Go Back   ninjette.org > General > Off-Topic
Old July 5th, 2015, 03:08 AM   #1
Somchai
Freedom for Germany
Motorcycle(s): Ninja 250R-FI
29% performance boost for 8.50 USD
By installing a 'tuning piston return spring' (piston retract spring) you can give the engine in your vehicle a performance boost of up to 29%.
The operating principle of the piston return spring is the prevention of explosion.
By the piston in a normal gasoline engine the fuel-air mixture is compressed which can result in an explosion. If the explosion happens it causes you performance losses because the fuel-air mixture is burning.
With the help of our 'tuning piston return spring' from environmentally harmful PET-C (plutonium Etel tuning carbonate) it's prevented that the piston stops at TDC. Thus, the fuel-air mixture can escape easily from the exhaust.
The tension degree of the piston return spring is adjusted through the accelerator.
Buy this and much more here: http://etel-tuning.eu/leistungstunin...kholfeder.html
Old July 5th, 2015, 04:16 AM   #2
Snake
Snake's Avatar
LMAO! That is just way too funny.
Old July 5th, 2015, 07:48 AM   #3
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
dafuk?
TEAM ALFALFA
www.apexassassins.com
Old July 5th, 2015, 10:16 AM   #4
cadd
cadd cadd cadd
cadd's Avatar
Motorcycle(s): 300
MOTM - May '15
No green one? Need to match my bike's color so everyone can see them.
Riding it like I financed it.
Old July 5th, 2015, 10:50 AM   #5
TnNinjaGirl
Ms. Personality
TnNinjaGirl's Avatar
Do you have to match the spring color (presumably tension setting) to the same color power band that you are running?
Old July 5th, 2015, 10:55 AM   #6
Brother Michigan
Motorcycle(s): 2013 Ninja 300
They really should be complementary colors to get the greatest impact.
DISCLAIMER: I generally have no idea what I'm talking about.
Old July 5th, 2015, 09:02 PM   #7
xorbe
xorbe's Avatar
Isn't that a straight up joke description for a desktop piston prop? I mean, look at the operator pic on the right ... it's comedy.
Old July 5th, 2015, 09:34 PM   #8
haha. this is marvelous. where does one get this, "plutonium ethyl tuning carbonate"? when using the plutonium-ethyl, does one need to actually use gas? or will the engine run for the expected half-life of 24000 years?
Old July 6th, 2015, 07:11 AM   #9
Rifleman
Old and slow
Rifleman's Avatar
Motorcycle(s): Suzuki TL1000R, Honda CBR600F3, Ninja 250
hey, I can't even get that stuff Though I would like to get some new power bands... and maybe some high performance blinker fluid.
http://img.photobucket.com/albums/v620/Ricejocky/achievement.easy.bake.Rifleman_zpscllv4ryl.png
Rifleman is offline   Reply With Quote
Old July 6th, 2015, 08:48 AM   #10
Ninjinsky
Ninjinsky's Avatar
They do a kit for Yamaha riders too
Old July 6th, 2015, 10:02 AM   #11
cadd
cadd cadd cadd
cadd's Avatar
Motorcycle(s): 300
MOTM - May '15
Yup, synthetic blinker fluid is the way to go.
Old July 10th, 2015, 12:44 PM   #12
xorbe
xorbe's Avatar
"Forget the X, Y, and H type exhausts. We now have the new O-type exhaust! Also works for electric vehicles."
Old July 10th, 2015, 01:22 PM   #13
Rifleman
Old and slow
Rifleman's Avatar
Dude, that blinker fluid is getting cloudy... just like brake fluid, needs to be changed when it gets just the tiny bit of yellow tinge, or cloudy...
oh man, that is a beautiful pic of blinker fluid, I think I'm going to steal it.
Old July 27th, 2015, 12:34 PM   #14
VaFish
VaFish's Avatar
MOTM - Jan '16
Should have seen the look on my face when the salesman said my new 2014 Duramax Diesel truck needed "Exhaust Fluid".
Old July 27th, 2015, 12:46 PM   #15
DEFY
ᗧ•••ᗣ•ᗣᗣ•••ᗣ
DEFY's Avatar
When the fluid starts leaking means you need to soon replace the muffler bearings. You can puncture the diaphragm and the exhaust will start to draw air in if you don't replace them lol. I recommend you go pick up the gold standard, it will save you 2 years before you have to replace them again.
Spoiler for topic:
It might just be the [you] tag
Old July 27th, 2015, 01:05 PM   #16
VaFish
VaFish's Avatar
MOTM - Jan '16
New Diesels do seriously use exhaust fluid.
https://en.wikipedia.org/wiki/Diesel_exhaust_fluid
Makes neat little crystal structures when it leaks all over your hunting cloths in the back of the truck.
Old July 28th, 2015, 04:16 PM   #17
TheJeepGuy
TheJeepGuy's Avatar
Motorcycle(s): TRX 450 R Quad, no street
And it's pretty much just cat pee, or my mechanic is misinformed. Ether or.
TheJeepGuy is offline   Reply With Quote
Old August 4th, 2015, 11:12 AM   #18
JohnnyBravo
Certifiable nontundrum
JohnnyBravo's Avatar
MOTM - Sep '13, Sep '16
Urea is def pee... Anyone who buys that crap is an idiot!
Old August 5th, 2015, 04:41 AM   #19
Ducati999
Motorcycle(s): Ducati 999 2012 Ninja 250r Ducati748 Yellow finally running 2003 SV650 S (SOLD)
You are wrong it is Pee with de ionized water! you have to dilute the pee for it to be a sellable product!
Ducati999 is offline   Reply With Quote
Old August 7th, 2015, 12:51 AM   #20
JohnnyBravo
Pee is pee no matter how much water you put in it... Would you rather have your water with pee or without?
Old August 7th, 2015, 04:26 AM   #21
Ducati999
I guess that would depend what I was going to do with it, never really gave it any thought till now!
[motorcyclistonline] - Takai (division of WeaponX Performance) Performance Ignition C Ninjette Newsbot Motorcycling News 0 September 30th, 2011 09:30 PM
[sportrider - latest stories] - TAKAI (division of WeaponX Performance) Performance I Ninjette Newsbot Motorcycling News 0 September 29th, 2011 06:10 PM
[motorcyclistonline] - 'Camp LaRocco' helps boost morale, lift performance of GEICO H Ninjette Newsbot Motorcycling News 0 July 15th, 2011 09:00 PM
a little extra boost. egb1108 General Motorcycling Discussion 34 June 12th, 2011 02:28 PM
[topix.net] - Hero allowed USD 1 billion foreign investment Ninjette Newsbot Motorcycling News 0 March 30th, 2011 01:40 AM
