Old August 28th, 2015, 09:43 AM   #1
TnNinjaGirl
Ms. Personality
TnNinjaGirl's Avatar
Wire wheels
Has anyone done wire wheels on their pregen?
Specifically I'm thinking a 17" rim on a dual disk front hub and a disk rear hub with 17" rim. Maybe a bit wider on front and rear.
Old August 28th, 2015, 11:32 AM   #2
Haven't seen 'em yet, but now that you mention it I'd be curious to see how they look.
Old August 28th, 2015, 11:38 AM   #3
Ghostt
Ghostt's Avatar
Would be awesome for a cafe' racer modification.
violente et ignorantia
ZX-2R BLOG
Old August 28th, 2015, 11:40 AM   #4
There was a picture floating around a while back of a pregen modded up in scrambler trip with wire spoke wheels. Remember what I'm talking about?
That said, check out Warp 9 and their sumo wheels for dual sports. They typically come in whatever color you want, 17" diameter, and as wide as you want, usually with as large of a brake rotor as you can stuff in it if that's what gets you excited.
If I were going to try and put spoked wheels on, that's the route I would take. Find a dual sport, fit those wheels to the ninjette, then swap out for sumo conversion wheels. Would look neat!
EDIT: found the post I was thinking about. Not sure what came of the OP's bike, if he ever actually did this or just asked about it...
https://www.ninjette.org/forums/show...4&postcount=32
Old August 28th, 2015, 12:11 PM   #5
It does look good on that bike.
Old August 28th, 2015, 12:13 PM   #6
There WILL be another....
Old August 28th, 2015, 12:25 PM   #7
dcj13
Participant
dcj13's Avatar
Motorcycle(s): '94 K75 std
Wire wheels are cool looking, but are a PITA. Gotta run innertubes, so you can't plug a hole in the tire and continue your ride; need truing now and then; more work to keep clean.
But, oh, they look good!
Old August 28th, 2015, 12:34 PM   #8
Do they make rim strips for those like they do for single wall bicycle rims or are the tubes extra thick in that area where the tube makes contact with the inside of the nipples?
Old August 28th, 2015, 12:49 PM   #9
TnNinjaGirl
Ms. Personality
I guess I'll need to measure my hubs to see how wide they are and go from there. Rims should be easy to find and spokes can be found/made.
Now that I think of it I may end up going with a different set of forks so it may not even be an issue.
I'm not really worried about how much maintenance or whatever it will be. It's a custom bike. I've got several others to ride if I want something reliable.
They do look good though. Seems like a great way to retro-fy the pregen. I'm also assuming the wheels would weigh less but I could be wrong.
I suppose it was a shot in the dark to see if I could copy someone's work instead of doing my own research.
Old August 28th, 2015, 01:02 PM   #10
http://gas2.org/2013/12/16/recycled-...50-retro-redo/
Old August 28th, 2015, 01:46 PM   #11
TnNinjaGirl
Ms. Personality
Oh I like that
Old August 29th, 2015, 06:25 PM   #12
Originally Posted by TnNinjaGirl View Post
.........I suppose it was a shot in the dark to see if I could copy someone's work instead of doing my own research.
Take a look at this:
http://www.motorcyclistonline.com/do...s-spoked-wheel
Old December 4th, 2015, 05:53 AM   #13
Yamahawk
Chaplain
Yamahawk's Avatar
Motorcycle(s): 75 RD350 race bike, 82 XZ550RJ Vision, 81 XV920RH, 89 VTR250 Interceptor race bike, 06 Concours, 86 EX250E1
I think it was the KLR650 rims that could be adapted to the EX250's, but don't quote me on that... They are Kawasaki, and they are wire wheels, you could have a different size front rim laced up on it to eliminate the 21" rim, unless that would be preferable, and use the rear KLR rim as is. Of course, spacers, sprocket alignment, etc. will all have to be considered and dealt with... but it can be done!
God chose what the world thinks foolish to shame the wise,what the world thinks as weak to shame the strong,what is despised in the world,what is nothing,to set aside what is regarded as something
Yamahawk is offline   Reply With Quote
[American Motorcyclist Association] - Near-perfect wire-to-wire effort gives veteran Ninjette Newsbot Motorcycling News 0 March 11th, 2015 07:40 AM
[kropotkin thinks...] - 2014 Argentina Moto2 Race Result: Winning Wire-To-Wire Ninjette Newsbot Motorcycling News 0 April 27th, 2014 09:30 AM
[kropotkin thinks...] - 2014 COTA Moto3 Race Result: A Wire To Wire Win Ninjette Newsbot Motorcycling News 0 April 13th, 2014 10:10 AM
[motorcyclistonline] - Wiles Goes Wire to Wire at AMA Pro K&N Filters Grand National Ninjette Newsbot Motorcycling News 0 June 21st, 2010 06:40 PM
[topix.net] - Kendall Norman leads wire to wire at Sugarloafers MC Hare & Hound Ninjette Newsbot Motorcycling News 0 May 18th, 2010 06:00 PM
