December 9th, 2014, 05:55 PM | #1 |
Boy Racer
Join Date: Oct 2013 Motorcycle(s): 08' NINJA 250R, 2013 BMW HP4 Posts: 41
Engine Block off plates
Okay guys I have a Carbied 09 Ninja 250r, and have been looking for information regarding block off plates, can anyone tell me what they do, why I would get them, and if they change anything significantly enough for me to realise while I ride?
Ride List: Current: 09' Ninja 250r Previous: 99' ZZR250 |
December 9th, 2014, 06:28 PM | #2 |
the block off a hole. you use them when you take something off and there is a hole left.
December 9th, 2014, 07:45 PM | #3 |
I have one I never used... PM me addy and I'll send it out.
December 10th, 2014, 08:18 AM | #4 |
Track Clown
MOTM - Sep '15
what hole is blocked? the in hole or out hole?
December 10th, 2014, 08:37 AM | #5 |
Block off plates are used for when you remove the AirClean system (for emissions).
When you remove that it leaves a open hole into the engine, the plates close that off. Removal of this system should only be done when chaining full exhaust system, I believe. |
December 10th, 2014, 09:56 AM | #7 |
Hello Moto
Join Date: Mar 2013 Motorcycle(s): 1975 RD350; 2001 KX125; 2003 Z1000; 2003 KDX50; 2009 ZX6R; 2011 Ninja 250R; 2014 KX250F Posts: 352
December 10th, 2014, 11:56 AM | #8 |
Certifiable nontundrum
MOTM - Sep '13, Sep '16
Does it do anything besides just help popping an backfiring?
December 10th, 2014, 12:49 PM | #9 |
It's cool, I only date 3 input girls, just like my prom date
December 10th, 2014, 12:56 PM | #10 |
never disrespect the screaming eagle, boy.
5 ports. Simultaneous data transfer.
December 10th, 2014, 12:57 PM | #11 |
MOTM - Sep '18, Feb '16
The holes on the top of the valve cover go directly into the exhaust system. They allow air to enter the exhaust to aid the catalytic converter. Unburned fuel needs oxygen so the cat can burn it.
If you have no cat the air will cause a POP sound when decelerating.
December 10th, 2014, 01:02 PM | #12 | |
December 10th, 2014, 01:16 PM | #13 |
The cat needs oxegen to burn the fuel. Without a catalist the fuel and air would not burn. You want the heat to stay in the exhaust system. That is why we wrap headers.
December 10th, 2014, 01:33 PM | #14 |
this is something i've never understood... why should the headers be hot? as in, if you could do something to aide cooling the headers, why not? what is better about a hot header? i mean if you don't have a cat and don't care about emissions
December 10th, 2014, 01:48 PM | #15 |
The point is to have a proper fuel mixture knside the engine. Header heat is not the goal. But hot headers move gases better. I will find out why. I know but can't explane.
December 10th, 2014, 05:00 PM | #16 |
i've heard before that hotter fluids have less coefficient of friction because of the decreased mass per area... maybe it's something like that?
Does anyone know the bolt size so I can put mirror block off plates on? | Insane Pie | 2008 - 2012 Ninja 250R Tech Talk | 1 | June 14th, 2014 07:29 AM |
PowderKeg Racing Smog Block Of Plates | Ricmon | 2008 - 2012 Ninja 250R Tech Talk | 2 | August 22nd, 2012 12:31 PM |
WTB pre gen block off plates | 7oxSin | Items Wanted | 0 | July 14th, 2012 06:46 PM |
Mirror Block Off Plates | gadgetguy1288 | 2008 - 2012 Ninja 250R Farkles | 6 | March 13th, 2012 04:15 PM |
[motorcyclistonline] - New Driven Block Off Plates | Ninjette Newsbot | Motorcycling News | 0 | March 16th, 2011 08:40 PM |
