Old May 2nd, 2015, 02:19 AM   #1
Billson
Motorcycle(s): 88 Kawasaki 250 ninja
Question Gday new here, bike idles down very slow!
Hey everyone, picked up a 88 250 ninja and had to clean the carbs and put a few things back together, still haven't got the air box on due to no screws for it... But to the point when I start it up and give it a squirt it takes a while to idle back down, just wondering if I haven't put a hose on somewhere or what's going on??
Billson is offline   Reply With Quote
Old May 2nd, 2015, 04:18 AM   #2
That's typical of a vacuum leak or very lean condition.
Check the rubber boots and connections from the carb to the engine by spraying some carb cleaner on them and listening for a change in RPMs.
What did you set the idle mixture screws at? 2 1/2 turns out is a good starting point. They are fuel-bleeds, so turning out gives a richer mixture.
Old May 2nd, 2015, 07:42 PM   #3
Originally Posted by Billson View Post
........ just wondering if I haven't put a hose on somewhere or what's going on??
Welcome, Billy !!!
Yes, the lack of air filter makes the mix lean, which keeps the rev's up, as pointed above.
Check that the throttle cables are fully releasing the butterflies in the carbs, aas well as the choke cable is fully releasing the choke's plunge via some slack and quick return.
Those cables and the throttle handle always appreciate some lubrication.
Old May 2nd, 2015, 08:32 PM   #4
Billson
Thanks guys I've have a look, also I only have airbox outside, when I got it there was no filter or even the inserts that hold it in
Old May 2nd, 2015, 08:37 PM   #5
Billson
Also is there supposed to be a hose going from the back centre of the carbys to somewhere? Not sure cause nothing was put together
Old May 2nd, 2015, 08:52 PM   #6
Start by reading through these:
http://faq.ninja250.org/wiki/How_do_...n_the_carbs%3F
After jetting bike idles low? Mr_ek9 2008 - 2012 Ninja 250R Tech Talk 2 January 17th, 2015 02:18 PM
Parked bike fell in mud and now idles low/won't start. BoKing 1986 - 2007 Ninja 250R Tech Talk 9 December 15th, 2014 03:28 PM
Bike idles higher when leaned over on kickstand cuong-nutz 2008 - 2012 Ninja 250R Tech Talk 2 September 25th, 2014 12:24 PM
Giving up the slow bike for a slow car CycleCam303 Off-Topic 17 February 18th, 2014 02:13 AM
Gday from australia :P bomber12 New Members 13 July 12th, 2010 09:29 AM
