Old October 21st, 2014, 03:51 PM   #1
MrAtom
MOTM - July '15
Headlight question
Buddy of mine has an 04 GSXR headlight he said I could have if it'd fit my bike. Now, it looks like it'll just plug and play and the only thing I'd need to do is worry about mounting. Normally, I'd just try it out, but I don't want to fry his part if it doesn't work. It has the same kind of plug as my stock pregen light (I think). Can I just plug it in and use it? What would I need to do to make it work? Is it more trouble than it's worth? Thanks. Sorry I make so many threads :P (I did go spelunking in the search option but could find nothing that was particularly helpful.)
Old October 21st, 2014, 03:54 PM   #2
lol, not gonna fit that fairing. pass on it.
Old October 21st, 2014, 03:58 PM   #3
MrAtom
MOTM - July '15
I know THAT haha. Without the fairing :P
Old October 22nd, 2014, 10:07 PM   #4
PHMCS
Phoenix Salvage
Motorcycle(s): 2007 Ninja 250R
Looking at parts diagrams/fiche, all GSX-R 600/750/1000s in 2004 use a dual bulb headlight assembly, which appears to be either h4 low/h7 high beam, or h11 low, HB3/9005 high.
The pregen ninja only uses a single H4. (the EX-J uses a dual bulb config)
To get both functioning, would likely require some wiring work since you'll be short a connector.
if you're just looking to hook up just one and run it as a high/low, i guess you could do it, but you'd be giving up lighting performance and might run into some aiming issues.
See my current inventory of used parts for sale here
PHMCS is offline   Reply With Quote
Old October 22nd, 2014, 10:34 PM   #5
MrAtom
MOTM - July '15
He sent it out to me, anyway. He said I'd be fine macgyvering it. Just to keep an eye on the temperature/don't start any electrical fires. My bike's kind of a turd, so I don't mind doing things like this to it. All in the name of fun and polishing my turd.
Thanks for the heads up. With the mounting setup I had in mind, I didn't even consider aiming it. And there's a lot of other issues that come with how well it'd perform, like you said. This is gonna be a real pain, and probably more trouble than it's worth, but he already sent it out to me, so I guess I'm obliged to figure it out now :P
headlight swap question? Towner 2008 - 2012 Ninja 250R Tech Talk 1 July 20th, 2013 10:20 PM
Headlight Retrofit Question 2fidyswag 2008 - 2012 Ninja 250R Tech Talk 36 April 4th, 2013 02:17 PM
Headlight Retrofit Question 2fidyswag 2008 - 2012 Ninja 250R Tech Talk 7 March 13th, 2013 01:43 PM
Headlight question Malicious Logic 2008 - 2012 Ninja 250R Tech Talk 8 September 10th, 2012 07:36 PM
Headlight Question. BSNinja250 2008 - 2012 Ninja 250R Farkles 11 January 20th, 2010 10:24 AM
