Old June 2nd, 2009, 06:58 PM   #1
lavid2002
lavid2002's Avatar
Motorcycle(s): None yet
Where can I store my motorcycle? Shed? backyard? what...
Where can I keep my motorcycle when I get it. I suppose I could clear out the shed and make a small ramp so I can drive the bike into it, but there are allot of tools and I dont want my bike to get dinged up. Also, its packed in there. The garage is small and thats where my mom keeps her infiniti G35 (only the driver can get in and out we have hardwood stacked on the right side. I SUPPOSE I could buy a shed separate for the ninja but that would cost allot. ARGGG. I dont know what to do with this thing. Also, Im leaving for college in the fall and its a year round school. Ill only be home every now and again this needs to be secure and out of the elements. Ideas?
What do you do with your ninja?
Thanks! :P
-Dave
-Dave
lavid2002 is offline   Reply With Quote
Old June 2nd, 2009, 07:03 PM   #2
dmonaco05
Motorcycle(s): 2009 ninja 250r
get one of those cheap $250 sheds by arrow from lowes/hd not the highest quality but wont break the bank and cheaper than a storage unit
dmonaco05 is offline   Reply With Quote
Old June 2nd, 2009, 07:09 PM   #3
miks
I'm lovin' it.
miks's Avatar
Motorcycle(s): '09 Black 250R
Put it inside the house
Or, buy a weatherproof full cover.
Son: When I grow up I want to ride a motorbike.
Father: You can't do both son.
miks is offline   Reply With Quote
Old June 2nd, 2009, 07:10 PM   #4
noche_caliente
noche_caliente's Avatar
Motorcycle(s): '08 250
or wait until you're more settled to get one if you can't take it to school and don't have anywhere to put it
Progrip tank pad, blue rim stripes, blue Pazzos, Roaring Toyz lowering kit, Puig DB in dark smoke, Cortech sport tail, super mini tank, and saddlebags, OES swingarm spools and Intuitive frame sliders
Old June 2nd, 2009, 07:12 PM   #5
lavid2002
lavid2002's Avatar
Theres a bookshelf and dresser in the shed we really dont use, the price of these sheds is kind of deterring. Maybe I can throw those away and use the right part of the shed. I have to scoot the bike acrost like 20 feet of grass every time I want to use it though. This isnt a big deal is it?
-Dave
Old June 2nd, 2009, 07:14 PM   #6
lavid2002
lavid2002's Avatar
Lol every entrance to my house has at least 3 steps. I dont think the suspension could handle it... haha
-Dave
Old June 2nd, 2009, 07:26 PM   #7
Elfling
Elfling's Avatar
Motorcycle(s): 03 Ninja 250, 02 CBR600 f4i
Doesn't sound like a big deal to me, the bike does roll If you're going to leave it alone for long periods of time, Id definitely put it inside something to keep it out of the elements.
Elfling is offline   Reply With Quote
Old June 2nd, 2009, 07:35 PM   #8
lavid2002
lavid2002's Avatar
Alright, I work at a marina and to winterize te motors we make a fuel mixture of WD-40, Sta-bil, and gasoline. We run it in the engines, then after 5 minutes or so (To assure its all nice and in the jets and everywhere) We spray engine fogger into the carburetor until the motor bogs out and dies. Once it dies we know everything is coated and there is no possible chance of gas deterioration and or rusting of internal parts. Whats the best way to winterize these babies?
-Dave
Old June 2nd, 2009, 07:43 PM   #9
dmonaco05
the OM just says to run the engine at idle speed until it dies
Old June 3rd, 2009, 06:53 PM   #10
lavid2002
lavid2002's Avatar
Seriously? What about rust inside the engine. Also, I doubt running it until it dies gets every little bit of fuel...what happens when the fuel gets gummed up from the cold? Ive cleaned out tons of carbs full of gasoline that turned into a gelatin like substance over winter....madness. Does anyone here run it until it dies and call it a day? If so leme kno how its working out for you plz.
-Dave
-Dave
Old June 3rd, 2009, 07:10 PM   #11
Apex
Livin' the Minimoto Life
Apex's Avatar
If you plan on storing it for a while. pull the spark plugs, add some oil in the chambers. Then cycle the engine using the starter (with the fuel cut off), and coat the cylinders with oil.
I personally would drain the contents of gas tank in a handheld gas tank. While the tank is off, pull the plugs, add some oil, and cycle the engine with the plugs out of it. Having the plugs out keeps the motor from forcing the oil to the exhaust. Then you should be set. I'd personally drain the gas out of the carbs myself.
Old June 4th, 2009, 04:45 PM   #12
lavid2002
lavid2002's Avatar
I was thinkin about drining the bowls and calling it a day, but what about all the jets? I think ill run a lil sta-bil then fog it, then drain the fuel and do the cylinders.
-Dave
Old June 4th, 2009, 08:15 PM   #13
ninjammin
Motorcycle(s): 2003 Ninja 250
It is June right?
ninjammin is offline   Reply With Quote
Old June 5th, 2009, 08:20 AM   #14
CC Cowboy
CC Cowboy's Avatar
MOTM - Mar '13, Jun '14
Store it at my house, with the keys in it.
Old June 5th, 2009, 10:31 AM   #15
HKr1
IC2(SW)
HKr1's Avatar
I gotta ride 1/2 mile dirt, just to find some pavement to ride on
Old June 6th, 2009, 07:27 PM   #16
krazygluon
Parking Lot Qualified
Motorcycle(s): '09 Ninja 250
TBH, not having $250 for a shed might be a hint that you don't really have the $$ for the bike.
There's a Total Cost of Ownership involved in motorcycles (or road bicycles or any other moving man-toy) that silently extends well beyond the pricetag of the bike, not to mention the risk of becoming a completely addicted gearwhore.
I live in an apartment and during the summer I rely on a bike cover. In the winter I'll rent a car-port space and throw a cable around it attached to a pole. Might add a few blankets under the cover and will probably remove the battery and take it indoors.
krazygluon is offline   Reply With Quote
Old June 6th, 2009, 10:05 PM   #17
wyckedflesh
wyckedflesh's Avatar
Motorcycle(s): '09 Blue Kawasaki KLE650 Versys, '95 Ducati 900SS/CR (undergoing track conversion)
wyckedflesh is offline   Reply With Quote
Old June 7th, 2009, 12:27 PM   #18
Red'09250
Motorcycle(s): Red '09 250
Did you put a cat under your kickstand? I've heard of throwing a towel down to keep divots out of the floor, but this is ridiculous.
Red'09250 is offline   Reply With Quote
Old June 7th, 2009, 01:46 PM   #19
wyckedflesh
It was a thought, really, but not with her, she is a bit too feisty to get away with that. She is also a year and a half old kitten, she has yet to grow into her paws...
My Backyard csmith12 Videos 72 September 1st, 2014 06:12 PM
storage shed sharky nrk General Motorcycling Discussion 3 January 30th, 2014 08:31 AM
Building a Shed.... Joshorilla Off-Topic 10 May 14th, 2013 08:20 PM
a few things from my shed hoodadooda Motorcycle-related 9 August 24th, 2012 09:35 AM
What's in your backyard? OldGuy General Motorcycling Discussion 20 May 28th, 2009 11:19 AM
