Old March 29th, 2015, 01:39 PM   #1
93etgocart
93etgocart's Avatar
Motorcycle(s): 2003 Honda Shadow, 2008 ninja 250
Rebuilding the petcock and have a question.
Ok so I noticed I was leaking gas and found it leaking at the white plastic spacer so I decided to just rebuild the whole thing. But upon dis-assembly I found I have no idea how the diaphragm comes apart from the spacer. I found the k and s repair kit on dennis kirk and was wondering when I get it how do I go about rebuilding the diaphragm? thanks in advance
93etgocart is offline   Reply With Quote
Old March 29th, 2015, 08:49 PM   #2
Free bump for more views...
Old March 29th, 2015, 09:56 PM   #3
Ghostt
Ghostt's Avatar
The diaphragm is a very thin, most likely it's stuck to the plate, is this the kit your referring to,
K&S Technologies Fuel Petcock Repair Kit 55-2009 https://www.amazon.com/dp/B00M9N04PW..._dxngvb1HK5CS3
if you have some pictures that might help.
Also try this as well,
http://faq.ninja250.org/wiki/Rebuild...tcock/fuel_tap
I'm not familiar with the NewGen petcock, but it should be similar to PreGen.
Hope this helps.
violente et ignorantia
ZX-2R BLOG
Old March 30th, 2015, 03:02 PM   #4
93etgocart
93etgocart's Avatar
https://www.denniskirk.com/fuel-petc...prd/187589.sku that is the kit im referring to even though I found it cheaper on ebay but its alot like the pregen. I just am not sure how to put the diaphragm back together. Also I looked at that link and it doesnt really clearly show how to rebuild the diaphragm.
Old March 30th, 2015, 03:07 PM   #5
Ghostt
Ghostt's Avatar
Once you get the kit, it should make sense then, rebuilding a petcock is once of the easier things on the bike to do.
The diaphragm is just stuck to the spacer, it will peel off. Can you maybe post some pictures of what your concerned about?
ZX-2R BLOG
Old March 30th, 2015, 03:23 PM   #6
93etgocart
93etgocart's Avatar
I am concerned about how to get the two pieces of the diaphragm around the spacer.
Old March 30th, 2015, 03:28 PM   #7
Ghostt
Ghostt's Avatar
The diaphragm lays on top of the spacer, doesn't wrap around.
ZX-2R BLOG
Old March 30th, 2015, 03:29 PM   #8
93etgocart
93etgocart's Avatar
There is a little rubber piece on each side isnt there? connected by some piece of metal?
Old March 30th, 2015, 03:34 PM   #9
Ghostt
Ghostt's Avatar
Might be different on a NewGen petcock, but here's a write-up on PreGen one
ZX-2R BLOG
Old March 30th, 2015, 03:42 PM   #10
93etgocart
93etgocart's Avatar
This is what it looks like and im not sure if the rubber is supposed to separate from the metal part in the middle or if you just push it through the hole and then put it back through there. That is what my main question is.
Old March 30th, 2015, 04:35 PM   #11
cadd
cadd cadd cadd
cadd's Avatar
Motorcycle(s): 300
MOTM - May '15
Maybe your situation is different from mine. I had gas dripping from the petcock. Before purchasing the rebuild kit, I stretched the spring just a bit and put everything back together. It stopped dripping.
Old March 30th, 2015, 04:54 PM   #12
93etgocart
93etgocart's Avatar
Ya I thought about trying that but the bike sat for a year and a half before I purchased it so I figured it was worth the 28 bucks to just rebuild it.
Old March 31st, 2015, 07:01 AM   #13
Ghostt
Ghostt's Avatar
Push it thru the hole, you are correct sir.
ZX-2R BLOG
Old April 3rd, 2015, 01:15 PM   #14
93etgocart
93etgocart's Avatar
Well good news I got my parts in today and after comparing the springs it was most likely my spring. But now I dont have any leaks and can get back to riding.
Old April 3rd, 2015, 01:21 PM   #15
Ghostt
Ghostt's Avatar
Good deal, glad it all worked out, any problems during the rebuilding?
ZX-2R BLOG
Old April 3rd, 2015, 06:01 PM   #16
93etgocart
93etgocart's Avatar
Nope went smooth I almost put the wrong spring back but luckily caught it before I got it back on the bike.
petcock question. berserk81 General Motorcycling Discussion 3 December 12th, 2013 08:08 PM
Petcock / Fuel Tap question pdxdavid 2008 - 2012 Ninja 250R Tech Talk 9 October 9th, 2013 08:28 PM
Petcock Question az3200 1986 - 2007 Ninja 250R Tech Talk 3 June 3rd, 2013 06:25 PM
Carb Cleaning/Rebuilding Question.... jboyd12 2008 - 2012 Ninja 250R Tech Talk 13 March 26th, 2012 08:58 PM
petcock question Realirony 2008 - 2012 Ninja 250R Tech Talk 6 March 9th, 2009 11:55 AM
