Old November 16th, 2014, 08:59 PM   #1
Ninja Rob
Ninja Rob's Avatar
Motorcycle(s): 2004 Ninja 250
Broken throttle cable
My throttle cable snapped off. It has a push and pull side. It is the cable that closes the throttle. Does anyone know if it is the push or pull? In my previous posts my bike was not working but now it is and I am happy. I took it for a ride around the parking lot then it started raining so it's back to the carport.
Before life ends, Some people want to climb Mount Everest, some want to go to Disney Land, some people want to visit Paris. Me, I want to ride a motorcycle.
Ninja Rob is offline   Reply With Quote
Old November 16th, 2014, 09:08 PM   #2
Rifleman
Old and slow
Rifleman's Avatar
Motorcycle(s): Suzuki TL1000R, Honda CBR600F3, Ninja 250
Don't ride it like that... it is fully possible to get the broken cable jammed inside the grip housing in the "open" direction...
you can operate with just the "pull" cable... older bikes used to have just one and spring return to idle...
but the best and correct way is to replace the broken cable.
Either RonAyers.com or you can look for a set on Ebay...
I can't say it enough, running it like this is dangerous, don't do it, you can hurt yourself, or worse, hurt someone else.
oh sorry, that is the "return to idle" cable, pulls the throttle closed when you roll the grip forward.
Rifleman is offline   Reply With Quote
Old November 16th, 2014, 09:27 PM   #3
Ninja Rob
Ninja Rob's Avatar
Thanks. I appreciate your genuine concern. Would you know the part number by chance?
Old November 16th, 2014, 09:32 PM   #4
Gurk
Done here.
Motorcycle(s): -
Yep. Broken cable is no no. Better to cut it off and just work with pull cable.
This is not the safest thing to do I guess but I cut my "push" cable off on my R6 a while ago. No matter how I route it, push cable makes the throttle not snap back to off throttle position fast enough. With just the pull cable it works perfectly so I've been riding like that for some time now.
Gurk is offline   Reply With Quote
Old November 16th, 2014, 09:45 PM   #5
Ninja Rob
Ninja Rob's Avatar
I do not mind buying the cable. After some googling, is it just one cable? It seems like it is. Or is it two individual cables?
Old November 16th, 2014, 10:09 PM   #6
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
it is one cable, but it does look like the other cable is still intact
TEAM ALFALFA
www.apexassassins.com
Old November 16th, 2014, 10:20 PM   #7
Ninja Rob
Ninja Rob's Avatar
This is the part I bought. The open cable is intact. The closing one is not.
The one I bought. From ebay, not partzilla.
http://www.partzilla.com/parts/detai...4012-0080.html
Last futzed with by Ninja Rob; November 16th, 2014 at 10:21 PM. Reason: because
Old November 17th, 2014, 08:24 AM   #8
Rifleman
Old and slow
Rifleman's Avatar
I think the one you ar elooking for is on this page @ RonAyers.com
http://www.ronayers.com/Cables-C401969.aspx
Old November 17th, 2014, 08:33 AM   #9
Rifleman
Old and slow
Rifleman's Avatar
there are two cables, but I think you can purchase just the pull or the push, don't have to get them as a pair.
each cable pulls, (you can't push a cable, well not very well)
when you twist open... the "open" cable pulls the throttle butterflies open.
when you twist closed... there is a "close" cable that pulls the butterflies closed.
mind you there is a big spring that closes the butterflies, but manufactures added the "close" cable in case something happened to that spring or something got sticky...
a full on cable to pull things closed if something went sideways...
this is why your bike "operates normally" with just one cable, pull open, spring closed.
It looks like your end fitting has come off, in my cheap days, I would fix them myself... I would get a lead fishing weight and pinch it on the cable with vice grips and then pound it into a small copper tube with a cut out for the cable... totally cheap but I had the tools and could make it work for another year. Farmer boy fixes to keep the **** running.
Old November 17th, 2014, 08:51 AM   #10
Ninja Rob
Ninja Rob's Avatar
It closes fine. It`s an 04 ninja. Just that I am selling it and I would not feel right selling it to another person in that condition.
Last futzed with by Ninja Rob; November 17th, 2014 at 08:52 AM. Reason: minor grammer
Old November 17th, 2014, 10:07 AM   #11
MrAtom
MOTM - July '15
Good guy
Old November 17th, 2014, 10:41 AM   #12
/moved to pre-gen tech
Old January 23rd, 2015, 10:07 AM   #13
Ninja Rob
Ninja Rob's Avatar
I have replaced the cable a while back, just barely updating it here.
Throttle went while riding -> need new throttle cable? AndrewMack 2008 - 2012 Ninja 250R Tech Talk 13 September 8th, 2013 06:17 PM
Adjusting Throttle Cable - Barrel adjusters and Throttle body adjusters are maxed out theob 2008 - 2012 Ninja 250R Tech Talk 10 July 19th, 2012 05:01 PM
Fine throttle cable adjustment assembly broken. setasai 2008 - 2012 Ninja 250R Tech Talk 2 June 18th, 2011 09:10 PM
Clutch cable ever broken on a ride? ally99 2008 - 2012 Ninja 250R Tech Talk 10 June 28th, 2010 11:28 PM
Throttle & Throttle Cable Smoothness paterick4o8 2008 - 2012 Ninja 250R Tech Talk 3 December 1st, 2009 01:50 PM
