October 18th, 2014, 03:40 PM | #1 |
Join Date: Sep 2014 Motorcycle(s): 2004 Ninja 250 Posts: 342
Bike got wet in the rain.
I took my bike to work and it rained all day. Is there maintenance that should be done?
Before life ends, Some people want to climb Mount Everest, some want to go to Disney Land, some people want to visit Paris. Me, I want to ride a motorcycle. |
October 18th, 2014, 03:49 PM | #2 |
Join Date: Aug 2014 Motorcycle(s): 2007 Ninjette Posts: 809
No
"That's what" -she |
October 18th, 2014, 04:18 PM | #3 |
If the brake discs get rusty they will lose the rust. If chain is rusty might want to oil it. That's it.
October 18th, 2014, 05:02 PM | #4 |
Ride it. It is very angry with you and deserves some love. Make up date
October 18th, 2014, 05:09 PM | #5 |
#squid
Join Date: Jul 2011 Motorcycle(s): Track dedicated 2008 ZX6R Posts: A lot.
MOTM - Jul '16
whenever your bike gets wet you'll want to lube everything that gets lubed. Examples are chains, swing arm pivot, cables, etc. Time consuming but I just do it after I wash my bike. If I'm riding in the rain often, like me, I'll just spray chain lube on the drivetrain after a ride. I dont carry about it looking ugly since I'd be riding it again in the wet conditions.
October 18th, 2014, 06:32 PM | #6 |
ran when parked
Join Date: Aug 2013 Motorcycle(s): Freeride 250R, KLX250SF, mopeds Posts: A lot.
MOTM - Sep '17, Dec '14
check to make sure nothing melted or dissolved.
parts that usually melt include: headlights taillights handlebars rearsets gas tank bolts sidestand switches clutch levers 2nd gear the underside of your tires parts that usually dissolve include: chain rollers sprocket teeth bar end screws ignition coils left side piston rear fender front left brake pad hope nothing's ****ed! |
October 18th, 2014, 06:35 PM | #7 | |
Join Date: Aug 2013 Motorcycle(s): 2012 Ninja 250 Posts: 450
I thought the rider melted? |
October 18th, 2014, 06:58 PM | #8 |
The only thing I noticed was that it took longer to start and when I put it in first gear, it would immediately turn off. I messed around with the clutch, took it to 2nd, then back down to first, and then it worked. Strange. Maybe someone was messing with my clutch. Last time, kids were sitting on my bike while their parents took pictures. Another guy molested my bike by sliding his hand all over the side. I am a cook in a restaurant so my bike gets plenty of publicity.
October 18th, 2014, 07:01 PM | #9 |
ran when parked
was your kickstand down?
Instagram: @katie.baden |
October 18th, 2014, 07:11 PM | #10 |
Yes it was down. It didn't fall or anything. Why?
October 18th, 2014, 07:23 PM | #11 |
Que Buenos Son!!!
MOTM - Nov '14
It's totaled!.. I'll take it off your hands for a small fee.
October 19th, 2014, 03:58 AM | #12 |
Join Date: Apr 2014 Motorcycle(s): Ninja 250, Yamaha RS200 (classic) Posts: A lot.
I rest my case
October 19th, 2014, 05:39 AM | #13 |
The part about it being in gear is why it would keep shutting off. There's a series of switches that keep the bike from running when it's not safe to ride. IE, kick stand down, in gear, letting the clutch out. Same thing cars do.
One of your switches may be a little sticky, causing the shutoff feature to not work completely as intended. It's fairly normal and your switches probably just need a little squirt of lube. nbd. |
October 19th, 2014, 09:01 AM | #14 | |
Thank you. Best advice on this thread. I know intermediate mechanical work on cars and some of the things with the motorcycle are the same but sometimes I will encounter something new. How do I lube the shift lever? If that`s what it`s called. It does stick at times. Sometimes at red lights, I down shift and it will stay stuck on 2nd or won`t go all the way back down to first.
October 19th, 2014, 09:11 AM | #15 |
That make up date though...Still got to have a make up date with my wife for getting the bike but I didn't leave her out in the rain so it can wait a little longer. She`s warming up to the bike and I`m trying to get her interested in riding. Just trying to get my skills up, take the MSF course, have my complete gear before I go around trying to teach her how to ride.
October 19th, 2014, 04:42 PM | #16 |
Join Date: May 2013 Motorcycle(s): '92 GPX 250 (Gone and replaced with '08 V-Strom), 2005 Suzuki C50. Posts: 186
Consider it washed and ride it.
Originally Posted by jgcable; I ride a 2006 Custom HD Wideglide..... and I almost have to sign autographs when I park it. |
October 19th, 2014, 05:07 PM | #17 |
Participant
Join Date: Oct 2012 Motorcycle(s): '94 K75 std Posts: Too much.
October 19th, 2014, 05:57 PM | #18 |
Join Date: Aug 2011 Motorcycle(s): Honda Elite 110 (deceased), Green 2012 Ninja 250 (sold on Pi day); Grey/Green 2019 Ninja 400 ABS Posts: 238
I find that after a time out in the rain, my front brakes get a bit of rust and I get off-throttle squeak. Scrubbing the rust off by strong braking resolves that (obviously not while it's still raining).
[roadracingworld.com] - Rain Brings Wet End To FIM Moto2/Moto3 Testing At Jerez | Ninjette Newsbot | Motorcycling News | 0 | February 21st, 2013 12:50 PM |
[kropotkin thinks...] - 2012 WSBK Assen QP2: Wet, wet, wet | Ninjette Newsbot | Motorcycling News | 0 | April 21st, 2012 02:50 AM |
[kropotkin thinks...] - More Testing, More Rain: Wet Weather Washes Out Portimao WSBK | Ninjette Newsbot | Motorcycling News | 0 | November 29th, 2010 03:40 PM |
[sportrider - features] - Wet Weather Motorcycle Riding - Rain, Rain | Ninjette Newsbot | Motorcycling News | 0 | May 18th, 2010 03:30 AM |
[sportrider - latest stories] - Wet Weather Motorcycle Riding - Rain, Rain | Ninjette Newsbot | Motorcycling News | 0 | April 14th, 2010 04:50 PM |
