Old January 14th, 2015, 11:42 PM   #1
swarfman64
Master modder
swarfman64's Avatar
Motorcycle(s): TURBO gpx250 99 CB250/500rs Sherco290 Trials Indian 1911big base (replica)
Ecotrons map
Hello, I was wondering if anyone had a map for a turbocharged/ Ecotrons injected ninja, ideally one that is known to work with the standard fuel regulator. And going to the full 2.5 bar too.
I have a project at a stand still.
Any help appreciated
[B]Come and see my turbo ninja build, dyno build and other stuff at http://swarfman64.blogspot.com.au/20...rtia-dyno.html
swarfman64 is offline   Reply With Quote
Old January 15th, 2015, 02:16 AM   #2
Somchai
Freedom for Germany
Motorcycle(s): Ninja 250R-FI
Andrew I don't know the Ecotrons system, Matt for sure can tell you how to do it, but normally you go and calculate the mass of air your engine is sucking in per hour.
The formula is: 60 * cc of each cylinder (in liter) * cylinders * rpm * grade of delivery (turbo = 1.2 - 1.6) / 2
i.e. for your bike: 60 * 0.125 * 2 * 12000 * 1.4 / 2 = 126000 liter / hour
All those values are calculated for full open throttle.
Good luck
Old January 15th, 2015, 06:09 AM   #3
swarfman64
Master modder
swarfman64's Avatar
Thanks for the info', I'm waiting on some help from Matt. I have some files but are having some minor issues loading them. I initially was shooting for 8psi boost, but now I think I'm going to push a lot further which means a rising rate reg and possibly bigger injectors.
I was also interested to know if there is actually another Ecotrons boosted ninja that is sorted tune wise, I'm thinking there may not be yet.
Ecotrons Install Thread Jiggles 2008 - 2012 Ninja 250R Tech Talk 1732 May 31st, 2022 02:17 PM
Ecotrons petcock option swarfman64 1986 - 2007 Ninja 250R Tech Talk 2 January 10th, 2015 03:26 PM
WTB:Ecotrons petcock crimsondragon Items Wanted 2 September 21st, 2014 06:54 AM
Ecotrons kit garth285 Items Wanted 0 June 17th, 2014 05:09 PM
Ecotrons and Koso Question msebastian 2008 - 2012 Ninja 250R Tech Talk 29 July 19th, 2012 05:07 PM
