November 19th, 2014, 02:57 AM | #1 |
Need your help mixture screw base on this spark plug
Hi guys,
I need your opinion to turn idle mixture screw base on this spark plug colour. What shoul i do? Turn in or turn out mixture screw. Bike fully stock accept full system exhaust. As you can see on the base ring not full brown colour. I use syock needles with mixture screw left 2,5 and 2.25. This image with the spark plug wre h is the right one. Thanks |
November 19th, 2014, 05:10 AM | #2 |
Your plugs look fine. In fact they look new. You're not really going to tell a lot on new plugs.
Sounds like the same question from your previous posts. https://www.ninjette.org/forums/show...ighlight=plugs https://www.ninjette.org/forums/show...ighlight=color https://www.ninjette.org/forums/show...ighlight=spark https://www.ninjette.org/forums/show...ighlight=spark |
November 19th, 2014, 07:13 AM | #3 |
Your idle mixture setting aren't going to change the color of your plugs significantly - unless you are idling all day...
Set the idle mixture screws at a base setting of 2 1/2 turns out, then go in or out 1/2 turn to see which direction makes it run better. If it runs significantly better, go more in the same direction until it runs worse. Then make adjustments in 1/8 turn increments back toward the base setting until you feel it's the best. Another way to set the idle mixture is to adjust them until you get the highest hot idle speed, then go slightly (1/8 turn +/-) richer. Going slightly richer usually smooths out the transition from the idle circuit to the needle, where having it adjusted "right on" can sometimes give you a little lean stumble as it transitions. When you are done you will most likely need to set the hot idle speed to back 1300. If you carbs are out of sync you may not be able to get it to idle well no matter where you set it, so be sure they are synced before making fine adjustments. |
Stock mixture screw settings | ferret09 | 2008 - 2012 Ninja 250R Tech Talk | 6 | September 12th, 2023 11:00 PM |
what is the best idle screw mixture | vmax | 2008 - 2012 Ninja 250R Tech Talk | 9 | July 1st, 2017 10:45 AM |
Mixture screw turns. | simook | 2008 - 2012 Ninja 250R Tech Talk | 7 | October 13th, 2013 07:26 PM |
Adjusting the Idle Mixture Screw | conrya5 | 2008 - 2012 Ninja 250R Tech Talk | 22 | March 18th, 2013 05:03 AM |
Idle Mixture adjustment screw Q | indr | 2008 - 2012 Ninja 250R Tech Talk | 1 | December 2nd, 2010 09:36 PM |
