April 1st, 2015, 12:33 PM | #41 | |
Nope!
And... as far as your question goes. You asked about being smoother in the wet. I have given this one some initial thought and I got nothing of real value that I haven't already posted in other threads or you don't already know from us talking about it in the paddock. Also, I am just not sure how it's any different from riding smoothly in the dry aside of not being as aggressive with inputs. I know you have rain tires, that changes some things traction wise but as far as I know, the riding skills portions are nearly identical. I have resources though , I will have you AND me an answer pretty soon I hope. Or maybe @Misti could shed light here were I cannot.
April 1st, 2015, 12:34 PM | #42 |
Private Joker
MOTM - Mar '14
yeah, the track was damp in fl but it was dry enough to where there wasn't a traction difference. The only difference there was mental, me holding back because of a lack of traction that I never experienced bc I was holding back
forecast is calling for heavy rain in the AM that's what I figured, the riding theoretically shouldn't change except to brake sooner and use a slightly slower throttle roll on
April 1st, 2015, 12:42 PM | #43 | |
The only thing that I can add right now is. I have 2 sets of markers on tracks that I have ridden in the wet. I have a dry set of markers and a wet set. You know the drill here, the braking markers are way earlier in the wet, the apexes are the same, but the exits are somewhat different. Do you think your turn in point should be moved too?
April 1st, 2015, 12:46 PM | #44 |
Private Joker
MOTM - Mar '14
I'm tempted to say yes but I don't believe the turn in point should change
UNLESS you accompany the change (moving turn in point back, turn in earlier) with a slower steering rate, but this doesn't really make much sense to me to do since a slower turn in rate puts you at more risk of losing the front since you're leaned over longer
April 1st, 2015, 12:48 PM | #45 |
Inline 4!!!
Emotions/mental state and how it affects your ability to stay safe on two wheels.
April 1st, 2015, 12:54 PM | #46 | |
Private Joker
MOTM - Mar '14
April 1st, 2015, 01:07 PM | #47 | |
As a coach though, sure... there are times I would rather not ride, weather, track conditions or maybe even a bit of turtlehead lol. But I have a job to do, so I normally take some time to myself and get my mind straight to do my best, just like anyone else should do, coach or not. Nobody should force anyone to ride, if you feel forced, then that is a giant red flag to NOT ride.
April 1st, 2015, 01:34 PM | #48 | |
Knowing my own riding, I must alter some turn in points to certain corners as I believe I am on the very edge of charging them. I will admit here... I am human, some corners are more fun at the bleeding edge. I KNOW for 100% fact I can't get away with some of the stuff I get away with while in the wet. So along with any other credited comments, Imma say... use your noodle. After the number of track days you have taken, you have a good idea when you're cheating the system and when you're not. Adjust as necessary.
Goal: Shake A Million Hands | Look through the corners | Track Day Prep | Closest track? | The Mid-Ohio School Last futzed with by csmith12; April 2nd, 2015 at 05:50 AM. |
April 1st, 2015, 03:51 PM | #49 | |
Private Joker
MOTM - Mar '14
"Nature does not hurry, yet everything is accomplished." - Lao Tzu Less is more, especially when doing something that requires focus. If your mind is distracted and filled with clutter then you're never going to feel one of the best feelings there is in life. The flow when you are riding hard and smooth, when you know you can push harder but don't feel the need to at that moment because you're already flying and enjoying yourself.
April 1st, 2015, 07:38 PM | #50 |
Inline 4!!!
Impossible. I'm literally always up to ride.
April 1st, 2015, 07:41 PM | #51 |
Private Joker
MOTM - Mar '14
Just because you haven't experienced something doesn't mean you won't. You've never ridden track, it's a completely different beast.
April 1st, 2015, 09:46 PM | #52 |
Inline 4!!!
I cannot wait to find out!
April 1st, 2015, 09:48 PM | #53 |
Private Joker
MOTM - Mar '14
Do you know when you're going to be able to get to the track, I'd say your best bet is to get there on a day when other ninjette members are there. It makes the day a lot better to be able to meet and ride with the folk on the forum
April 4th, 2015, 09:43 AM | #54 |
I haven't forgot about ya @snot, just been busy at work. The passing question is still open too.
April 4th, 2015, 09:59 AM | #55 |
sammich maker
MOTM - Apr '15
It's ok, I am patient
https://www.brocksperformance.com/VZ...0035+C450.aspx |
April 5th, 2015, 06:39 AM | #56 |
Private Joker
MOTM - Mar '14
Here's a good one
passing a rider who is slower but not by that much, how to pass rather than get sucked into their pace and subsequently stuck behind them rather than continuing to chase down the coach/rider you were targeting. It's not as big of a deal in a track day setting but in a race setting it'd make a huge difference. edit: update on rain, rain stopped early but the track was super slick session one. It got better across the morning and had acceptable grip in the afternoon, never managed to really get heat into my tires like I do at jennings
April 5th, 2015, 07:43 AM | #57 | |
This is a vision problem 2 fold. 1st part; Your vision lingers on the rider in front of you too long and you may start to let that rider's riding leak into yours. ie, start to ride their pace, start to ride their lines, turn in points, braking, accel, ect... ect... 2nd part; With your field of attention slimmed down to include a near rider, it can keep you from seeing passing opportunities ahead of time. This is why Misti recommends not only looking ahead, but wider as well. When passing a rider that is only slightly slower than you, you have to plan it out ahead of time or take advantage of a mistake. Be ready to take different lines to set up the pass. If everyone always follows the race line, nobody would pass anyone. Take a session and try different lines through the corners. The track is full of good and bad lines, you remember how to find and validate a good line right? And, if you are better at a certain section of the track, then that should be where you make the pass, planning it came before that section, not IN that section.
April 5th, 2015, 05:20 PM | #58 |
Private Joker
MOTM - Mar '14
It makes sense to me that it's a vision issue, I feel that I was affected more by the first part than the second and did the majority of my passes under braking bc I tend to not trust most riders in novice enough to pass them on the outside mid-corner after seeing them swing excessively wide mid-corner. I'd just go under them (and be just fine doing so) if it were a legal pass but I get why that rule is there and stick to it for that reason.
I like passing under braking
April 8th, 2015, 04:37 PM | #59 | |
But remember when we rode together on the track? While behind you filming my lines were all over the track to get the best and most helpful video I could get without disturbing your groove. There are other reasons why you would want to find other lines through the corners. Maybe somebody spilled oil. Poor tarmac conditions, maybe the org just puts cones in places for safety reasons to force an alternate line. Or maybe worse stuff like a bike or rider laying in the middle of the track. You have seen that one before too. You just got to be ready when you see that yellow flag waving ya know..
April 8th, 2015, 04:43 PM | #60 |
Private Joker
MOTM - Mar '14
being able to change lines at a moments notice is pretty critical on the street as well
I tend to, intentionally, ride every line imaginable on the street at one point or another for that reason. I'll spend some time working on alt lines when I get to NJMP in 10 days...assuming I figure out the issues with the gsxr and fix them but that's a different discussion I heard something that's a good idea to work on and figured this would be a good thread for it: When coming to a stop brake in such a way that the front end stays completely still when you finish stopping. I.e. the front doesn't bounce back at all. This is way easier said than done and requires you to be incredibly smooth on the brakes, I've been trying it every time I get on the brakes for the past few days and have only managed to do it twice out of 100+ tries. The end result conceivably is that it teaches you to be smoother on the brakes so you can trail them into a corner better at higher lean. "the fastest riders have the slowest hands" type thing
April 8th, 2015, 05:10 PM | #61 |
This is a great discussion, your thinking...
Sounds like some fun stuff to try in a parking lot as practice. I would avoid that in high traffic areas though. #1 goal of braking - get your entry speed perfect. Doing that while track riding you're setting up an important and subtle "race condition". You asked how to get "smoother brake to throttle transitions", so let's have a closer look and I bet we can figger it out ... When trying to casually stop the bike's at it's sag measures (neutral suspension), it's easy to know the rider has reached their comfortable speed BEFORE the suspension returns to that neutral state (speeds near 0mph normally poses no speed concerns). So you're free to take as long as you need to work on brake finesse (skill isolation ya know). On the track though, it's another story. Your main goal is to get to your entry speed and get back to the throttle asap. So it's gunna be a race to what happens first, will you reach your entry speed first or will you reach neutral suspension first? Let's ask some deeper questions then... Does it matter which you reach first? Should you reach one before the other? Should you reach them at the same time?
April 8th, 2015, 05:25 PM | #62 |
Private Joker
MOTM - Mar '14
For purposes of this post apex = the slowest point of the corner where you begin your roll on, which can be earlier than the corner's physical apex
It does matter which one you reach first, You want to reach your entry speed first as you're still trailing the brakes to the apex in a perfect world where the apex is the slowest part of the corner (though usually not by much) In a perfect world you would reach the apex at neutral suspension and the dialed in speed, which is a large reason you trail the brakes in the first place, at the same time. This allows for you to begin your throttle roll on at the apex without any complaints from the front suspension about being suddenly decompressed. This is perfect world though, actually pulling this off is far easier said than done
April 8th, 2015, 05:32 PM | #63 |
Hmmm... what about this then, how does lean angle play a role here? if the apex is the slowest part of the corner, would you also carry the most lean angle at apex (in a perfect world)?
April 8th, 2015, 05:34 PM | #64 | |
Private Joker
MOTM - Mar '14
When braking to a stop the norm is to brake lightly then progressively increase braking until you stop, which is fine but will cause the forks to rebound slightly as you stop. The difference is that with this approach you smoothly apply the brakes so the forks act much like a V. You still compress the forks under braking, as that is inevitable with any real braking power. Smoothly add braking force from nothing until maximum braking then slowly ease off the brakes back to neutral. So on track, or taking any corner really, you would smoothly apply the braking force as you start braking which allows you to use more braking power without bottoming out the forks (a genuine problem on my track 250, super soft (stock) forks + upgraded front caliper/rotor that provides more stopping power than the forks can actually handle if you "step on the brakes") then get your braking done at max braking and turn in and smoothly trail the brakes through until the apex arriving at neutral sag just in time to roll on the throttle On the topic of lean angle, max lean angle would be at the apex, though I am sure there are exceptions to this rule that I am not thinking of
April 8th, 2015, 05:43 PM | #65 |
Private Joker
MOTM - Mar '14
Max lean could occur earlier though, as trailing the brakes in this way satisfies the suspension much like a throttle roll on would. Reducing load on the front and transferring it to the rear
the throttle and brake are one control, not two separate controls as we are inclined to believe. Transferring between the two "should be" seamless at all times. To decrease throttle is to brake and to decrease braking force is to accelerate if that makes any sense at all
April 8th, 2015, 10:07 PM | #66 | |
I completely understand what you're doing, it's how my dad taught me to brake in a car when I first started driving. "Ease up on the brake that last 20ft before ya come to a full stop we don't get whiplash".
imho... there is a balance between flick rate and the speed a rider releases the brake to control trail off to compensate for the lean angle needed to make the line. Honestly, from what I know and my own experience, it's a trade off for an earlier turn in point that "feels" better. When "I" am in practice mode, I would rather spend my time setting a good turn in point, entry speed and getting the bike turned faster. Which means less time is spent trailing the brakes and spend more time on the throttle throughout the corner. It's just as fast when looking at lap times and feels overall safer to me. I am not totally against trailing really, really deep or even somewhere in between, it's a useful tool when needed to guard against a pass but it's not something I strive for in every corner. Realistically, many corners lend themselves to a bit of trail braking as the rider sees fit and it's not all bad either. Notice there was no mention of apex anywhere in that last part...
April 9th, 2015, 07:17 AM | #67 |
Private Joker
MOTM - Mar '14
Note I redefined apex because I couldn't think of a better word to use so what we're saying isn't too different. I get what you're saying, slightly surprised that trailbraking doesn't make that big of a difference but it makes sense if you're accelerating sooner to have any time lost be made right back up.
Looks like it's a stylistic difference based on rider preference, I'll have to try both to figure out which I prefer and that preference may change track to track. I see NJMP as more of a track where trailbraking would feel more natural and summit point main as more of a track where flicking the bike over and getting back on the gas asap would pay dividends at the end of each straight.
April 9th, 2015, 09:30 AM | #68 | |
April 9th, 2015, 12:21 PM | #69 | |
Join Date: Oct 2010 Motorcycle(s): currently: Yamaha YZF 250 dirt/motard Posts: 787
Misti
"Leap and the net will appear!" superbikeschool.com www.motomom.ca |
April 9th, 2015, 01:00 PM | #70 | |
Private Joker
MOTM - Mar '14
On track, almost. It moves the braking point and turn in point earlier slightly but not by much. I also don't use as much lean in the wet (likely mental more than anything else, just need more track time in wet conditions) while turning in slightly slower but still quick. How big of a difference depends on conditions. The goal is still to get the bike leaned over as quickly as possible
April 10th, 2015, 10:42 AM | #71 | |
Where do you start with picking a brake marker?: When I read a few riding skills books I found this area to be somewhat lacking. I understand why too… it’s vague, you may be fighting your SR’s and feels somewhat questionable until you establish a baseline. Which is exactly what we are going to do. Do you remember doing the no brake drill during track school at Mid-Ohio? This is the beginning of how your find your very first, and very safe braking marker, as well as a 75% skill entry speed as a bonus. Without worrying about other braking inputs and all that shifting of gears, how much of your attention did you have to focus on entry speed? Nearly all of it aye? Now if you can remember again, where did you roll off the gas for turn 7? If you can remember that point on the track, congratulations, you had just set your very first braking marker. But let’s look closer, why am I talking about the no brake drill while on the subject of braking? Because during the drill you were goals were to set entry speed and a turn in point. It’s important to know that your turn in point and your braking marker are attached at the hip. If you move your turn in point, your brake marker can also be moved respectively. To put it simply, if your braking in a straight line, that line has a start (brake marker) and end (turn in point). Move either of those points, and the line (braking distance available) will be shorter or longer based on your movement(s). Understanding the relationship between those two points is the key to getting most out of your brakes (and is one of the secrets of advanced passing skills @alex.s). From that point on, small forward movements (about a bike length) of the brake marker can be made to decrease the amount of track space between that new marker and the turns turn in point. You should remember to do your hard braking near the front end of that braking line (braking zone) and trail off the brake before the turn in point to accurately set your entry speed. And… since we don’t normally downshift in turns, downshifting is another activity that is timed in the braking zone and based off the turn in point. Without upsetting the suspension, in a corner....going in to hot. How do you keep from making it worst?: First! An ounce of prevention is worth a pound of cure. Getting a handle on the needed skills to negotiate a corner well should be done before testing higher speeds that may trigger the going in to hot SR. When you overcook a turn, don't panic! Unless you're nearly at race pace, truly overcooking the turn entry is kinda rare on modern bike hardware. It’s an SR, and part of the point of asking questions and learning is how to handle those SR’s effectively. Mainly though, chopping the throttle will make the instability worse in many ways and get your lower body in position while on the gas and get your grip and arms loose just before your braking marker and stay there! This will prevent much instability before it even starts. In my experience, the most common entry speed issues are over braking, followed by an entry speed that is only mildly over the riders comfortable entry speed sending them wide because the rider may feel they can’t turn in time. This is where knowing how to hook turn can pay big dividends. The SR will trigger that the rider is going too fast, and then the rider causes 99% of the instabilities by reacting to the SR’s vs making corrective actions. Look where you want to go, keep loose, and move that head and torso much, much lower and to the inside while maintaining good throttle control. This will maintain and even improve stability if you find yourself running wide in a corner for any reason. Do not move your lower body off the bike at this time as it will add instability. When the rider feels they more than mildly over their comfortable entry speed. There are 2 main schools of thought on how to handle it; just gas it and lean it, which plays on the above statement that overcooking the turn is rare. The other is an product (result) of decisive actions; stay calm and loose, reduce lean angle, brake to a more controllable speed, repoint the bike (re-steer) and restart throttle roll. Only one of these puts the rider in complete 100% control, 100% of the time, while maintaining as much stability as possible. While the other leaves the rider at the mercy of speed, the bike, available traction and a bit of blind luck, and at the same time, the rider may be fighting the bike due to the SR’s. So assuming you as the rider wants to be in complete control all the time. If you find yourself too hot on entry; stay calm and loose, reduce lean angle, brake, repoint then restart your throttle roll. To just throttle it out and add lean as needed is a common reason for crashes. The reason this works, is also based on the first school of thought. WTF how?!?!?!? Think about it honestly, since it’s rare to “really” overcook a corner, then you shouldn’t be so far off your corner entry speed and line that the rider cannot complete these actions while still remaining on the track surface. Now let’s be realistic here, surface elevation change can make doing this visually very difficult. When you can't see how much tarmac to work with the SR’s are much, much worse. There is an exception to doing this though, if there is a rider to your outside you can’t run them over, possibly crashing two riders instead of one and so goes the risk of riding fast… There is also another option as a last resort depending on how comfortable you are with alternate lines through the corner. If a rider overcooks their normal turn in point, do they know another line that allows for additional braking distance? When a rider “seriously” overcooks a corner, your turn in point can be near the edge of the track before the corner followed by a quick flick. Check the red car in the image below, the other cars in the image have their various turn in points but the red car hasn’t turned yet. Compare the orange car to the red car. The orange car has a better turn in point for the corner, but if the red car overshot the entry speed, the red car can move the turn in point closer to the edge of the tarmac to allow for more braking distance while straight up vs trying to brake in the corner adding instability and possibly overloading the front wheel causing a lowside. @lowcel has witnessed me do just this, that extra 50ft of braking distance made the difference between making the corner vs making sand castles in china beach. hahahahahahaha Talking to a coach about how you "blew the corner" is a much better conversation than a chat in the medical building about what happened in the corner. When to dip and roll on?: What do you mean here? Turn and start to roll the throttle?
Goal: Shake A Million Hands | Look through the corners | Track Day Prep | Closest track? | The Mid-Ohio School Last futzed with by csmith12; April 11th, 2015 at 10:52 AM. Reason: spelling |
April 11th, 2015, 09:30 PM | #72 | ||
Here is a sample; Quote:
April 12th, 2015, 10:19 AM | #73 | |
Here is another sneak peek Alex!
April 12th, 2015, 01:05 PM | #74 |
those tippy toe brakes on turn in... i hate when i do that when i know i can just do a 10% roll off or even just take it wide open with softer steering. its a fear thing i guess
April 12th, 2015, 01:27 PM | #75 | |
Funny story... In most of left corners, it would get some medium chatter post apex. Turns out, the gent that I bought it from left it sit for 1.5yrs without moving, it and had some mild flat spots. The chatter was every lap but only at slow/med. paces, but think about it more, what side of the bike is the sidestand on? It put the lean angle right about the same it would sit on the side stand. A new set of tires and poof! No more chatter. Bummer is, I spent 3/4ths of a day, trying to figger out if it was me causing the chatter trying to get used to a "new to me" bike. So goes the life of a rider trying to git-r-done at the track. /sigh... To be the coach I want to be, I must get faster at figuring out these kinds of simple things. "Every Lap", "only slow/med pace" and "only lefts" tells the story.
April 12th, 2015, 08:26 PM | #76 |
Private Joker
MOTM - Mar '14
Turn 12 at jennings is special, T2 is one thing, you still see mad run off so it's easier to get comfortable flying through there but T12 you see trees in your peripheral vision
this does affect my confidence in some corners, which is silly considering I ride shenny a lot where the run off is about as bad as a public road
April 15th, 2015, 01:53 PM | #77 |
Private Joker
MOTM - Mar '14
Elaborating on this would make a great article that would be useful for many people, myself included, as a study of the process and approaches of improving at riding, and pretty much everything else really.
April 15th, 2015, 01:59 PM | #78 |
MOTM - Sep '14
Keep calm and ride on -Motofool Never quit on a rainy day -ally99 |
April 15th, 2015, 02:00 PM | #79 |
Private Joker
MOTM - Mar '14
Well I believe a challenge was what was asked for
April 15th, 2015, 03:50 PM | #80 | |
I am not sure I am qualified to write anything on this. Lemme think about it and see if I can base it on any real "proven" facts vs experience. This is a good question and one that does "challenge" me.
Rokon Challenge | Panda | Videos | 1 | November 2nd, 2013 09:03 PM |
Flap challenge #2 | KazMan | Ninjettes At Speed | 96 | July 18th, 2012 03:27 PM |
Arcade Challenge? | dubojr1 | Off-Topic | 8 | June 28th, 2012 12:50 PM |
Ididaride Challenge | spooph | General Motorcycling Discussion | 31 | February 2nd, 2011 05:26 PM |
