Old February 6th, 2015, 02:30 AM   #1
joeybaila
Motorcycle(s): 2010 EX250
No power to bike
Hey guys. I'm having some troubles with a recent purchase. I bought the bike as a parts bike and decided to put it as a race bike. The previous owner said the motor ran fine and that the motor had 6k miles on it. The right engine cover was removed because he crashed it and it had a small leak. Well, the guy hacked the sheet out of the harness, so I ordered a new one.
I hooked everything up, and made sure the new battery did its 6 hour initial charge, it read 12.71v. well I turn the key and no light on the dash, engine wont crank. Ive done the kickstand delete, so that isn't it. I jumped the starter solenoid, and it cranks over. I have checked all my connections and none are loose or have backed out. I checked both grounds, the one by the thermostat and the one by the right side engine cover, both are good. i know everything is good in the harness and the gauges, because i took the gauges from my other race bike. I even swapped the edu, and then the complete harness (from my running bike) and still no power to the gauges. Ive also tried swapping out the starter switch, solenoid, and rectifier. None of them made any difference. Anybody have something like this happen, thank you in advance guys.
joeybaila is offline   Reply With Quote
Old February 6th, 2015, 08:50 AM   #2
cuong-nutz
cuong-nutz's Avatar
check your ignition switch/harness. bust out your multimeter. You should be getting power to the white wires that feed from the battery.
Look up the igintion delete/bypass DIY how to to see.
HalfFast Racing Team
Old February 6th, 2015, 06:30 PM   #3
Ghostt
Ghostt's Avatar
Fuses including the main fuse on the starter solenoid? And bust out that multi-meter time.
violente et ignorantia
ZX-2R BLOG
Old February 6th, 2015, 07:12 PM   #4
joeybaila
ok figured it out. Turns out I had a few problems. First, I don't know why but the bike would not crank, after disconnecting the gauges, it now cranks. Must be a short or something. I was not getting any fire at the coils. I had purchased one of those cheap $40 keys on ebay, but did not know that they need a resistor. so put the key from my A bike, and now i have fire. woot woot. thank you guys
Bike size (shape not cc power thread) Mowgli General Motorcycling Discussion 11 July 9th, 2012 09:14 PM
bike loses power and shuts off on freeway realmess 2008 - 2012 Ninja 250R Tech Talk 14 March 18th, 2012 03:37 PM
Bike lacking power on commute today. CZroe 2008 - 2012 Ninja 250R Tech Talk 8 March 23rd, 2011 10:42 AM
Power Commander for new bike? dive1tom General Motorcycling Discussion 5 December 8th, 2009 08:53 PM
Help me buy a bike with less power 00v_Lucky Off-Topic 6 April 21st, 2009 05:12 AM
