July 3rd, 2009, 06:12 PM | #1 |
Join Date: Jun 2009 Motorcycle(s): 2000 Ninja 250 (Red) Posts: 13
Question on footpeg placement, and controls.
Hey, I've noticed a minor problem on my bike.
Since I'm rather tall (6'4"), my feet tend to want to be angled down a little bit on the pegs. this means unless im way duck footed im pressing down on the shifter and rear brake. I have adjusted the brake lever far enough that its no longer an issue. I also adjusted the shifter, however i can't adjust it far enough due to the linkage hitting on the footpeg mount. So i adjusted it back up so it doesnt make contact anymore. but the shifter is still under a small amount of pressure in my ideal position on the bike. Should I just attempt to alter my riding position or is there some way to modify something slightly so i'm not holding pressure on the shifter? Or can I just hold my toe out far enough it doesnt touch the shifter? Thanks, Tom |
July 3rd, 2009, 06:20 PM | #2 |
July 3rd, 2009, 06:26 PM | #3 | |
I'll try to get a pic of it sometime, its dark out now and the bike is in my brothers shop for now, I'll see if i can get pictures tomorrow. Tom |
July 3rd, 2009, 06:30 PM | #4 |
cool... try to get some pics with the shift lever hitting the footpeg mount.
July 3rd, 2009, 06:36 PM | #5 |
Yep, I'll definetly do that.
Thanks |
July 4th, 2009, 03:27 AM | #6 |
MOTM - Sep '18, Feb '16
footpegs
I have had the same problem . I have tried every combination of foot peg and rear set.
I ended up using Buell XB foot pegs. With stock rear sets . They go down and back just enough. And I have the shifter adjusted to work .Before If I adjust the shifter where it is comfortable it would hit the foot peg when going Down into first . I ground a slight notch into the foot peg to allow it to move .. BUT then it hits the bolt head for the kick stand. So I had to bend it out. I have a 34 inch inseam and have a bad knee . So folding my legs up gets very uncomfortable on long rides.That is why I have spent so much time on my seating position..Something I have not tried it raising the seat with either more padding or shimming the bolts up at the front of the seat The first photo is all the stuff I have tried . The second is the Buell XB foot pegs. |
July 4th, 2009, 10:23 AM | #7 |
Jarod:
It sounds to me like you are trying to ride the motorcycle with the arches of your feet on the pegs. You should be riding with the balls of your feet on the pegs, and moving your feet as required to access the controls. Other points to cover - make sure your crotch is scooted right up against the gas tank, grip the tank firmly with your knees, and use your abdominal muscles (not your hands/arms) to support your upper body. Wes |
July 4th, 2009, 10:30 AM | #8 |
welcome to the forum, Wes.
July 4th, 2009, 11:08 AM | #9 |
don't guys tend to not want to be up against the tank?
July 4th, 2009, 11:29 AM | #10 |
North Alabama Mtn. ryder
hey jarod hows it going, im the same height as youand it took some training to become comfortable without putting weight on the bars. My big thing was using the balls of my feet on the pegs and training my lower back and legs to support my weight. yesterday i put 200 miles on it at one time and was fairly comfortable. i bet i look kinda funny all folded up. i feel even goofier on the new 600's
QTRltrPWR |
July 5th, 2009, 12:16 AM | #11 | |
Join Date: Feb 2009 Motorcycle(s): '91 Honda CBR600 F2 Posts: A lot.
1991 Honda CBR600 F2, White/Gray, D&D slip-on exhaust, tail integrator, gel grips, Custom undertail. |
July 5th, 2009, 07:54 AM | #12 |
Join Date: Jun 2009 Motorcycle(s): 2007 Ninja 250 Posts: 16
I had no idea the brake lever and shifter could be adjusted. I have the opposite problem. I'm 5 feet tall, While riding I scoot my foot all the way forward to be able to reach the brake and Shifter. So my just my heel is in contact. When I first take off my foot naturally wants to be on the peg at the ball of my foot, causing me to readjust. Im in a lot of stop and go traffic, shouldn't I position my right foot on my rear brake for quick stopping (just in case)?
July 5th, 2009, 02:27 PM | #13 | |
Join Date: Jan 2009 Motorcycle(s): 05 GSX-R 600 2003 EX250: Woodcraft Bars, Levers, Mirrors, Shim'd Mixture, Synthetic, '08 Rear Shock Posts: A lot.
i've gotten into the habit years ago of having my foot and toes on top of the brake and shifter, unless i have them as you and others have described, ball of foot on peg.
do you have a maintenance manual for your bike? i think you may be able to address your concerns by raising the brake and shifter from their present position. Quote:
in town, in traffic, in twisties, your feet should be ready to apply whatever you need (shift or break). this should be your 'default' or primary riding foot posture IMHO. i'll adjust my feet on the pegs while cruising in a more open enviornment w/less traffic. also, when moving fwd. from a stop, my right foot is up first and on the rear brake lever in case i need to brake at slow speeds. you have a PM
Remember when sex was safe and motorcycles were dangerous? |
July 6th, 2009, 07:34 AM | #14 |
argh, sorry I haven't been able to get pictures yet, its been a bit crazy around here suddenly.
It seems like i may very well be positioning my feet wrong though. I've ridden ATVs and other powersports stuff, and the arches sat on the pegs usually. so I assumed the arches of my feet were where the pegs should sit. I'll try to get some pics as soon as i possibly can. |
September 17th, 2011, 08:58 PM | #15 | |
Butt camera placement | Jiggles | Ninjettes At Speed | 4 | August 7th, 2013 07:37 AM |
Mirror placement and your preferences | CThunder-blue | General Motorcycling Discussion | 18 | November 11th, 2012 07:29 PM |
Shift arm linkage placement | Redsvt | 2008 - 2012 Ninja 250R Tech Talk | 1 | March 11th, 2012 08:43 AM |
left hand controls 95 bike 05 controls | mapolley07 | 1986 - 2007 Ninja 250R Tech Talk | 12 | December 22nd, 2011 10:05 AM |
Base sticker placement? | Underkill | General Motorcycling Discussion | 10 | January 29th, 2010 11:31 PM |
