July 31st, 2015, 12:04 PM | #1 |
Join Date: Aug 2012 Motorcycle(s): 2007 Ninja 250 Posts: 181
Gas tank leaking from underneath
As the title says, my tank has a leak. It is on the bottom, on the Right, near the front. Somewhere near the mounting bracket thing. I still have not find the exact location, and I fear it may be under the bracket.
What are my realistic options? I don't see any pregen talks on eBay at the moment, and oem is life $800. Searching find people suggesting everything from Bondo, to redkote, to peanut butter to welding. Everything has people saying it works and others saying it doesn't. What words of wisdom can you give me?
Shhhhh, don't tell Jiggles I am using the [ you ] tag. |
July 31st, 2015, 12:47 PM | #2 |
Contact your local radiator shop, they should be able to repair the leak, and maybe coat/seal the tank.
July 31st, 2015, 01:21 PM | #3 |
It's almost certainly the fairing screws; someone put the long ones in the bottom by accident, or simply screwed the existing ones in too hard. There was a recall for this quite awhile back for a small percentage of pre-gens who may have been given the wrong screws at the factory, so check your vin with kawi on the off-chance you can still get a free tank for the problem.
Like you've stated, I've seen a variety of fixes. Some say JBweld works fine, others don't. Some use quicksteel + jbweld, some find other ways to patch the hole. However you do fix it, make darned sure you are using the correct screws and don't overtighten, so you don't put the hole right back into your repair.
July 31st, 2015, 01:55 PM | #4 |
I don't think it is the farting screw issue. The leak is on the bottom of the tank. Out send to be coming from underneath the "bracket" that slips over the rubber thing when you install the tank.
I am sure there are proper terms for all this, but I don't know what they are.
July 31st, 2015, 02:28 PM | #5 |
Ah - got it.
August 1st, 2015, 11:40 AM | #6 |
Join Date: Jun 2013 Motorcycle(s): N650 (and others) Posts: 408
Like, take the tank off and look ... 5-10 minutes? Outside in a well ventilated area!
August 2nd, 2015, 08:56 PM | #7 |
MOTM - July '15
Ive had success in using some of that putty that you cut off then knead into one color then apply. I think the reason most people fail at this is because they dont apply pressure to the putty for long enough. I kneaded mine, applied it, then held my hand on it firmly for 30 minutes because the instructions said to hold it until it starts to harden, and said it hardens in 30 minutes. You might call that overkill, i call it a tank without a leak in it anymore. Just grab your smartphone, sit on the ground, and firmly apply pressure for 30 minutes, and let out a loud, painful groan when youre done.
August 8th, 2015, 02:16 AM | #8 |
Join Date: Jul 2015 Motorcycle(s): 2004 EX250R Posts: 39
PM sent... U get it ?
August 16th, 2015, 06:08 PM | #9 |
Join Date: Jul 2015 Motorcycle(s): buell s1, triumph 955 daytona, and 99 ninja 250 Posts: 15
regular jb weld wont work on gas so get jb weld steel stick and forget about bondo it dont work with gas
August 16th, 2015, 06:25 PM | #10 |
Personally this needs to fixed properly, we are talking about gas leak right above a hot engine.
Take the tank to a professional, if you don't have the proper tools to fix it.
August 16th, 2015, 08:15 PM | #11 |
Participant
Join Date: Oct 2012 Motorcycle(s): '94 K75 std Posts: Too much.
Well stated! I'm not a fan of snake-oil coatings (Kreem, etc.) or glue for fixing fuel leaks.
August 16th, 2015, 09:27 PM | #12 |
Almost all radiator shops do motorcycle tank repairs, and even some will do the professional coating as well. Money well spent.
August 17th, 2015, 12:37 AM | #13 |
MOTM - July '15
My putty's still holdin up.
August 19th, 2015, 11:21 AM | #14 |
I have seen that kind of leak near the front tank to frame mount before due to rust. Is your tank rusted on the inside.
I think I still have a black pregen gas tank in my spare parts pile. PM me if you are looking to buy a used tank. |
Leaking gas | Alisha_Ardella | 2008 - 2012 Ninja 250R Tech Talk | 23 | May 11th, 2015 10:41 AM |
Moto leaking gas | Qomomoko | 1986 - 2007 Ninja 250R Tech Talk | 23 | April 24th, 2015 11:33 AM |
Leaking Gas Tank | tay2 | 1986 - 2007 Ninja 250R Tech Talk | 1 | October 2nd, 2014 05:46 PM |
Why is My Gas Cap Still Leaking?! | az3200 | 1986 - 2007 Ninja 250R Tech Talk | 9 | May 8th, 2013 06:17 AM |
leaking a little gas | h0yitsdom | 1986 - 2007 Ninja 250R Tech Talk | 15 | July 11th, 2011 04:57 PM |
