Old September 3rd, 2015, 08:10 PM   #1
[motorcyclistonline] - BMW S1000XR vs. DUCATI MULTISTRADA 1200 – Tested To the Limit!
http://cf.c.ooyala.com/FpNHJjdzrXrVR...promo265599120
Please enable Javascript to watch this video
Where do BMW’s S1000XR and Ducati’s Multisrada 1200 S fit in? They have big windscreens and side cases like touring-bikes, but they also have hand guards and long-travel suspension like ADV bikes. And yet with big brakes, high-performance engines, and loads of electronic rider aids they clearly have plenty of sportbike DNA too.*
So what are the S1000XR and Mulstisrada 1200, and more importantly, what can they do? In this episode of On Two Wheels we set out to answer that question—on the dyno, at the drag strip, at the track, on the Pacific Coast Highway, and even in the dirt! *
Watch the video above to see how these two premium do-it-alls compare in the real world, and check out the dyno, ergo, and spec charts below to see how they stack up on paper.
TECH SPEC BMW S1000XR DucatI MULTISTRADA 1200 SPRICE $19,790 (as tested) $21,094 (as tested)ENGINE TYPE 999cc, liquid-cooled inline-four 1198cc, liquid-cooled 90° V-twinBORE x STROKE 80.0 x 49.7mm 106.0 x 67.9mmCOMPRESSION 12.0:1 12.5:1VALVE TRAIN DOHC, 16v DOHC, 8vFUEL SYSTEM EFI, ride by wire EFI, ride by wireCLUTCH Wet, multi-plate slipper Wet, multi-plate slipperTRANSMISSION/FINAL DRIVE 6-speed/chain 6-speed/chainFRAME Aluminum twin-spar Tubular-steel trellisFRONT SUSPENSION Sachs 46mm fork with dynamic compression and rebound damping; 5.9-in. travel Sachs 48mm fork adjustable for spring preload with dynamic compression and rebound damping; 6.7-in. travelREAR SUSPENSION Marzocchi shock adjustable for spring preload and rebound damping; 5.5-in. travel Sachs shock adjustable for spring preload with dynamic compression and rebound damping; 6.7-in. travelFRONT BRAKE Brembo four-piston calipers, 320mm discs with ABS Brembo four-piston calipers, 320mm discs with ABSREAR BRAKE Brembo two-piston caliper, 265mm disc with ABS Brembo two-piston caliper, 265mm disc with ABSFRONT TIRE 120/70-ZR17 Bridgestone T30 120/70-ZR17 Pirelli Scorpion TrailREAR TIRE 190/55-ZR17 Bridgestone T30 190/55-ZR17 Pirelli Scorpion TrailRAKE/TRAIL 25.5°/4.6 in. 24.0°/4.3 in.SEAT HEIGHT 33.1 in. 32.5/33.3 in.WHEELBASE 61.0 in. 60.2 in.MEASURED WEIGHT (TANK FULL/EMPTY) 535/504 lb. 548/516 lb.FUEL CAPACITY 5.3 gal. 5.3 gal.FUEL MILEAGE (HIGH/LOW/AVG.) 546/33/39 mpg 44/34/40 mpgRANGE 207 mi. (including reserve) 212 mi. (including reserve)¼-MILE (CORRECTED) 10.95 sec @ 129.4 mph 11.48 sec @ 123.0 mphTOP-GEAR ROLL-ON 60–80 MPH 2.8 sec. 4.2 sec.WARRANTY 36 mo., 36,000 mi. 24 mo., unlimited mi.CONTACT bmwmotorcycles.com ducatiusa.comDYNO
Cylinder count trumps displacement in this game. Not only does the BMW own the Ducati in peak power, but it lays down a much smoother torque curve, though the Ducati’s deserves something of an asterisk, as the fueling might be compromised by early calibration glitches.
©Motorcyclist
©Motorcyclist
ERGOS
Gerhard, meet your Italian cousin. The rider triangle on the BMW is subtly tighter, with less legroom, more rearset footpegs, and a taller bar. Ducati’s fine Italian saddle makers did a better job, even with a lower seat height. Both bikes are terrifically comfortable though.
©Motorcyclist
Click here for full story...
[motorcyclistonline] - 2016 BMW S1000XR vs. 2015 Ducati Multistrada 1200 S | MC COMPA Ninjette Newsbot Motorcycling News 0 September 3rd, 2015 05:00 PM
[motorcyclistonline] - 2015 Ducati Multistrada 1200 | FIRST LOOK Ninjette Newsbot Motorcycling News 0 November 3rd, 2014 04:40 PM
[motorcycle.com] - 2015 BMW S1000XR Spied Inline-Four Multistrada Rival on the Way Ninjette Newsbot General Motorcycling Discussion 6 April 8th, 2014 11:59 AM
[motorcyclistonline] - Ducati Multistrada 1200 Makes First U.S. Appearance Ninjette Newsbot Motorcycling News 0 December 1st, 2009 07:00 PM
[motorcyclistonline] - First Look: 2010 Ducati Multistrada 1200 Ninjette Newsbot Motorcycling News 0 November 9th, 2009 07:10 PM
