Old January 28th, 2015, 11:29 PM   #1
kaosyin
Motorcycle(s): 09 kawasaki ninja 250r
no turn signals working
So I recently installed new led turn signals in front rear and mirror I wired everything up and
Now they won't even come on at all before they came on and stayed solid with the stock relay so I went and bought
A electronic relay and they still don't work I've tryed 3 different electronic relays and nothing
They won't even come on and fuse is fine any help to this problem would greatly appreciated
kaosyin is offline   Reply With Quote
Old January 29th, 2015, 01:31 PM   #2
Apex123
Motorcycle(s): Green Ninja 250 2008
Is the indicator on the dash turning on and off?
Apex123 is offline   Reply With Quote
Old January 29th, 2015, 04:00 PM   #3
kaosyin
Yea it comes on and off but it is dimly lit not bright like usual
Old January 29th, 2015, 04:53 PM   #4
Apex123
Has the bike been sitting / been winterized and you just did the upgrade now? Are all of the dash lights dim like the turn signal? If so, This might be the cause of your battery being dead. If not, Re hook up your stock turn signals, if they work then you have narrowed your problem down to incorrect installation or a need of a different relay.
Indicator Problem - Turn Signals Not Working alex192 2008 - 2012 Ninja 250R Tech Talk 6 December 7th, 2014 09:56 AM
Turn signals stopped working. Insan3guy General Motorcycling Discussion 1 October 15th, 2013 10:17 PM
Turn Signals not working correctly aspenratt07 1986 - 2007 Ninja 250R Tech Talk 5 April 1st, 2013 08:46 PM
Turn Signals Stopped Working! DisciplesHeart 2008 - 2012 Ninja 250R Tech Talk 18 March 21st, 2012 08:45 PM
Left turn signals not working properly maraci 2008 - 2012 Ninja 250R Tech Talk 7 April 16th, 2011 07:38 PM
