Reply With Quote
Old October 5th, 2014, 06:27 PM   #2
Matto55
Motorcycle(s): 2009 Kawasaki Ninja 250; 1999 Kawasaki Klx300R
Are the pistons coming back up once you have pushed them down? I feel that once you have them pushed in they shouldn't come back out unless you apply the brake..
Matto55 is offline   Reply With Quote
Old October 5th, 2014, 06:29 PM   #3
allanoue
allanoue's Avatar
MOTM - Sep '14
c-clamp
use the old pads to cover the cylinder and a piece of thick cloth for the other side of the caliper. Push the cylinder all the way in until it is flush with the caliper before you install the new pads.
Old October 5th, 2014, 06:30 PM   #4
doyler
Motorcycle(s): R6
Yeah they come back up maybe a centimeter or so - just enough to make it not fit...
Old October 5th, 2014, 06:31 PM   #5
doyler
Motorcycle(s): R6
Originally Posted by allanoue View Post
c-clamp
I used a c-clamp to push them flush but they come back up just enough to make it not fit.
Old October 5th, 2014, 06:38 PM   #6
allanoue
allanoue's Avatar
MOTM - Sep '14
Get it recessed then
Old October 5th, 2014, 06:39 PM   #7
Matto55
I think your best bet is to try it again with the old brake pad up against the piston, then use the c clamp to push it all the way back so it is flush with the caliper.
Old October 5th, 2014, 08:01 PM   #8
Klondike1020
Intrepid Adventurer
Klondike1020's Avatar
Something is not right with your setup. Your pistons should not push back out. try opening the fluid reservoir while you do it. be ready for some to over flow. It sounds to me like you are compressing the air in the reservoir when you use the C clamp. So it springs back out when you release it.
Let me know what happens when you crack the reservoir open and compress the ppistons with the clamp
LIFE IS NOT FOR REGRETS OR EXCUSES.
Breath deep, seek peace.
Embrace the Madness. Life is good, let it be
My ever changing garage space occupants "A" The Ex-Ninjetters Lair 116 October 26th, 2018 11:31 AM
Cant find brake bolt connecting brake pads. Trubin General Motorcycling Discussion 6 June 3rd, 2014 05:35 PM
Replacing brake pads and brake fluid Bones85 2008 - 2012 Ninja 250R Tech Talk 4 April 28th, 2013 06:25 PM
Emergency: Need Help Changing Brake Pads (Oil Squirted Out) Francis 2008 - 2012 Ninja 250R Tech Talk 32 May 17th, 2012 09:59 PM
changing brake pads ladyninja08 2008 - 2012 Ninja 250R Tech Talk 19 July 9th, 2009 08:52 AM
